Window Functions
This section describes window functions, including their syntax, parameters, and usage examples.
Function List
| Function | Description |
| Divides data in a window partition sequentially into n groups. |
ntile
This function divides data in a window partition sequentially into n groups.
Syntax:
ntile(n) over ( [partition by partition_expression] [order by order_expression] )
| Parameter | Description | Type | Mandatory |
| n | Number of groups. | Integer | Yes |
| partition by partition_expression | Partition expression for dividing data into partitions. | Any | Yes |
| order by order_expression | Window sorting. An order by clause is used to sort rows in a window partition. | Any | Yes |
Return value type: integer
Example: status,host,ntile(5) over (partition by status order by host) as n
| Type | Query Statement | Returned Result |
| Scenario | status,host,ntile(5) over (partition by status order by host) as n |
