Updated on 2025-07-28 GMT+08:00
Array Functions
This section describes array functions, including their syntax, parameters, and usage examples.
Function List
Table 1 Array functions
Function
array
Constructs the input parameters of the same type into an array.
array_position
Obtains the subscript of a specified element, starting from 1. If the specified element was not found, 0 is returned.
cardinality
Calculates the number of elements in an array.
mv_length
Calculates the number of elements in an array. It is equivalent to the cardinality function.
contains
Determines whether an array contains a specified element. If the array contains the element, true is returned.
mv_contains
Determines whether an array contains a specified element. If the array contains the element, true is returned. This function is equivalent to the contains function.
mv_prepend
Adds a specified element to the beginning of an array.
mv_append
Adds a specified element to the end of an array.
mv_slice
Returns a portion of an array from index start to index end.
mv_to_string
Uses a specified delimiter (str) to join all elements of an array (arr) into a string.
string_to_mv
Uses a specified delimiter (str2) to split a string (str1) into an array.
mv_offset
Returns the array element at the provided 0-based index.
mv_ordinal
Returns the array element at the provided 1-based index.
mv_offset_of
Returns the 0-based index of expr that appears for the first time in an array. If expr does not appear, it returns -1.
mv_ordinal_of
Returns the 1-based index of expr that appears for the first time in an array. If expr does not appear, it returns -1.
array
Constructs the parameters of the same type into an array.
Syntax: array[expr1,expr...]
Table 2 Parameter description
Type
Mandatory
expr
Raw data.
String/Integer/Long/Double/Float
Yes
Return value type: array
Example: SELECT ARRAY['1','2','3','4','5']
Table 3 Query and analysis results
Type
Query Statement
Returned Result
["1", "2", "3", "4", "5"]
array_position
Syntax: array_position(expr, ele)
Table 4 Parameter description
Type
Mandatory
expr
Original array.
Array
Yes
ele
Specified element.
An element in the array. It must be of the same type as the other elements in the array.
Yes
Return value type: integer
Example: SELECT ARRAY_POSITION(ARRAY['1','2','3'],'2')
Table 5 Query and analysis results
Type
Query Statement
Returned Result
2
cardinality
This function calculates the number of elements in an array. The elements must be of the same parameter type.
Syntax: cardinality(expr)
Table 6 Parameter description
Type
Mandatory
expr
Original array.
Array (string/number)
Yes
Example: SELECT CARDINALITY(ARRAY['1','2','3'])
Table 7 Query and analysis results
Type
Query Statement
Returned Result
3
mv_length
This function calculates the number of elements in an array. It is equivalent to the cardinality function.
Syntax: mv_length(expr)
Table 8 Parameter description
Type
Mandatory
expr
Original array.
Yes
Example: SELECT MV_LENGTH(ARRAY['1','2','3'])
Table 9 Query and analysis results
Type
Query Statement
Returned Result
MV_LENGTH (ARRAY['1','2','3'])
3
contains
This function determines whether an array contains a specified element. If the array contains the element, true is returned.
Syntax: contains(expr, ele)
Table 10 Parameter description
Type
Mandatory
expr
Original array.
Yes
ele
Specified element.
String/Number. The type must be the same as that of the element in the array.
Yes
Return value type: Boolean
Example: SELECT CONTAINS(ARRAY['1','2'],'1')
Table 11 Query and analysis results
Type
Query Statement
Returned Result
true
mv_contains
This function determines whether an array contains a specified element. If the array contains the element, true is returned. This function is equivalent to the contains function.
Syntax: mv_contains(expr, ele)
Table 12 Parameter description
Type
Mandatory
expr
Original array.
Yes
ele
Specified element.
Yes
Example: SELECT MV_CONTAINS(ARRAY['1','2'],'1')
Table 13 Query and analysis results
Type
Query Statement
Returned Result
true
mv_prepend
This function adds a specified element to the beginning of an array.
Syntax: mv_prepend(expr, arr)
Table 14 Parameter description
Type
Mandatory
expr
Specified element.
Yes
arr
Original array.
Yes
Example: SELECT MV_PREPEND('1', ARRAY ['1','2'])
Table 15 Query and analysis results
Type
Query Statement
Returned Result
MV_PREPEND ('1', ARRAY['1','2'])
["1","1","2"]
mv_append
This function adds a specified element to the end of an array.
Syntax: mv_append(arr, expr)
Table 16 Parameter description
Type
Mandatory
arr
Original array.
Yes
expr
Specified element.
Yes
Example: SELECT MV_APPEND(ARRAY['1','2'],'1')
Table 17 Query and analysis results
Type
Query Statement
Returned Result
MV_APPEND(ARRAY['1','2'], '1')
["1","2","1"]
mv_slice
This function returns a portion of an array from index start to index end.
Syntax: mv_slice(arr, start, end)
Table 18 Parameter description
Type
Mandatory
arr
Original array.
Yes
start
Start position.
Integer
Yes
end
End position.
Integer
Yes
Example: SELECT MV_SLICE(ARRAY['1','2','3','4','5'], 2, 4)
Table 19 Query and analysis results
Type
Query Statement
Returned Result
["3","4"]
mv_to_string
This function uses a specified delimiter (str) to join all elements of an array (arr) into a string.
Syntax: mv_to_string(arr, str)
Table 20 Parameter description
Type
Mandatory
arr
Original array.
Yes
str
Specified delimiter.
String
Yes
Return value type: string
Example: SELECT MV_TO_STRING(ARRAY['1','2','3','4','5'],'-')
Table 21 Query and analysis results
Type
Query Statement
Returned Result
1-2-3-4-5
string_to_mv
This function uses a specified delimiter (str2) to split a string (str1) into an array.
Syntax: string_to_mv(str1, str2)
Table 22 Parameter description
Type
Mandatory
str1
Original string.
String
Yes
str2
String
Yes
Example: SELECT STRING_TO_MV('1-2-3-4-5','-')
Table 23 Query and analysis results
Type
Query Statement
Returned Result
["1","2","3","4","5"]
mv_offset
This function returns the array element at the provided 0-based index. If the index is out of bounds, it returns null.
Syntax: mv_offset(arr, index)
Table 24 Parameter description
Type
Mandatory
arr
Original array.
Yes
index
Specified index position.
Integer
Yes
Return value type: string/integer/long/Boolean/double
Example: SELECT MV_OFFSET(ARRAY['1','2','3','4','5'], 2)
Table 25 Query and analysis results
Type
Query Statement
Returned Result
3
mv_ordinal
This function returns the array element at the provided 1-based index. If the index is out of bounds, it returns null.
Syntax: mv_ordinal(arr, index)
Table 26 Parameter description
Type
Mandatory
arr
Original array.
Yes
index
Integer
Yes
Return type: string/integer/long/Boolean/double
Example: SELECT MV_ORDINAL(ARRAY['1','2','3','4','5'], 2)
Table 27 Query and analysis results
Type
Query Statement
Returned Result
MV_ORDINAL (ARRAY['1','2','3','4','5'], 2)
2
mv_offset_of
This function returns the 0-based index of expr that appears for the first time in an array. If expr does not appear, it returns -1.
Syntax: mv_offset_of(arr, expr)
Table 28 Parameter description
Type
Mandatory
arr
Original array.
Yes
expr
Specified element.
Yes
Example: SELECT MV_OFFSET_OF(ARRAY['1','2','3','4','5'], '2')
Table 29 Query and analysis results
Type
Query Statement
Returned Result
mv_ordinal_of
This function returns the 1-based index of expr that appears for the first time in an array. If expr does not appear, it returns -1.
Syntax: mv_ordinal_of(arr, expr)
Table 30 Parameter description
Type
Mandatory
arr
Original array.
Yes
expr
Specified element.
Yes
Example: SELECT MV_ORDINAL_OF(ARRAY['1','2','3','4','5'], '2')
Table 31 Query and analysis results
Type
Query Statement
Returned Result
2
