Help Center/ MetaStudio/ User Guide/ Data Analysis
Updated on 2025-08-25 GMT+08:00
Data Analysis
You can view the number of created virtual avatars, number of voice model training tasks, and number and duration of composited videos, as well as the corresponding trend charts.
  • By default, Data Analysis is not displayed. You need to submit a service ticket to apply for the permission to use it.
  • You can view only historical data of the previous day and earlier.
  • An IAM user can log in as an IAM user or a federated user. If an IAM user logs in with both roles simultaneously, only the IAM username is displayed in the IAM User drop-down list box when the master account is used for login. The federated username of the current user and the data generated after the federated username-based login cannot be viewed, but other data can.
  1. Log in to the MetaStudio console and go to the Overview page.
  2. In the navigation pane on the left, choose Data Analysis to go to the Data Analysis page, as shown in Figure 1.
    For details, see Table 1.
    Figure 1 Data analysis
    Table 1 About the Data Analysis page
    Area
    IAM User
    This parameter is available only when the master account is used for login.
    • If IAM User Isolation is enabled and you log in using the master account, you can view data of all IAM users or filter to view data of a specific IAM user. If you log in as an IAM user, you can view only the data of this IAM user.
    • If IAM User Isolation is disabled and you log in using both the master account and IAM account, you can view data of all IAM users.
    Note: An IAM user can log in as an IAM user or a federated user. If an IAM user logs in with both roles simultaneously, only the IAM username is displayed in the IAM User drop-down list box when the master account is used for login. The federated username of the current user and the data generated after the federated username-based login cannot be viewed, but other data can.
    Models with Training Completed
    You can view the number of created virtual avatar models and that of voice models.
    The created, unactivated, activated, and frozen model assets, as well as those moved to the recycle bin, are counted.
    Video Production Statistics
    You can view the number and duration of composited videos.
    You can click the Composited videos or Composited video duration (min) area to view the daily statistics in the trend chart below.
    The trend chart shows the number and duration of composited videos of the standard and Flexus editions, respectively.
    Note: You can view only historical data of the previous day and earlier.
