Updated on 2026-05-22 GMT+08:00
Importing RVTools Data
This section describes how to import RVTools data to MgC to obtain the server resource list.
Notes and Constraints
  • File format
    The file must be in XLSX format.
  • File size and compression ratio
    The file to be imported cannot be larger than 50 MB, and the compression ratio cannot be lower than 5%.
  • Required headers and fields
    Table 1 Required table headers and fields
    vInfo
    vDisk
    VM
    Capacity MiB
    OS according to the configuration file
    VM UUID
    CPUs
    Raw
    Memory
    VM UUID
    Firmware
Step 1: Exporting RVTools Data
  1. Start the RVTools application.
  2. On the login page, enter the following information:
    • In the IP address/Name text box, enter the IP address of the vCenter server.
    • In the User name text box, enter the username for connecting to the vCenter server.
    • In the Password text box, enter the password corresponding to the username.
  3. Click Login. In the top menu bar, choose File > Export all to Excel.
  4. Select a path for saving the file that contains details about your resources.
Step 2: Importing RVTools Data
  1. Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
  2. In the navigation pane, click Resource Survey.
  3. Click the Import tab. Then click the Import card.
    Figure 1 Import
  4. Choose Import RVTools data. In the File drop-down list, select the file exported from RVTools, and click Confirm.
    If you are using this function for the first time, the Authorization Required dialog box will appear. Click OK to grant agency-based authorization.
  5. After the upload is successful, check the task status in the list.
    • If the task status is Succeeded, you can view the imported resource details and resource statistics.
    • If the task fails, click the task name to view the data source that failed to be collected. Hover over the collection status to view the failure cause. For details about how to rectify common failure causes, see What Can I Do If Importing RVTools Data Fails? After fixing the issue, import the file again.
Viewing Resource Details
When the status of the RVTools import task changes to Succeeded, go to the Resource List page and check the imported resource information in the server list. You can click a server name to check the server details.
Viewing Resource Statistics
If the status of the RVTools import task is Succeeded, you can check the VMware resource statistics.
  • Hosts: CPU models, host quantity, total memory, allocated VM memory, memory allocation rate, VM quantity, quantity of running VMs, storage usage, and the host list
  • VMs: counts of Windows OS versions and Linux OS distributions, total memory, vCPU quantity, disk quantity and size, VM quantity, and the VM list
  1. On the Resource List page, click VMware Resources in the upper right corner.
    Figure 2 Checking VMware resources
  2. On the displayed Resource Statistics page, under VMware Resources, click the Host or VM tab to check resource data.
