Updated on 2025-08-19 GMT+08:00
Viewing and Exporting Task Execution Results
Each time a migration task is executed, a task execution is generated. On the task execution details page, you can view and export the task execution results.
The exported files can be downloaded within 15 days of when they are generated but will be automatically deleted after that.
A migration task has been created and executed.
  1. On the Task Executions page, locate a task execution and click View in the Progress column.
  2. Click Export above the list. The system starts to export the task execution results. You can filter the task execution results and export only the filtered results.
  3. Click Manage Exports.
  4. After the export is complete, click Download in the Operation column to download the exported results.
    Figure 1 Downloading exported results
