Monitoring Hard Terminals
Monitoring Devices
Details about all hard terminals of your enterprise are displayed under .
Managing Configurations
You can add a configuration file to centrally configure the basic details about hard terminals and IdeaHubs.
- In the navigation pane, choose .
- Click the Batch Configuration tab, enter the configuration details, and click Batch application.
Key parameters:
Device Range
- Devices in a group: The configuration file takes effect only for hard terminals in the specified group.
You can choose to add or edit device groups.
- Ungrouped devices: The configuration file takes effect only for hard terminals that are not grouped.
- All devices: The configuration file takes effect for all hard terminals of the enterprise.
Email Address/Mailbox Username/Email Password
These parameters are used to send whiteboard minutes.
