Creating a Keyword List
If the speech recognition result of some business-specific words is below expectations, you can use the keyword management feature. Adding these words to a keyword list will improve recognition accuracy and enhance user experience of virtual avatar interaction.
- Log in to the MetaStudio console and go to the Overview page.
- Click Go to MetaStudio Console to go to the MetaStudio console.
- In the navigation pane, choose Assets > My Creations.
- Choose Intelligent Interaction > Keywords and click Create Keyword List on the upper right corner of the page, as shown in Figure 1.
Configure parameters by referring to Table 1.
Table 1 Creating a keyword list Parameter
List Name
Enter the keyword list name.
Language
Select the language of the keyword list: Chinese, English, Arabic, Portuguese, Spanish, or Thai.
ASR
ASR service to use. Currently, AI Ask is available.
Keyword
Enter a keyword, which can contain letters, spaces, digits, - (hyphens), | (vertical bars), and () (parentheses).
You can enter a keyword in either of the following format: MetaStudio or HUAWEI(HUA WEI|WHILE WE). In the second example, the word to the left of the parenthesis is the target word for correction. The words inside the parenthesis, separated by vertical bars (|), are the alternative pronunciations or common misrecognitions that the system will automatically convert to the target word.
After entering a keyword, press Enter to enter the next one. A keyword table can contain a maximum of 100 keywords, with no more than 256 characters for each keyword.
- Click OK. A new keyword list will appear on the page.
You can perform the following operations on the added keyword table:
- Click Edit in the Operation column of the keyword list. In the dialog box displayed, modify the keyword list configuration.
- Click Delete in the Operation column of the keyword list. In the dialog box displayed, click OK to delete the keyword table.
Note: If a keyword table has been configured in an intelligent interaction dialog project, the keyword table cannot be deleted or its language cannot be changed.
