Help Center/ MetaStudio/ User Guide/ Service Overview
Updated on 2025-08-25 GMT+08:00
Service Overview
Access the MetaStudio console and select Overview to go to the page shown in Figure 1.
Figure 1 Service overview page
The MetaStudio service overview page consists of three areas:
Overview
You can see the introduction to MetaStudio on top of the page and perform the following operations:
  • Click Go to MetaStudio Console to perform operations such as voice modeling, image modeling, video production, and livestreaming.
  • Click Buy Resource to go to the page for buying resources. You can select Region, Service, Product, and Billing Mode. For details about the billing of each product, see Billing Overview.
My Resources
In the My Resources area, you can view the remaining resource details, as shown in Table 1. You can also click My Resources in the navigation pane to view the remaining resource list.
If a billing item supports pay-per-use billing, you can enable or disable pay-per-use billing:
  • Enabling pay-per-use billing: Click Enable Pay-per-Use in the resource card. In the dialog box displayed, agree to the agreement. Click OK.
  • Disabling pay-per-use billing: Click Disable in the resource card. In the dialog box displayed, click OK.
Table 1 My resources
Resource Category
Resource
Virtual avatar
Virtual avatar image modeling
The lower left of the card shows the remaining resource quantity. You can click to view the remaining resource quantity details.
Virtual avatar voice modeling
Virtual avatar video production
You can enable or disable pay-per-use billing for virtual avatar video production.
Virtual avatar livestreaming
This card appears only when the administrator has allocated livestream resources to you and the remaining resource quantity is not 0.
The lower left of the card shows the number of remaining livestreams available.
You can enable or disable pay-per-use billing for virtual avatar livestreaming.
Virtual avatar intelligent interaction
This card appears only when:
  • you have submitted a service ticket for enabling virtual avatar intelligent interaction;
  • the administrator has allocated intelligent interaction resources to you and the remaining resource quantity is not 0.
The lower left of the card shows the number of remaining dialogs available.
