MongoDB Monitoring
Updated on 2024-12-13 GMT+08:00
Introduction
A MongoDB monitor detects your database status, and automatically triggers traffic switching when the database is abnormal.
Table 1 Monitoring status description
Monitoring Status
Green
The monitoring is normal.
Red
The monitoring is abnormal. Traffic switchover is automatically triggered (if enabled) when the status changes from normal to failed.
Yellow
The monitor initialization failed. The initial detection fails when the monitor starts. In this case, confirm the configurations or contact O&M personnel.
Light gray
Monitor creation or configuration failed.
Dark gray
Invocation failed. The ETCD connection status is abnormal.
Creating a MongoDB Monitor
  1. Log in to the MAS console. On the Multi-Active Instances page, click an instance whose namespace type is Intra-city multi-active.
  2. Click the Monitor List tab, and click Create Monitor.
  3. Configure the basic information, then click Next: Data Centers.
    Figure 1 Basic information configurations
    Table 2 Basic information parameters
    Monitor
    Select MongoDB Monitoring.
    Application
    Select the application.
    Monitor Name
    Customize the monitor name.
    Exception Notification
    By default, this option is disabled.
    If it is enabled,
    • monitor and database exceptions will be sent to you in a timely manner with the Huawei Cloud SMN service. Configure a secret key first.
    • Cloud Eye is enabled by default. Ensure that the alarm rules for MAS have been created on the Cloud Eye console. For details, see Creating an Alarm Rule to Monitor an Event.
    Subject
    If Exception Notification is enabled, select a subject from the drop-down list or click Add to create a new one.
    Monitoring
    The default value is Yes. If No, database exceptions will not be monitored.
    Automatic Switchover
    The default value is Yes. If No, automatic switchover of the databases will not be triggered.
    Username
    Enter the username for logging in to the database.
    Password
    Enter the password for logging in to the database.
    Confirm Password
    Enter the password again.
  4. Configure the information, then click Next: Databases.
    Figure 2 Data center configurations
    Table 3 Data center parameters
    Cloud
    The environment where the monitored MongoDB database is deployed
    Region
    The region where the monitored database is located
    Connection Address
    The IP address and port number for accessing the MongoDB database
  5. Configure the databases, then click Next: Advanced.
    Figure 3 Database configurations
    Table 4 Database parameters
    Monitored Database
    Enter the monitored database name.
    Connected Database
    Enter the connected database name.
    CAUTION:
    The names of the Monitored Database and Connected Database should be the same, and the specified database must exist in the monitored data source.
  6. Configure the advanced settings, then click Next: Confirm.
    Figure 4 Advanced configurations
    Table 5 Advanced settings
    Retry Interval (ms)
    The interval of reconnection attempts, in milliseconds. Default value (recommended): 3000
    Value range: 1 to 300,000
    Monitoring Timeout (ms)
    The timeout duration before a monitor becomes abnormal, in milliseconds.
    Default value (recommended): 40,000; Value range: 1 to 600,000
    Ensure that the time you specify here is longer than the time required for data center 1 to synchronize data to data center 2. Otherwise, the data in data center 2 may be incomplete.
    Database Access Timeout (ms)
    The database access timeout duration, over which the database access is considered failed, in milliseconds. Default value (recommended): 3000
    Value range: 3000 to 100,000
  7. Confirm settings and click Create.
    If the created monitor is not normal, that is, its indicator is not green, its configurations or databases may be abnormal. In this case, rectify the fault.
Connection pool parameters
  1. Log in to the MAS console. On the Multi-Active Instances page, click an instance to go to its console.
  2. Click the Monitor List tab and choose More > Configure Connection Pool in the row that contains the target monitor.
  3. Set the configurations and click OK.
    Figure 5 Connection pool configurations
    Table 6 Connection pool parameters
    Database Name
    Enter the name of the connected MongoDB database.
    Routing Algorithm
    Options: Single read/write and Single write, local read
    AZs
    Set this parameter for data centers 1 and 2 based on the AZs where the MongoDB databases are deployed.
    Data Source
    Customize a name for the data source.
    Database Address
    Connection address of the MongoDB database
    Schema
    Name of the schema to be connected
