Help Center/ Migration Center/ User Guide/ Application Migration Projects/ Migration Workflows/ Creating a Batch File Storage Migration Workflow
Updated on 2026-10-27 GMT+08:00
This section describes how to create a workflow to efficiently migrate file systems in batches.
This function is currently available only in the LA-Sao Paulo1 and LA-Santiago regions. It is no longer available in the AP-Singapore and TR-Istanbul regions.
A batch file storage migration plan has been created for the source file systems to be migrated.
  1. Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
  2. In the navigation pane, choose Migration Workflows (NEW).
  3. On the Workflows tab, click Create Workflow to open the Select Creation Method page.
  4. Select the created batch file storage migration plan from the Migration Plan drop-down list. Then click OK. Incomplete migration plans cannot be selected. For details about how to create a file storage migration plan, see Creating a Batch File Storage Migration Plan.
  5. In the Basic Information area, enter a name and description for the workflow.
  6. In the Resource Settings and Migration Settings areas, check whether the resource and migration settings inherited from the selected migration plan meet your requirements. If you need to modify these settings, click Modify Migration Plan in the lower right corner of the page and update the migration plan settings.
  7. Confirm the settings and click Create Workflow in the lower right corner of the page. The Start Workflow dialog box is displayed, indicating that the workflow has been created.
    • If you want to start the migration immediately, click Confirm to run the workflow.
    • If you want to save the migration workflow without starting the migration, click Cancel. The migration workflow will move to a Waiting status, and the migration has not started yet. To run the workflow, click Run in the Operation column to manually start the migration. If you need to add checkpoints to the workflow to control the migration process, see Adding a Stage or Step.
  8. In the workflow list, click the workflow name. On the Workflow Details page, you can review the workflow status, progress, and migration progress of the resources contained in the workflow.
    When the workflow on a resource reaches a step requiring manual confirmation, choose More > Confirm in the Operation column, or click the resource name. In the displayed page, click Confirm. The workflow will then continue with the remaining migration steps.
    In the resource list, click More > View Target Resource in the Operation column to view details about the target file system.
  9. Click a resource name. On the page displayed on the right, you can view the Migration Progress and Historical Tasks tabs. You can also perform the operations below.
    Operation
    Modifying the number of concurrent subtasks
    1. In the Migration Progress area, click Modify above Expected Concurrent Subtasks to change the expected number of concurrent subtasks. There cannot be more than 10 concurrent subtasks for each online migration node. For example, if there are 2 online migration nodes, there can be up to 20 subtasks.
    2. Click Confirm.
    Adding traffic limiting rules
    1. In the Migration Speed area, click Add to add a rule to limit the bandwidth the migration can use in a specified period.
      NOTICE:
      • The bandwidth limit ranges from 1 MB/s to 1,048,576 MB/s.
      • Time periods in different rules cannot overlap.
        For example, if there is a rule added for the period from 8:00 to 12:00, you cannot configure rules for any overlapping periods, such as from 7:00 to 13:00, 7:00 to 8:00, and 9:00 to 12:00.
      • The start time in a rule cannot be later than the end time.
        For example, the time period from 23:00 to 01:00 is not allowed.
    2. Click Save.
    Obtaining the lists of migrated, skipped, or failed files
    In the File Statistics area, view the paths of the lists of migrated, skipped, or failed files. Click a file path, and it will take you to the OBS bucket where the list is stored. You can download the list from the bucket.
    Viewing traffic statistics
    In the Traffic Statistics area, view the migration traffic in the last 1 hour, last 6 hours, last 24 hours, or the entire migration period.
Deleting Workflow Resources
  • Only resources in the Failed, Paused, or Completed state can be deleted.
  • You can delete all resources to be migrated in a workflow. After all resources in a workflow are deleted, the workflow will be deleted together.
  1. Click the workflow name to view its details.
  2. In the resource list, select the resources to be deleted and click Delete above the list.
  3. Confirm the selected resources, enter DELETE, and click Confirm.
    To prevent resource deletion failures caused by disconnection of the workflow from related services (such as SMS, OMS, and OBS), you can select Force Delete to forcibly delete the resources. However, this operation only deletes the resource data from MgC. It may not delete the related tasks and resources in the related cloud services like SMS, OMS, and OBS. After the deletion, you need to manually delete the related tasks and resources in the related cloud services.
