Events Supported by Event Monitoring
Source |
Name |
Severity |
Description |
Solution |
Impact |
MAS |
Abnormal database |
Critical |
Abnormal relational database is detected by the MAS MySQL/Oracle/PostgreSQL monitor. |
On the MAS console, click Multi-Active Instances, select an instance, check event MySQL/Oracle/PostgreSQL details, and rectify the faults. |
Data in the relational database may be lost. |
MAS |
Database recovered |
Major |
The relational database is recovered, detected by the MySQL/Oracle/PostgreSQL monitor. |
None |
None |
MAS |
Abnormal Redis database |
Critical |
Abnormal Redis database is detected by the MAS Redis monitor. |
On the MAS console, click Multi-Active Instances, select an instance, check Redis event details, and rectify the faults. |
Data in the Redis database may be lost. |
MAS |
Redis database recovered |
Major |
The Redis database is recovered. |
None |
None |
MAS |
Abnormal MongoDB database |
Critical |
Abnormal MongoDB database is detected by the MAS MongoDB monitor. |
On the MAS console, click Multi-Active Instances, select an instance, check MongoDB event details, and rectify the faults. |
Data in the MongoDB database may be lost. |
MAS |
MongoDB database recovered |
Major |
The MongoDB database is recovered. |
None |
None |
MAS |
Abnormal Elasticsearch |
Critical |
Abnormal Elasticsearch database is detected by the MAS Elasticsearch monitor. |
On the MAS console, click Multi-Active Instances, select an instance, check Elasticsearch event details, and rectify the faults. |
The Elasticsearch instance may be unavailable. |
MAS |
Elasticsearch database recovered |
Major |
The Elasticsearch database is recovered. |
None |
None |
MAS |
Abnormal API |
Critical |
Abnormal API or unexpected response code is detected by the MAS API monitor. |
On the MAS console, click Multi-Active Instances, select an instance, check API event details, and rectify the faults. |
API data in the database may be lost. |
MAS |
API recovered |
Major |
The API is recovered. |
None |
None |
MAS |
Area status changed |
Major |
Area status changes are detected by MAS. |
On the MAS console, click Multi-Active Instances, select an instance, check multi-active area event details, and rectify the faults. |
Network of the multi-active areas may change. |
