IP Address Functions
This section describes IP address functions, including their syntax, parameters, and usage examples.
The relationships between IP addresses and regions provided by LTS are from third-party libraries. The data is updated periodically (about half a year) and may not reflect the correct relationships. LTS will be optimized to update the libraries more frequently to provide better experience.
A maximum of 5 million data records can be queried using the aggregate query of an IP function. Exceeding this limit will cause the query to time out.
Function List
| Function | Description |
| Checks whether the target IPv4 address is internal or external. | |
| Obtains the prefix of the target IPv4 address. | |
| Checks whether the target IPv4 CIDR block is a subnet of a specified CIDR block. | |
| Checks whether the target IPv4 address is in a specified CIDR block. | |
| Obtains the largest IP address in an IPv4 CIDR block. | |
| Obtains the smallest IP address in an IPv4 CIDR block. | |
| Obtains the range of an IPv4 CIDR block. | |
| Returns the country or region where an IPv4 address is located. | |
| Returns the code of the country where an IPv4 address is located. | |
| Returns the name of the city where an IPv4 address is located. | |
| Returns the carrier name of an IPv4 address. | |
| Returns the country or region where an IPv6 address is located. | |
| Returns the code of the country where an IPv6 address is located. | |
| Returns the name of the province where an IPv6 address is located. | |
| Returns the name of the city where an IPv6 address is located. | |
| Returns the network service provider of an IPv6 address. | |
| Returns the coordinates of the city where an IPv6 address is located. | |
| Checks whether the IP address is an intranet address. |
ip_to_domain
This function checks whether the target IPv4 address is internal or external.
Syntax: ip_to_domain(expr)
| Parameter | Description | Type | Mandatory |
| expr | IP address. | String | Yes |
Return value type: string
Example: SELECT IP_TO_DOMAIN('10.110.10.210'), IP_TO_DOMAIN('192.175.4.1')
| Type | Query Statement | Returned Result |
| Scenario 1 | IP_TO_DOMAIN('10.110.10.210') | intranet |
| Scenario 2 | IP_TO_DOMAIN('192.175.4.1') | internet |
ip_prefix
This field obtains the prefix of the target IPv4 address.
Syntax: ip_prefix(expr, prefixBit)
| expr | IPv4 address. | String | Yes |
| prefixBit | Number of prefix digits. | String | Yes |
Example: SELECT IP_PREFIX('10.110.10.210', 8), IP_PREFIX('144.101.32.5', 12)
| Scenario 1 | IP_PREFIX('10.110.10.210', 8) | 10.0.0.0/8 |
| Scenario 2 | IP_PREFIX('144.101.32.5', 12) | 144.96.0.0/12 |
is_prefix_subnet_of
This function checks whether the target IPv4 CIDR block is a subnet of a specified CIDR block.
Syntax: is_prefix_subnet_of(expr1, expr2)
| expr1 | Specified IPv4 CIDR block. | String | Yes |
| expr2 | Target IPv4 CIDR block. | String | Yes |
Return value type: Boolean
Example: SELECT IS_PREFIX_SUBNET_OF('192.168.0.1/24', '192.168.1.1/24')
| Scenario | IS_PREFIX_SUBNET_OF('192.168.0.1/24', '192.168.1.1/24') | false |
is_subnet_of
This function checks whether the target IPv4 address is in a specified CIDR block.
Syntax: is_subnet_of(expr1, expr2)
| expr2 | Target IPv4 address. | String | Yes |
Example: SELECT IS_SUBNET_OF('192.168.0.1/24', '192.168.1.1')
| Scenario | IS_SUBNET_OF('192.168.0.1/24', '192.168.1.1') | false |
ip_subnet_max
This function obtains the largest IP address in an IPv4 CIDR block.
Syntax: ip_subnet_max(expr)
| expr | IPv4 CIDR block. | String | Yes |
Example: SELECT IP_SUBNET_MAX('192.120.80.128/10')
| Scenario | IP_SUBNET_MAX('192.120.80.128/10') | 192.127.255.255 |
ip_subnet_min
This function obtains the smallest IP address in an IPv4 CIDR block.
Syntax: ip_subnet_min(expr)
| expr1 | IPv4 CIDR block. | String | Yes |
Example: SELECT IP_SUBNET_MIN('192.120.80.128/10')
| Scenario | IP_SUBNET_MIN('192.120.80.128/10') | 192.64.0.0 |
ip_subnet_range
This function obtains the range of an IPv4 CIDR block.
Syntax: ip_subnet_range(expr)
Example: SELECT IP_SUBNET_RANGE('192.120.80.128/10')
| Scenario | IP_SUBNET_RANGE ('192.120.80.128/10') | ["192.64.0.0","192.127.255.255"] |
When the maximum IP address, minimum IP address, and IP address range of a given CIDR block are calculated, its unicast and broadcast addresses are excluded. The maximum and minimum available IP addresses and the available IP address range of the CIDR block is returned.
ip_to_country
This function returns the country or region where an IPv4 address is located.
Syntax: ip_to_country(x)
| x | IPv4 address. | String | Yes |
Example: select ip_to_country(ip)
| Scenario | ip_to_country(ip) | CN |
Ip_to_country_code
This function returns the code of the country where an IPv4 address is located.
Syntax: ip_to_country_code(x)
Example: select ip_to_country_code(ip)
| Scenario | ip_to_country_code(ip) | CN |
ip_to_city
This function returns the city of an IPv4 address.
Syntax: ip_to_city(x)
Example: select ip_to_city(ip)
| Scenario | ip_to_city(ip) | Cochise |
ip_to_provider
This function returns the carrier name of an IPv4 address.
Syntax: ip_to_provider(x)
Example: select ip_to_provider(ip)
| Scenario | ip_to_provider(ip) | CONUS-YPG |
ipv6_to_country
This function returns the country or region where an IPv6 address is located.
Syntax: ipv6_to_country(x)
| x | IPv6 address. | String | Yes |
Example: select ipv6_to_country(ip)
| Scenario | ipv6_to_country(ip) | China |
ipv6_to_country_code
This function returns the code of the country where an IPv6 address is located.
Syntax: ipv6_to_country_code(x)
Example: select ipv6_to_country_code(ip)
| Scenario | ipv6_to_country_code(ip) | CN |
ipv6_to_province
This function returns the name of the province where an IPv6 address is located.
Syntax: ipv6_to_province(x)
Example: select ipv6_to_province(ip)
| Scenario | ipv6_to_province(ip) | Shaanxi |
ipv6_to_city
This function returns the name of the city where an IPv6 address is located.
Syntax: ipv6_to_city(x)
Example: select ipv6_to_city(ip)
| Scenario | ipv6_to_city(ip) | Xi'an |
ipv6_to_provider
This function returns the network service provider of an IPv6 address.
Syntax: ipv6_to_provider(x)
Example: select ipv6_to_provider(ip)
| Scenario | ipv6_to_provider(ip) | China Telecom |
ipv6_to_city_geo
This function returns the coordinates of the city where an IPv6 address is located.
Syntax: ipv6_to_city_geo(x)
Example: select ipv6_to_city_geo(ip)
| Scenario | ipv6_to_city_geo(ip) | 39.904989,116.405285 |
ipv6_to_geo
Syntax: ipv6_to_geo(x)
Example: select ipv6_to_geo(ip)
| Scenario | ipv6_to_geo(ip) | 39.904989,116.405285 |
ipv6_to_domain
This function checks whether the IP address is an intranet address.
Syntax: ipv6_to_domain(x)
Example: select ipv6_to_domain(ip)
| Scenario | ipv6_to_domain(ip) | internet |
