Updated on 2026-09-20 GMT+08:00
Migration Cluster Resources and Settings
This section describes the resources and their settings of a migration cluster.
Resource Type
Configurable During Cluster Creation
Mandatory
Quantity
Naming Rule
ECSs
Yes
Yes
  • Master node: 1
  • Migration nodes: created based on the settings specified during cluster creation
  • List nodes: created based on the settings specified during cluster creation
oms_cluster_ecs_<node-ID>
These ECSs have the migration plug-in installed and are used to schedule and perform migration tasks.
NAT gateway
Yes
No
oms_cluster_nat_<cluster-ID>
This NAT gateway enables list and migration nodes to communicate with migration sources over the public network, so that source data can be migrated.
LTS
Yes
No
Host group name: oms_lts_host_group_<cluster-ID>
LTS is used to save and search for logs of the migration cluster.
If Log Collection is not enabled during cluster creation, these LTS resources will not be created.
Host group name: oms_lts_host_group_label_<cluster-ID>
Log group name: oms_lts_log_group_<cluster-ID>
Log stream name: oms_lts_stream_group_<cluster-ID>
Log access name: oms_lts_access_config_<cluster-ID>
VPC endpoint service
No
Yes
<region-name>.oms-cluster.<service-ID>
This VPC endpoint service allows OMS to communicate with the master node in the migration cluster to manage migration tasks.
For details, see VPC Endpoint Service Configuration.
Security groups
No
Yes
2
oms_cluster_sg_master_<cluster-ID>
This is the security group of the master node in the migration cluster. It enables the communication between OMS and the migration cluster.
For details about the security group settings, see Security Group Settings for the Master Node.
oms_cluster_sg_agent_<cluster-ID>
This is the security group of the list and migration nodes in the migration cluster. It enables communication between nodes in the migration cluster.
For details about the security group settings, see Security Group Settings for List and Migration Nodes.
Item
Configuration
VPC
The VPC where the migration cluster works is selected.
Service Type
Interface
Connection Approval
Yes
VPC endpoints need to be approved before they can connect to this endpoint service.
Port Mapping
Ports 22 and 9002 are mapped.
They are used for plugin installation, task delivery, and task management.
Backend Resource Type
ECS
The ECS used as the master node.
Connection Management
The VPC endpoint of OMS is allowed to access this VPC endpoint service.
Allows OMS to communicate with the master node in the migration cluster.
Permission Management
OMS is added to the whitelist.
Allows access from the VPC endpoint of OMS.
Direction
Priority
Action
Type
Protocol & Port
Source or Destination
Inbound
Allow
IPv4
All
Security group of the master node
Allows VMs in the security group to communicate with each other.
Inbound
Allow
IPv4
TCP: 9002
198.19.128.0/17
Allows OMS to communicate with the master node to deliver and manage tasks.
Inbound
Allow
IPv4
TCP: 9005
198.19.128.0/17
Allows the master node to be installed, deployed, and upgraded.
Inbound
Allow
IPv4
All
The security group of the list and migration nodes
Allows the list and migration nodes to communicate with the master node.
Outbound
Allow
IPv4
All
0.0.0.0/0
Allows outbound traffic to communicate with the migration source.
Outbound
Allow
IPv4
All
Direction
Priority
Action
Type
Protocol & Port
Inbound
Allow
IPv4
All
Inbound
Allow
IPv4
All
Outbound
Allow
IPv4
All
0.0.0.0/0
Outbound
Allow
IPv4
All
