Updated on 2025-07-23 GMT+08:00
Modules
Introduction
This section describes how to manage the edition and features of your instance. The following features are supported:
  • MySQL
  • Oracle
  • PostgreSQL
  • Redis
  • MongoDB
  • Elasticsearch
  • openGauss
  • API
  • Enable corresponding features before you create data sources and monitors.
  • If a feature is not enabled here, you cannot create or check the corresponding monitor on the instance details page.
Enabling a Module
  1. Go to the Buy Module page.
  2. Select an edition and features, and click OK.
    Table 1 Module parameters
    Edition
    You can choose Intra-city multi-active or Remote multi-active.
    Features
    Options:
    • MySQL
    • Oracle
    • PostgreSQL
    • Redis
    • MongoDB
    • Elasticsearch
    • openGauss
    • API
    Billing Mode
    Billing mode of the function module. Pay-per-use is selected by default.
Modifying a Module
  1. On the MAS console, click Overview and click Modify next to a function module.
  2. Select or deselect the target features, and click OK.
    If a feature has dependent instances and data sources, you cannot delete it by deselecting it.
Deleting a Module
  1. On the MAS console, click Overview and click Delete Module next to a function module.
  2. Click OK to delete the module.
    • The enabled features with the selected edition will also be deleted.
    • If a function module has dependent instances and data sources, it cannot be deleted.
