- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Getting Started with MAS
- Modules
- Namespace
- Multi-Active Instances
- Application Management
- Monitor Management
- Credential Management
- Event Monitoring
- Audit Logs
- Permissions Management
MAS FAQs
- Is MAS a Product or Solution?
- Does MAS Synchronize Data in Addition to Controlling Access from Applications to Databases?
- Is MAS Like a Management Channel for Which I Need to Configure Automatic Switchover Policies?
- What Is the Automatic Switchover Mechanism? How Does MAS Implement Switchovers in Seconds?
Multi-Active DR Solution FAQs
- In the Single- or Dual-Instance Data Layer Architecture (Same Region, Multi-AZ, Traffic Distribution with API Gateway), Which Components Are Provided by MAS and Which Ones Should I Prepare?
- Can I Implement the Active-Active Solution on Any Other Services in Addition to Self-Built Cloud Services?
- How Do I Implement Database Dual-Write?
- Does the Multi-Active Architecture Have Any Requirements on My Services?
- What Are the RPO and RTO of the Multi-Active DR Solution?
- Does the Multi-Active DR Solution Have Any Network Requirements? Will Incorrect Switchover Occur If the Network is Unstable or Jitters?
- How Do I Configure Monitoring for Multi-AZ Deployment in the Same Region?
- Will MAS and API Gateway Be Deployed on Both Huawei Cloud and Our Cloud?
- MAS Usage FAQs
MAS FAQs
Help Center/
Multi-Site High Availability Service/
User Guide/
Event Monitoring/
Viewing Event Monitoring Graphs
This section describes how to view the event monitoring data.
- Choose Service List > Cloud Eye.
- In the navigation pane on the left, click Event Monitoring.
- On the displayed page, all system and custom events of the last 24 hours are displayed by default.
- Locate the target event and click View Graph in the Operation column to view its graph.
Parent topic: Event Monitoring
