Managing Projects
Overview
You can create a project to segregate and manage your migration resources. Two types of projects are available for different migration cases.
- Application migration: This type of projects applies to discovery and migration of server and storage resources.
- Big data migration: This type of projects applies to big data migration and consistency verification.
Creating a Project
Create a project of the corresponding type based on the migration scenario. Projects for application migration differ from those for big data migration in their features.
- Sign in to the MgC console.
- In the navigation pane on the left, choose Other > Settings.
- Under Migration Projects, click Create Project.
Figure 1 Creating a project
- In the Create Project dialog box, set Project Type to Application migration.
The project type cannot be changed after the project is created.
Figure 2 Setting the project type to application migration - Enter a project name and click Create. After the project is created, you can view it in the project list.
Figure 3 Creating a project
- In the Create Project dialog box, set Project Type to Big data migration.
Figure 4 Setting the project type to big data migration - Enter a project name and click Create. After the project is created, you can view it in the project list.
Modifying a Migration Project
- Locate the project and click Modify in the Operation column.
- In the displayed dialog box, modify the project name, project description, start time, and end time, and click Confirm.
Archiving a Migration Project
Archived projects will not be displayed in the project drop-down list in the left corner of the page. To archive a project, locate it and click Archive in the Operation column. To display an archived project in the drop-down list again, you need to unarchive it first.
The project currently in use cannot be archived.
