Mathematical Calculation Functions
This section describes mathematical calculation functions, including their syntax, parameters, and usage examples.
Function List
| Function | Description |
| Rounds a number (x). If n is specified, it rounds x to n decimal places. If n is not specified, it rounds x to the nearest integer. |
round
This function rounds a number (x). If n is specified, it rounds x to n decimal places. If n is not specified, it rounds x to the nearest integer.
- Rounds x to the nearest integer:
Syntax: round(x)
- Rounds x to n decimal places:
Syntax: round(x, n)
| Parameter | Description | Type | Mandatory |
| x | Original field. | Double | Yes |
| n | Number of decimal places (integer). | Integer | Yes |
Return value type: double
Example: select round(num,4)
Example number: 3.1415926
| Type | Query Statement | Returned Result |
| Scenario | select round(num,4) | 3.1416 |
