Period-over-Period Functions
This section describes period-over-period functions, including their syntax, parameters, and usage examples.
Function List
| Function | Description |
| Compares the calculation result in the current period with that n seconds ago. | |
| Compares the calculation result in the current period with that n seconds ago. It also returns a millisecond-level timestamp in the result array. |
compare
- The following syntax compares the calculation result in the current period with that n seconds ago:
    compare(x, n)
- The following syntax compares the calculation result in the current period with that n1, n2, and n3 seconds ago:
    compare(x, n1, n2, n3...)
| Parameter | Description | Type | Mandatory |
| x | Aggregation function result field to be compared. | Double or long | Yes |
| n? | Time window (in seconds). For example, 3600 means 1 hour, 86400 means one day, 604800 means one week, and 31622400 means one year. | long | Yes |
Returned Data Type
JSON array. The format is [Current calculation result,Calculation result n seconds ago,Ratio of the current calculation result to that n seconds ago].
Example
This example calculates the ratio of the number of visits in the current hour to that in the same period of the previous day.
- Set the query and analysis time range to 1 hour (full hour), and run the following query and analysis statements: In the preceding command, 86400 indicates the current time minus 86400 seconds (one day).
    SELECT compare(PV, 86400) FROM (SELECT count(*) AS PV )
- Check the query and analyze results.
    - 5994.0 indicates the number of website visits in the current hour (for example, from 2021-01-02 00:00:00 to 2021-01-02 01:00:00).
- 6000.0 indicates the number of website visits in the same period of the previous day, for example, from 2021-01-01 00:00:00 to 2021-01-01 01:00:00.
- 0.999 indicates the ratio of the number of website visits in the current hour to that in the same period of the previous day.
 Figure 1 Query and analysis results
- Display query and analysis results in columns.
    SELECT diff[1] as "today", diff[2] as "yesterday", diff[3] as "ratio" FROM(SELECT compare(pv, 86400) AS diff FROM (SELECT count(*) AS pv )) Figure 2 Query and analysis results
ts_compare
This function compares the calculation result in the current period with that n seconds ago. The ts_compare function must be grouped by time column (GROUP BY).
Syntax
    ts_compare(x, n)
    ts_compare(x, n1, n2, n3...)
| x | The value is of the double or long type. |
| n | Time window (in seconds). For example, 3600 means 1 hour, 86400 means one day, 604800 means one week, and 31622400 means one year. |
Returned Data Type
JSON array. The format is [Current calculation result,Calculation result n seconds ago,Ratio of the current calculation result to that n seconds ago,UNIX timestamp n seconds ago].
Example
This example compares the number of website visits in the 3 hours of today with that in the 3 hours of the previous day.
Set the query and analysis time range to 3 hours of the current day and run the following statements: In the preceding command, 86400 indicates that the current time minus 86400 seconds (one day), and date_trunc('hour',__time) indicates that the date_trunc function is used to truncate the input timestamp to the hour.
- Query and analysis statement
    * | SELECT t_time, ts_compare(PV, 86400) AS data FROM( SELECT to_unixtime(date_trunc('hour', __time)) AS t_time, count(*) AS PV GROUP BY t_time ORDER BY t_time ) GROUP BY t_time
- Query and analysis results
    t_time Data 2021-10-26T06:00:00.000Z [159.0,224.0,0.7098214285714286,1.6351416E9] 2021-10-26T07:00:00.000Z [100.0,148.0,0.6756756756756757,1.6351452E9] 2021-10-26T08:00:00.000Z [100.0,100.0,1.0, 1.6016544E9, 1.6351488E9]
