ELB Dashboard Templates (Dedicated)
ELB automatically distributes incoming traffic across multiple backend servers based on configured routing rules. It expands the external service capabilities of applications through traffic distribution and improves application availability by eliminating SPOFs. ELB allows you to view and analyze detailed access logs of HTTP and HTTPS requests for layer-7 load balancing, including request time, client IP addresses, request paths, and server responses.
ELB dashboard templates support Viewing ELB Layer-7 Access Center, Viewing ELB Layer-7 Monitoring Center, and Viewing ELB Layer-7 Monitoring by Second.
- upstream_addr_priv (applicable to shared load balancers) indicates the IP address and port number of the backend host. There may be multiple values separated by commas and spaces, and each value is in the format of {IP address}:{Port number} or -.
- upstream_addr (applicable to dedicated load balancers) indicates the IP address and port number of the backend host. There may be multiple values separated by commas and spaces, and each value is in the format of {IP address}:{Port number} or -.
For more information, see Load Balancer Types.
- Logs have been collected from ELB. For details, see Ingesting ELB Logs to LTS.
- Logs have been structured. For details, see Setting Cloud Structuring Parsing.
- Log in to the LTS console.
- In the navigation pane, choose Log Management.
- In the Log Applications area, click ELB Log Center and choose Access Dashboard.
- In the dashboard list, choose ELB Dashboard Templates (Dedicated) under Dashboard Templates and click ELB Layer-7 Access Center to view the detailed charts. Figure 1 ELB Layer-7 Access Center
- Filter by load balancer. The associated query and analysis statement is:
* | SELECT distinct(lb_name)
- Filter by client IP address. The associated query and analysis statement is:
* | SELECT distinct(remote_addr)
- Filter by backend server IP address. The associated query and analysis statement is:
* | SELECT distinct(upstream_addr)
- Filter by EIP. The associated query and analysis statement is:
* | SELECT distinct(eip_address)
Select a time range at the top of the page.A relative time range of at least 30 minutes is recommended. The system filters data based on the log reporting time. Due to the latency between the service time (the time_iso8601 field) and the log reporting time, data points at the boundaries of a line chart sorted by service time may be incomplete and should not be used as a primary reference.
- From now: queries log data generated in a time range that ends with the current time, such as the previous 1, 5, or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from now, the charts on the dashboard display the log data that is generated from 18:20:31 to 19:20:31.
- From last: queries log data generated in a time range that ends with the current time, such as the previous 1 or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from last, the charts on the dashboard display the log data that is generated from 18:00:00 to 19:00:00.
- Specified: queries log data that is generated in a specified time range.
- Day-over-day PV Change. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 86400) as diff from (select count(1) as "pv" from log))
- Week-on-week PV Change. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 604800) as diff from (select count(1) as "pv" from log))
- Day-over-day UV Change. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 86400) as diff from (select APPROX_COUNT_DISTINCT(remote_addr) as "uv" from log))
- Week-on-week UV Change. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 604800) as diff from (select APPROX_COUNT_DISTINCT(remote_addr) as "uv" from log))
- PV Distribution (China). The associated query and analysis statement is:
* | SELECT ip_to_province(remote_addr) as province, count(1) as pv where IP_TO_COUNTRY (remote_addr) = 'China' group by province HAVING province not in ('','Reserved address','*') - PV Distribution (Global). The associated query and analysis statement is:
* | SELECT ip_to_country(remote_addr) as country,COUNT(1) as PV GROUP BY country HAVING country not in ('','Reserved address','*') - UV Distribution (China). The associated query and analysis statement is:
* | SELECT ip_to_province(remote_addr) as province, APPROX_COUNT_DISTINCT(remote_addr) as uv where IP_TO_COUNTRY (remote_addr) = 'China' group by province HAVING province not in ('','Reserved address','*') - UV Distribution (Global). The associated query and analysis statement is:
* | SELECT ip_to_country(remote_addr) as country, APPROX_COUNT_DISTINCT(remote_addr) as uv group by country HAVING country not in ('','Reserved address','*') - Average Latency Distribution (China). The associated query and analysis statement is:
* | SELECT province,round( CASE WHEN "Average latency (ms)" > 0 THEN "Average latency (ms)" ELSE 0 END, 3 ) AS "Average latency (ms)"FROM (SELECT ip_to_province(remote_addr) as province,avg(request_time) * 1000 AS "Average latency (ms)"WHERE IP_TO_COUNTRY (remote_addr) = 'China'GROUP BY province HAVING province not in ('','Reserved address','*')) - Average Latency Distribution (Global). The associated query and analysis statement is:
* | SELECT country,round( CASE WHEN "Average latency (ms)" > 0 THEN "Average latency (ms)" ELSE 0 END, 2 ) AS "Average latency (ms)"FROM (SELECT ip_to_country(remote_addr) as country,avg(request_time) * 1000 AS "Average latency (ms)" GROUP BY country HAVING country not in ('','Reserved address','*')) - PV/UV Today. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') AS _time_ , count(1) as PV, APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ') <= CURRENT_TIMESTAMP and TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ') >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR group by _time_ order by _time_)
- PV/UV in 7 Days. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') AS _time_ , count(1) as PV, APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ') <= CURRENT_TIMESTAMP and TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ') >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR - INTERVAL '7' DAY group by _time_ order by _time_ )
- Top 10 Provinces by Visits. The associated query and analysis statement is:
* | SELECT ip_to_province(remote_addr) as "province", count(1) as "Visits" group by "province" HAVING "province" <> '-1' order by "Visits" desc limit 10
- Top 10 Cities by Visits. The associated query and analysis statement is:
* | SELECT ip_to_city(remote_addr) as "city", count(1) as "Visits" group by "city" HAVING "city" <> '-1' order by "Visits" desc limit 10
- Top 10 Hosts by Visits. The associated query and analysis statement is:
* | SELECT host as "Host", count(1) as "PV" group by "Host" order by "PV" desc limit 10
- Top 10 UserAgents by Visits. The associated query and analysis statement is:
* | SELECT http_user_agent as "UserAgent", count(1) as "PV" group by "UserAgent" order by "PV" desc limit 10
- Device Distribution by Type. The associated query and analysis statement is:
* | SELECT case when regexp_like(lower(http_user_agent), 'iphone|ipod|android|ios') then 'Mobile' else 'PC' end as type , count(1) as total group by type
- Device Distribution by System. The associated query and analysis statement is:
* | SELECT case when regexp_like(lower(http_user_agent), 'iphone|ipod|ios') then 'IOS' when regexp_like(lower(http_user_agent), 'android') then 'Android' else 'other' end as type , count(1) as total group by type HAVING type != 'other'
- TOP URL. The associated query and analysis statement is:
* | SELECT CASE WHEN STRPOS(router_request_uri, '?')!=0 THEN LPAD(router_request_uri, CAST(STRPOS(router_request_uri, '?') as INTEGER)-1, '?') ELSE router_request_uri END as "router_request_uri" , count(1) as pv, APPROX_COUNT_DISTINCT(remote_addr) as uv, round(sum( case when status < 400 then 1 else 0 end ) * 100.0 / count(1), 2) as "Access Success Rate" group by "router_request_uri" ORDER by pv desc
- Top IP Addresses by Visits. The associated query and analysis statement is:
* | SELECT remote_addr as "Source IP Address",ip_to_country(remote_addr) as "Country/Region",ip_to_province(remote_addr) as "Province",ip_to_city(remote_addr) as "City",ip_to_provider(remote_addr) as "Carrier",count(1) as "PV",http_user_agent as "UserAgent Sampling",CASE WHEN STRPOS(router_request_uri, '?')!=0 THEN LPAD(router_request_uri, CAST(STRPOS(router_request_uri, '?') as INTEGER)-1, '?') ELSE router_request_uri END as "URL Sampling" group by remote_addr,http_user_agent,"URL Sampling" ORDER by "PV" desc
- In the dashboard list, choose ELB Dashboard Templates (Dedicated) under Dashboard Templates and click ELB Layer-7 Monitoring Center to view the detailed charts. Figure 2 ELB Layer-7 Monitoring Center
- PV. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV FROM (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') AS _time_ , count(1) as PV from log group by _time_ order by _time_ ) order by _time_
- Request Success Rate. The associated query and analysis statement is:
* | SELECT ROUND(sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1),2) as cnt
- 4xx Requests. The associated query and analysis statement is:
* | SELECT COUNT(1) as cnt WHERE "status" >= 400 and "status" < 500
- 499 Requests. The associated query and analysis statement is:
* | SELECT COUNT(1) as cnt WHERE "status" = 499
- Average Latency. The associated query and analysis statement is:
* | SELECT round(avg(request_time) * 1000, 3) as cnt
- 404 Requests. The associated query and analysis statement is:
* | SELECT COUNT(1) as cnt WHERE "status" = 404
- 504 Requests. The associated query and analysis statement is:
* | SELECT COUNT(1) as cnt WHERE "status" = 504
- 5xx Requests. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,cnt FROM ( SELECT TIME_CEIL ( TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT300S' ) AS _time_, count( 1 ) AS cnt FROM log where "status" >= 500 GROUP BY _time_ ) order by _time_
- Status Code Distribution. The associated query and analysis statement is:
* | SELECT status, COUNT(1) AS rm GROUP BY status
- UV. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,UV FROM (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') AS _time_ , APPROX_COUNT_DISTINCT(remote_addr) as UV from log group by _time_) order by _time_
- Traffic. The associated query and analysis statement is:
* | SELECT TIME_FORMAT(_time_,'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_,round( CASE WHEN "Inbound" > 0 THEN "Inbound" ELSE 0 END, 2 ) AS "Inbound",round( CASE WHEN "Outbound" > 0 THEN "Outbound" ELSE 0 END, 2 ) AS "Outbound" FROM (SELECT TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') AS _time_,sum(request_length) / 1024.0 AS "Inbound",sum(bytes_sent) / 1024.0 AS "Outbound" group by _time_) order by _time_
- Access Failure Rate. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "Failure rate" > 0 THEN "Failure rate" ELSE 0 END, 2 ) AS "Failure rate",round( CASE WHEN "5XX" > 0 THEN "5XX" ELSE 0 END, 2 ) AS "5XX" from (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') AS _time_,sum(case when status >= 400 then 1 else 0 end) * 100.0 / count(1) as 'Failure rate' , sum(case when status >=500 THEN 1 ELSE 0 END)*100.0/COUNT(1) as '5XX' group by _time_) order by _time_
- Latency. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "Avg." > 0 THEN "Avg." ELSE 0 END, 2 ) AS "Avg.",round( CASE WHEN "P50" > 0 THEN "P50" ELSE 0 END, 2 ) AS "P50",round( CASE WHEN "P90" > 0 THEN "P90" ELSE 0 END, 2 ) AS "P90",round( CASE WHEN "P99" > 0 THEN "P99" ELSE 0 END, 2 ) AS "P99",round( CASE WHEN "P9999" > 0 THEN "P9999" ELSE 0 END, 2 ) AS "P9999" from (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT600S') as _time_,avg(request_time) * 1000 as "Avg.", APPROX_QUANTILE_DS("request_time", 0.50)*1000 as "P50", APPROX_QUANTILE_DS("request_time", 0.90)*1000 as "P90" ,APPROX_QUANTILE_DS("request_time", 0.99)*1000 as 'P99',APPROX_QUANTILE_DS("request_time", 0.9999)*1000 as 'P9999' group by _time_) order by _time_ - Top Host Requests. The associated query and analysis statement is:
* | SELECT host, pv, uv, round( CASE WHEN "Access Success Rate (%)" > 0 THEN "Access Success Rate (%)" ELSE 0 END, 2 ) AS "Access Success Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "Inbound (KB)" > 0 THEN "Inbound (KB)" ELSE 0 END, 3 ) AS "Inbound (KB)", round( CASE WHEN "Outbound (KB)" > 0 THEN "Outbound (KB)" ELSE 0 END, 3 ) AS "Outbound (KB)" FROM ( SELECT "host", count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( http_x_forwarded_for ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Success Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", sum( request_length ) / 1024.0 AS "Inbound (KB)", sum( body_bytes_sent ) / 1024.0 AS "Outbound (KB)" WHERE "host" != '' GROUP BY "host" ) ORDER BY pv DESC
- Top Host Latencies. The associated query and analysis statement is:
* | SELECT "host", pv, round( CASE WHEN "Access Success Rate (%)" > 0 THEN "Access Success Rate (%)" ELSE 0 END, 2 ) AS "Access Success Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "P90 Latency (ms)" > 0 THEN "P90 Latency (ms)" ELSE 0 END, 3 ) AS "P90 Latency (ms)", round( CASE WHEN "P99 Latency (ms)" > 0 THEN "P99 Latency (ms)" ELSE 0 END, 3 ) AS "P99 Latency (ms)" FROM ( SELECT "host", count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Success Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90 Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99 Latency (ms)" WHERE "host" != '' GROUP BY "host" ) ORDER BY "Average Latency (ms)" desc
- Top Host Failure Rates. The associated query and analysis statement is:
* | SELECT "host", pv,round( CASE WHEN "Access Failure Rate (%)" > 0 THEN "Access Failure Rate (%)" ELSE 0 END, 2 ) AS "Access Failure Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "P90 Latency (ms)" > 0 THEN "P90 Latency (ms)" ELSE 0 END, 3 ) AS "P90 Latency (ms)", round( CASE WHEN "P99 Latency (ms)" > 0 THEN "P99 Latency (ms)" ELSE 0 END, 3 ) AS "P99 Latency (ms)" FROM ( SELECT "host", count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Failure Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90 Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99 Latency (ms)" WHERE "host" != '' GROUP BY "host" ) ORDER BY "Access Failure Rate (%)" desc
- Top URL Requests. The associated query and analysis statement is:
* | SELECT router_request_uri, pv,uv, round( CASE WHEN "Access Success Rate (%)" > 0 THEN "Access Success Rate (%)" ELSE 0 END, 2 ) AS "Access Success Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "Inbound (KB)" > 0 THEN "Inbound (KB)" ELSE 0 END, 3 ) AS "Inbound (KB)", round( CASE WHEN "Outbound (KB)" > 0 THEN "Outbound (KB)" ELSE 0 END, 3 ) AS "Outbound (KB)" FROM ( SELECT CASE WHEN STRPOS(router_request_uri, '?')!=0 THEN LPAD(router_request_uri, CAST(STRPOS(router_request_uri, '?') as INTEGER)-1, '?') ELSE router_request_uri END as "router_request_uri", count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( http_x_forwarded_for ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Success Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", sum( request_length ) / 1024.0 AS "Inbound (KB)", sum( body_bytes_sent ) / 1024.0 AS "Outbound (KB)" WHERE "host" != '' GROUP BY "router_request_uri" ) ORDER BY pv desc
- Top URL Latencies. The associated query and analysis statement is:
* | SELECT router_request_uri, pv,round( CASE WHEN "Access Success Rate (%)" > 0 THEN "Access Success Rate (%)" ELSE 0 END, 2 ) AS "Access Success Rate (%)",round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)",round( CASE WHEN "P90 Latency (ms)" > 0 THEN "P90 Latency (ms)" ELSE 0 END, 3 ) AS "P90 Latency (ms)",round( CASE WHEN "P99 Latency (ms)" > 0 THEN "P99 Latency (ms)" ELSE 0 END, 3 ) AS "P99 Latency (ms)" FROM (SELECT CASE WHEN STRPOS(router_request_uri, '?')!=0 THEN LPAD(router_request_uri, CAST(STRPOS(router_request_uri, '?') as INTEGER)-1, '?') ELSE router_request_uri END as "router_request_uri", count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Success Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90 Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99 Latency (ms)" WHERE "host" != '' GROUP BY "router_request_uri" ) ORDER BY "Average Latency (ms)" desc
- Top URL Failure Rates. The associated query and analysis statement is:
* | SELECT router_request_uri, pv, round( CASE WHEN "Access Failure Rate (%)" > 0 THEN "Access Failure Rate (%)" ELSE 0 END, 2 ) AS "Access Failure Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "P90 Latency (ms)" > 0 THEN "P90 Latency (ms)" ELSE 0 END, 3 ) AS "P90 Latency (ms)", round( CASE WHEN "P99 Latency (ms)" > 0 THEN "P99 Latency (ms)" ELSE 0 END, 3 ) AS "P99 Latency (ms)" FROM( SELECT CASE WHEN STRPOS(router_request_uri, '?')!=0 THEN LPAD(router_request_uri, CAST(STRPOS(router_request_uri, '?') as INTEGER)-1, '?') ELSE router_request_uri END as "router_request_uri", count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Failure Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90 Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99 Latency (ms)" WHERE "host" != '' GROUP BY "router_request_uri") ORDER BY "Access Failure Rate (%)" desc
- Top Backend Requests. The associated query and analysis statement is:
* | SELECT addr, pv, uv, round( CASE WHEN "Access Success Rate (%)" > 0 THEN "Access Success Rate (%)" ELSE 0 END, 2 ) AS "Access Success Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "Inbound (KB)" > 0 THEN "Inbound (KB)" ELSE 0 END, 3 ) AS "Inbound (KB)", round( CASE WHEN "Outbound (KB)" > 0 THEN "Outbound (KB)" ELSE 0 END, 3 ) AS "Outbound (KB)" FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( http_x_forwarded_for ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Success Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", sum( request_length ) / 1024.0 AS "Inbound (KB)", sum( body_bytes_sent ) / 1024.0 AS "Outbound (KB)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2) ORDER BY "pv" desc
- Top Backend Latencies. The associated query and analysis statement is:
* | SELECT addr,pv,round( CASE WHEN "Access Success Rate (%)" > 0 THEN "Access Success Rate (%)" ELSE 0 END, 2 ) AS "Access Success Rate (%)",round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)",round( CASE WHEN "P90 Latency (ms)" > 0 THEN "P90 Latency (ms)" ELSE 0 END, 3 ) AS "P90 Latency (ms)",round( CASE WHEN "P99 Latency (ms)" > 0 THEN "P99 Latency (ms)" ELSE 0 END, 3 ) AS "P99 Latency (ms)" FROM (SELECT upstream_addr as addr,count( 1 ) AS pv,sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Success Rate (%)",avg( request_time ) * 1000 AS "Average Latency (ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90 Latency (ms)",APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99 Latency (ms)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2) ORDER BY "Average Latency (ms)" desc
- Top Backend Failure Rates. The associated query and analysis statement is:
* | SELECT addr, pv, round( CASE WHEN "Access Failure Rate (%)" > 0 THEN "Access Failure Rate (%)" ELSE 0 END, 2 ) AS "Access Failure Rate (%)", round( CASE WHEN "Average Latency (ms)" > 0 THEN "Average Latency (ms)" ELSE 0 END, 3 ) AS "Average Latency (ms)", round( CASE WHEN "P90 Latency (ms)" > 0 THEN "P90 Latency (ms)" ELSE 0 END, 3 ) AS "P90 Latency (ms)", round( CASE WHEN "P99 Latency (ms)" > 0 THEN "P99 Latency (ms)" ELSE 0 END, 3 ) AS "P99 Latency (ms)" FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "Access Failure Rate (%)", avg( request_time ) * 1000 AS "Average Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90 Latency (ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99 Latency (ms)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2) ORDER BY "Access Failure Rate (%)" desc
- Choose ELB Dashboard Templates (Dedicated) under Dashboard Templates and click ELB Layer-7 Monitoring by Second to view the detailed charts. Figure 3 ELB Layer-7 Monitoring by Second
- The QPS chart displays the QPS changes. The associated query and analysis statement is:
* | SELECT TIME_FORMAT(TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT1S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log group by _time_
- The Success Rate chart displays the success rate changes. The associated query and analysis statement is:
* | SELECT __time,round(CASE WHEN "Success rate" > 0 THEN "Success rate" else 0 end,2) as "Success rate" from (select TIME_FORMAT(TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1) as 'Success rate' from log group by __time)
- The Latency chart displays the latency changes. The associated query and analysis statement is:
* | SELECT __time,round(CASE WHEN "Access latency" > 0 THEN "Access latency" else 0 end,2) as "Access latency",round(CASE WHEN "Upstream latency" > 0 THEN "Upstream latency" else 0 end,2) as "Upstream latency" from (select TIME_FORMAT(TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, avg(request_time)* 1000 as 'Access latency',avg(upstream_response_time)* 1000 as 'Upstream latency' from log group by __time)
- The Traffic chart displays the traffic changes. The associated query and analysis statement is:
* | SELECT TIME_FORMAT(__time, 'yyyy-MM-dd HH:mm:ss', '+08:00') AS __time, round(CASE WHEN "Incoming" > 0 THEN "Incoming" ELSE 0 END, 2) AS "Incoming",round(CASE WHEN "Outgoing body" > 0 THEN "Outgoing body" ELSE 0 END, 2) AS "Outgoing body" from (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S') as __time, sum("request_length") / 1024.0 as "Incoming", sum("body_bytes_sent") / 1024.0 as "Outgoing body" group by __time ) - The Status Codes chart displays the changes of status codes. The associated query and analysis statement is:
* | SELECT TIME_FORMAT(t.t, 'yyyy-MM-dd HH:mm:ss', '+08:00') as "time", CASE WHEN a."2XX" IS NOT NULL THEN CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX", CASE WHEN b."3XX" IS NOT NULL THEN CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX", CASE WHEN c."4XX" IS NOT NULL THEN CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX", CASE WHEN d."5XX" IS NOT NULL THEN CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX", CASE WHEN e."Other" IS NOT NULL THEN CAST(e."Other" AS BIGINT) ELSE 0 END as "Other" from ( select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S' ) as t from log group by t order by t asc ) t left join ( select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S' ) as t, CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "status" >= 200 and "status" < 300 group by t order by t asc ) a on t.t = a.t left join ( select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S' ) as t, CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "status" >= 300 and "status" < 400 group by t order by t asc ) b on t.t = b.t left join (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S' ) as t, CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "status" >= 400 and "status" < 500 group by t order by t asc ) c on t.t = c.t left join ( select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S' ) as t, CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "status" >= 500 and "status" < 600 group by t order by t asc) d on t.t = d.t left join ( select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'), 'PT5S' ) as t, CAST(COUNT(1) as VARCHAR) as "Other" from log WHERE "status" < 200 or "status" >= 600 group by t order by t asc ) e on t.t = e.t
- The Backend Response Code chart displays the changes of backend response codes. The associated query and analysis statement is:
* | SELECT TIME_FORMAT(t.t, 'yyyy-MM-dd HH:mm:ss', '+08:00') as "time",CASE WHEN a."2XX" IS NOT NULL THEN CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX",CASE WHEN b."3XX" IS NOT NULL THEN CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX",CASE WHEN c."4XX" IS NOT NULL THEN CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX",CASE WHEN d."5XX" IS NOT NULL THEN CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX",CASE WHEN e."Other" IS NOT NULL THEN CAST(e."Other" AS BIGINT) ELSE 0 END as "Other" from (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S') as t from log group by t order by t asc) t left join(select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "upstream_status" >= 200 and "upstream_status" < 300 group by t order by t asc) a on t.t = a.t left join (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "upstream_status" >= 300 and "upstream_status" < 400 group by t order by t asc) b on t.t =b.t left join (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "upstream_status" >= 400 and "upstream_status" < 500 group by t order by t asc) c on t.t =c.t left join (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "upstream_status" >= 500 and "upstream_status" < 600 group by t order by t asc) d on t.t =d.t left join (select TIME_CEIL(TIME_PARSE(time_iso8601 ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "Other" from log WHERE "upstream_status" < 200 or "upstream_status" >= 600 group by t order by t asc) e on t.t =e.t
