Updated on 2025-07-28 GMT+08:00
Type Conversion Functions
This section describes type conversion functions, including their syntax, parameters, and usage examples.
Function List
Table 1 Type conversion functions
Function
cast
Converts a value from one data type to another and provides the data type to dynamic parameters.
cast
This function converts a value from one data type to another and provides the data type to dynamic parameters.
The cast expressions can be used wherever expressions are allowed.
Syntax: CAST(Expression as Datatype)
Table 2 Parameter description
Type
Mandatory
expression
Source type of the expression.
Any
Yes
Datatype
Target type.
SQL data type, such as bigint, varchar, double, double precision, boolean, timestamp, decimal, integer, char, or date
Yes
Table 3 Mapping between index and SQL data types
Index Data Type
SQL Data Type
Long
Bigint
String
Varchar
Float
Double or double precision
Return value type: target data type
Example: select cast(time as date)
Table 4 Query and analysis results
Type
Query Statement
Returned Result
cast(time as date)
2023-08-31 23:11:17.000
