CCE Dashboard Templates
CCE provides highly scalable, high-performance, enterprise-class Kubernetes clusters.
CCE dashboard templates support Viewing CCE Logs: Node Operations, Viewing CCE Logs: Kubernetes Object Operations, Viewing CCE Logs: Kubernetes Event Queries, Viewing CCE Logs: Kubernetes Event Center, Viewing CCE Logs: Aggregation Search, Viewing CCE Logs: Account Operations, and Viewing CCE Log Audit Center.
- Logs have been collected from CCE. For details, see Ingesting CCE Application Logs to LTS.
- Logs have been structured. For details, see Setting Cloud Structuring Parsing.
- Log in to the LTS console.
- In the navigation pane, choose Dashboards.
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Logs: Node Operations to view the detailed charts. Figure 1 CCE Logs: Node Operations
- Filter by node name. The associated query and analysis statement is:
* | SELECT distinct("objectRef.name") - Filter by user. The associated query and analysis statement is:
* | SELECT distinct("user.username") - Filter by status code. The associated query and analysis statement is:
* | SELECT distinct("responseStatus.code") - Filter by operation type. The associated query and analysis statement is:
* | SELECT distinct("verb")
- Node Quantity Trend. The associated query and analysis statement is:
* | SELECT time_series( TIME_PARSE(LEFT(requestReceivedTimestamp, 23),'yyyy-MM-dd''T''HH:mm:ss.SSS'), 'PT1H', 'yyyy-MM-dd HH', '0' ,'+08:00') as "dt", count(DISTINCT("objectRef.name")) as "Nodes" where "objectRef.resource" = 'nodes' and "objectRef.subresource" = 'status' and "verb" in ('update', 'patch') and "user.username" = 'system:node' group by "dt" order by "dt" desc limit 10000 - Non-System User Operation Trend. The associated query and analysis statement is:
* | SELECT time_series( TIME_PARSE(LEFT(requestReceivedTimestamp, 23),'yyyy-MM-dd''T''HH:mm:ss.SSS'), 'PT1H', 'yyyy-MM-dd HH', '0' ,'+08:00') as "dt", count(*) as "Requests", "user.username" where "objectRef.resource" = 'nodes' and "user.username" not in ( 'kube-controller-manager','kube-apiserver-kubelet-client','apiserver') and "user.username" not like 'system:%' and "verb" in ('create','delete','update','patch') group by "dt", "user.username" order by "dt","Requests" desc limit 10000 - create Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'create' group by "Status code" - delete Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'delete' group by "Status code" - patch Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'patch' group by "Status code" - update Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'update' group by "Status code" - Node Blocking/Unblocking Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "requestObject" in ('{"spec":{"unschedulable":false}}','{"spec":{"unschedulable":true}}') group by "Status code" - Label Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" in ('patch','update') and CONTAINS_STRING("requestObject" , 'labels') and CONTAINS_STRING("requestObject" , 'metadata' ) group by "Status code" - Taint Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" in ('patch','update') and "requestObject" = 'taints' group by "Status code" - Eviction Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "objectRef.subresource" = 'eviction' and "objectRef.resource" = 'pods' and "verb" = 'create' group by "Status code" - Node Addition/Deletions. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "objectRef.name" AS "Node", "verb" AS "Operation", "stageTimestamp" AS "Occurred", "user.username" AS "Operator", "responseStatus.code" AS "Status Code" where "objectRef.resource" = 'nodes' and "verb" in ('create','delete') - Taint Operations. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "objectRef.name" AS "Node","requestObject" AS "Taints", "requestReceivedTimestamp" AS "Occurred", "user.username" AS "Operator", "responseStatus.code" AS "Status Code" where "objectRef.resource" = 'nodes' and "verb" = 'patch' and "requestObject" = 'taints'
- Eviction Operations. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "objectRef.name" AS "pod", "sourceIPs" AS "Source IP", "requestReceivedTimestamp" AS "Occurred", "user.username" AS "Operator", "responseStatus.code" AS "Status Code" where "objectRef.resource" = 'pods' and "verb" = 'create' and "objectRef.subresource" = 'eviction'
- Label Operations. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "objectRef.name" AS "Node", "requestObject" AS "Label", "requestReceivedTimestamp" AS "Occurred", "user.username" AS "Operator", "responseStatus.code" AS "Status Code" where "objectRef.resource" = 'nodes' and "verb" = 'patch' and "requestObject" = 'labels'
- Blocking Operations. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "objectRef.name" AS "Node", "requestReceivedTimestamp" AS "Occurred", "user.username" AS "Operator", "responseStatus.code" AS "Status Code" where "verb" = 'patch' and "objectRef.resource" = 'nodes' and CONTAINS_STRING("requestObject",'true') and CONTAINS_STRING("requestObject",'unschedulable') - Unblocking Operations. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "objectRef.name" AS "Node", "requestReceivedTimestamp" AS "Occurred", "user.username" AS "Operator", "responseStatus.code" AS "Status Code" where "verb" = 'patch' and "objectRef.resource" = 'nodes' and "requestObject" not in ('true','taints','unschedulable')
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Logs: Kubernetes Object Operations to view the detailed charts. Figure 2 CCE Logs: Kubernetes Object Operations
- Filter by namespace. The associated query and analysis statement is:
* | SELECT distinct("objectRef.namespace") - Filter by operation type. The associated query and analysis statement is:
* | SELECT distinct("verb") - Filter by status code. The associated query and analysis statement is:
* | SELECT distinct("responseStatus.code") - Filter by resource object. The associated query and analysis statement is:
* | SELECT distinct("objectRef.name") - Filter by resource type. The associated query and analysis statement is:
* | SELECT distinct("objectRef.resource") - Filter by user. The associated query and analysis statement is:
- Major Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(requestReceivedTimestamp, 16),'T',' ') AS "dt", "verb" as "Operation type", count(*) as "count" where "verb" in ('create','delete','update','patch') and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "dt","Operation type" order by "dt" limit 10000 - Non-System User Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(requestReceivedTimestamp, 16),'T',' ') AS "dt", count(*) as "Requests","user.username" WHERE "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','apiserver') and "user.username" not like 'system:%' and "verb" in ('create','delete','update','patch') and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','secrets','pvcs') group by "dt", "user.username" order by "dt" limit 10000 - create Resources. The associated query and analysis statement is:
* | SELECT "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - delete Resources. The associated query and analysis statement is:
* | SELECT "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - update Resources. The associated query and analysis statement is:
* | SELECT "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - patch Resources. The associated query and analysis statement is:
* | SELECT "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - create Users. The associated query and analysis statement is:
* | SELECT "user.username" as "User", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - delete Users. The associated query and analysis statement is:
* | SELECT "user.username" as "User", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - update Users. The associated query and analysis statement is:
* | SELECT "user.username" as "User", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - patch Users. The associated query and analysis statement is:
* | SELECT "user.username" as "User", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - create Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - delete Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - update Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - patch Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - create Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000 - delete Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000 - update Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000 - patch Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "Resource type", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Logs: Kubernetes Event Queries to view the detailed charts. Figure 3 CCE Logs: Kubernetes Event Queries
- Event Level: Select Warning, Normal, or Error.
- Filter by event type. The associated query and analysis statement is:
* | SELECT distinct("name") - Filter by cluster ID. The associated query and analysis statement is:
* | SELECT distinct("cluster_id") - Filter by namespace. The associated query and analysis statement is:
* | SELECT distinct("namespace") - Filter by name. The associated query and analysis statement is:
* | SELECT distinct("resource_name")
- Total Events. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log GROUP BY "_time_" ) order by "_time_"
- Ordinary Events. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Normal' GROUP BY "_time_" ) order by "_time_"
- Warnings. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Warning' GROUP BY "_time_" ) order by "_time_"
- Errors. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Error' GROUP BY "_time_" ) order by "_time_"
- Major Events. The associated query and analysis statement is:
* | SELECT "name",count(1) as 'total' from log group by "name"
- Major Event Statistics. The associated query and analysis statement is:
* | SELECT "type" as "Level", "name" as "Type", count(1) as "Total", "reason" as "Details" from log where "type" != 'Normal' group by "type", "name", "reason" order by "Total" desc
Major Pod Event Statistics. The associated query and analysis statement is:
* | SELECT "type" as "Level", "name" as "Type", count(1) as "Total", "reason" as "Details" from log where "type" != 'Normal' and "resource_kind" = 'Pod' group by "type", "name", "reason" order by "Total" desc
- Latest 100 Events. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time","type" as "Level", "name" as "Type", "reason" as "Details", "namespace" as "Namespace" from log order by __time desc limit 100
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Logs: Kubernetes Event Center to view the detailed charts. Figure 4 CCE Logs: Kubernetes Event Center
- Conntrack Full. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'ConntrackFull' ) )
- Event Sync Error. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NTPIsDown') )
- Insufficient Node PIDs. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name" in ('PIDPressure','NodeHasPIDPressure') ) ) - Insufficient Node FDs. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NodeHasFDPressure') )
- Insufficient Node Disk Space. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NodeHasDiskPressure') )
- Pod OOM. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name" in ('OOMKilling','PodOOMKilling')) ) - DockerHung. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'Failed' and "reason" = 'DockerHung') )
- Node Restart. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NodeRebooted') )
- Pull Image Failed. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'Failed' and "reason" = 'ImagePullBackOff') )
- Node OOM. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name" = 'SystemOOM') )
- Start Pod Failed. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'Failed' and "resource_kind" = 'Pod' and "reason" = 'ImagePullBackOff') )
- Event Distribution. The associated query and analysis statement is:
* | SELECT "type", count(*) as "Events" group by "type"
- Warning Event Trend. The associated query and analysis statement is:
* | SELECT time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "dt",count(1) as "count" from log where "type" = 'Warning' group by "dt" order by "dt"
- Error Event Trend. The associated query and analysis statement is:
* | SELECT time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "dt",count(1) as "count" from log where "type" = 'Error' group by "dt" order by "dt"
- Pod OOM Events. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00') as "Time", "resource_kind" as "Event Target", "name" as "Type", "resource_name" as "Target Name", "reason" as "Details" from log where "name" in ('OOMKilling','PodOOMKilling') order by __time desc limit 100 - Pod Driver Event List. The associated query and analysis statement is:
* | SELECT TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time", "resource_kind" as "Event Target", "name" as "Type", "resource_name" as "Target Name", "reason" as "Details" from log where "name" = 'NodeControllerEviction' order by __time desc limit 100
* | SELECT TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time", "type" as "Level", "resource_kind" as "Event Target", "name" as "Type", "resource_name" as "Target Name", "reason" as "Details" from log where "type" in ('Warning','Error') order by __time desc limit 100
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Logs: Aggregation Search to view the detailed charts. Figure 5 CCE Logs: Aggregation Search
* | SELECT distinct("objectRef.namespace") - Filter by user. The associated query and analysis statement is:
* | SELECT distinct("verb") - Filter by resource object. The associated query and analysis statement is:
* | SELECT distinct("objectRef.resource") - Filter by request URL. The associated query and analysis statement is:
* | SELECT distinct("requestURI") - Filter by userAgent. The associated query and analysis statement is:
* | SELECT distinct("userAgent")
- User Distribution Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "user.username" as "User", count(*) as "count" group by dt, "user.username" order by dt limit 10000
- Namespace Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.namespace" as "Namespace", count(*) as "count" group by dt, "objectRef.namespace" order by dt limit 10000
- Operation Type Trends. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "verb" as "Operation type", count(*) as "count" group by dt, verb order by dt limit 10000
- Status Code Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, cast("responseStatus.code" as varchar) as "Return code", count(*) as "count" group by dt, "Return code" order by dt limit 10000 - Resource Type Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "Operation type", count(*) as "count" group by dt, "objectRef.resource" order by dt limit 10000
- Major Operations. The associated query and analysis statement is:
* | SELECT "auditID" AS "Audit ID", "verb" AS "Operation Type", "requestReceivedTimestamp" AS "Started", "stageTimestamp" AS "Ended", "user.username" AS "Operator", "sourceIPs" AS "Operation Source","userAgent","objectRef.namespace" AS "Namespace", CONCAT(CONCAT("objectRef.resource", '/'), "objectRef.subresource") AS "Operation Object", "objectRef.name" AS "Resource Name", "responseStatus.code" AS "Return Code"
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Logs: Account Operations to view the detailed charts. Figure 6 CCE Logs: Account Operations
- Filter by username. The associated query and analysis statement is:
* | SELECT distinct("user.username") - Filter by namespace. The associated query and analysis statement is:
* | SELECT distinct("objectRef.namespace") - Filter by status code. The associated query and analysis statement is:
- Resources Created. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "verb" = 'create') )
- Resources Modified. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(*) as "total" from log where "verb" in ('update','patch')) ) - Resources Deleted. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(*) as "total" from log where "verb" = 'delete') )
- Affected Namespaces. The associated query and analysis statement is:
* | SELECT case when "objectRef.namespace" is null then '_all__' else "objectRef.namespace" end as ns, count(1) as total group by ns limit 10000
- Deleted Resource. The associated query and analysis statement is:
* | SELECT "objectRef.resource" as "resource", count(1) as "count" where "verb" = 'delete' group by "resource"
- Operation History. The associated query and analysis statement is:
* | SELECT case when "Operation" is null then 'None' else "Operation" end as "Operation", "Time", v from (select concat(CASE WHEN "objectRef.subresource" is null then "objectRef.resource" else "objectRef.subresource" end, '[', verb, ']' ) as "Operation", time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "Time", count(1) as v from log where "verb" in ('create', 'patch', 'update', 'delete') group by "Operation", "Time" order by "Time" desc limit 10000 ) order by "Time" - Resource Operations. The associated query and analysis statement is:
* | SELECT CASE WHEN "objectRef.subresource" is null then "objectRef.resource" else "objectRef.subresource" end as "Resource", verb as "Operation", count(1) as total where "verb" in ('create','update','patch','delete') group by "Resource", "Operation" limit 10000 - Created Resources. The associated query and analysis statement is:
* | SELECT "auditID" as "Event ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "Occurred", "requestURI" as "Resource", "objectRef.name" as "Resource Name", "responseStatus.code" as "Status Code","sourceIPs" as "Source IP", "requestObject" as "Details" where "verb" = 'create' order by __time desc limit 1000 - Modified Resources. The associated query and analysis statement is:
* | SELECT auditID as "Event ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "Occurred","requestURI" as "Resource", "objectRef.name" as "Resource Name", "responseStatus.code" as "Status Code", "sourceIPs" as "Source IP", requestObject as "Details" where "verb" in ('update','patch') order by __time desc limit 1000 - Accessed Resources. The associated query and analysis statement is:
* | SELECT auditID as "Event ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "Occurred", "requestURI" as "Resource", "objectRef.name" as "Resource Name", "responseStatus.code" as "Status Code", "sourceIPs" as "Source IP", requestObject as "Details" where "verb" in ('get','list') order by __time desc limit 1000 - Deleted Resources. The associated query and analysis statement is:
* | SELECT auditID as "Event ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "Occurred", "requestURI" as "Resource", "objectRef.name" as "Resource Name", "responseStatus.code" as "Status Code", "sourceIPs" as "Source IP", requestObject as "Details" where "verb" = 'delete' order by __time desc limit 1000
- Choose CCE Dashboard Templates under Dashboard Templates and click CCE Log Audit Center to view the detailed charts. Figure 7 CCE Log Audit Center
* | SELECT distinct("user.username") - Filter by operation type. The associated query and analysis statement is:
- Total Audit Records. The associated query and analysis statement is:
* | SELECT diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log ) )
- Users. The associated query and analysis statement is:
* | SELECT diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(distinct("user.username")) as total from log ) ) - Active Nodes. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(DISTINCT "user.username") as total from log where "objectRef.resource" = 'nodes' and "objectRef.subresource" = 'status' and "verb" in ('update','put','patch') and "user.username" in ('node','system')) ) - Abnormal Visits. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "responseStatus.code" >= 400) )
- Sensitive Operations. The associated query and analysis statement is:
* | SELECT diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as "total" from log where ("verb" = 'create' AND "objectRef.subresource" = 'exec') OR ("verb" = 'create' AND "objectRef.subresource" = 'attach' AND "objectRef.resource" = 'pods') OR ("objectRef.resource" = 'secrets' AND "verb"= 'get' AND ( "user.username" != 'apiserver') AND ("user.username" not like 'system:node:%')) OR ("verb"= 'delete' AND ( "user.username" not like 'system:node:%') AND ( "user.username" not like 'system:serviceaccount:kube-system:%') AND ( "user.username" != 'system:apiserver') AND ( "user.username" != 'system:apiserver') AND ( "user.username" != 'system:kube-scheduler') AND ("user.username" != 'system:kube-controller-manager'))) ) - Creation Operations. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'create') )
- Update Operations. The associated query and analysis statement is:
* | SELECT diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb in ('update','patch')) ) - Deletion Operations. The associated query and analysis statement is:
* | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'delete') )
* | SELECT "user.username" as "Username", count(*) as "count" group by "Username" order by "count" desc
- Namespaces. The associated query and analysis statement is:
* | SELECT "objectRef.namespace" as "Namespace", count(*) as "count" group by "Namespace"
- Resource Types. The associated query and analysis statement is:
* | SELECT "objectRef.resource" as "Resource type", count(*) as "count" group by "Resource type" order by "count" desc limit 20
- Operation Types. The associated query and analysis statement is:
* | SELECT verb as "Operation type", count(*) as "count" group by "Operation type" order by "count" desc
- Node Operations. The associated query and analysis statement is:
* | SELECT "verb" as "Operation type", count(*) as "count" where "objectRef.resource" = 'nodes' AND ("verb" in ('create','delete') ) group by "Operation type" order by "count" desc - Status Codes. The associated query and analysis statement is:
* | SELECT cast("responseStatus.code" as varchar) as "Status code", count(*) as "count" group by "Status code" order by "count" desc - Workload Operations. The associated query and analysis statement is:
* | SELECT "verb" as "Operation type", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('deployments','statefulsets','daemonsets','jobs','cronjobs') group by "Operation type" order by "count" desc - Service/Ingress Operations. The associated query and analysis statement is:
* | SELECT "verb" as "Operation type", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('ingresses','services') group by "verb" order by "count" desc - Major Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT("stageTimestamp", 13),'T',' ') AS "dt", "verb", count(*) as "count" where "verb" in ('create','delete','update','patch') group by "dt", "verb" order by "dt" limit 10000 - Non-System User Operation Trend. The associated query and analysis statement is:
* | SELECT REPLACE(LEFT("stageTimestamp", 13),'T',' ') AS "dt", count(*) as "count", "user.username" as "Username" where "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','system','apiserver') group by "dt", "Username" order by "dt" limit 10000
