Adding Discovered Resources to an Application
The following procedure describes how to group discovered source resources as applications. These applications will be used for generating target recommendations and executing migration.
Source resources have been discovered through online and intranet-based discovery tasks or manual addition.
- Sign in to the MgC console. In the navigation pane, under Project, choose a project from the drop-down list.
- In the navigation pane, choose Discover > Applications.
- In the application list, click the name of your application.
- Select the type of resources to be grouped into the application. The following describes how to add source servers to the application. The procedure also applies to other types of resources.
- On the Servers tab, click Add Resources above the list.
- Select the source servers to be added to the application and click Add Now in the lower right corner. You can see the source servers added to the application in the list.
