Regular Expression Functions
This section describes regular expression functions, including their syntax, parameters, and usage examples.
Function List
Function |
Description |
Extracts a substring that matches a specified regular expression from a target string. |
Checks whether a target string matches a specified regular expression. |
Extracts all substrings that match a specified regular expression from a target string. |
Removes or replaces all substring that match a specified regular expression from a target string. |
Splits a target string and returns the substrings after splitting. |
regexp_extract
This function extracts a substring that matches a specified regular expression from a target string.
- Extracts and returns the first substring that matches a specified regular expression from a target string.
- Extracts and returns the nth substring that matches a specified regular expression from a target string.
Syntax: regexp_extract(expr, regularExpr, n)
Parameter |
Description |
Type |
Mandatory |
expr |
Target string. |
String |
Yes |
regularExpr |
Regular expression containing capture groups. (\d)(\d) indicates two capture groups. |
String |
Yes |
n |
nth substring that matches the regular expression. |
Integer |
No |
Return value type: string
Example: SELECT REGEXP_EXTRACT('HTTP/2.0', '\d+')
Type |
Query Statement |
Returned Result |
Scenario 1 |
REGEXP_EXTRACT('HTTP/2.0', '\d+') |
2 |
Scenario 2 |
REGEXP_EXTRACT ('HTTP/2.0', '\d+', 1) |
2 |
regexp_like
This function checks whether a target string matches a specified regular expression.
Syntax: regexp_like(expr, regularExpr)
Parameter |
Description |
Type |
Mandatory |
expr |
Target string. |
String |
Yes |
regularExpr |
String |
Yes |
Return value type: Boolean
Example: SELECT REGEXP_LIKE('HTTP/2.0', '\d+')
Type |
Query Statement |
Returned Result |
Scenario |
REGEXP_LIKE('HTTP/2.0', '\d+') |
true |
regexp_extract_all
This function extracts all substrings that match a specified regular expression from a target string.
Syntax: regexp_extract_all(expr, regularExpr)
Parameter |
Description |
Type |
Mandatory |
expr |
Target string. |
String |
Yes |
regularExpr |
String |
Yes |
Return value type: array
Example: SELECT REGEXP_EXTRACT_ALL('HTTP/2.0', '\d+')
Type |
Query Statement |
Returned Result |
Scenario |
REGEXP_EXTRACT_ALL ('HTTP/2.0', '\d+') |
["2","0"] |
regexp_replace
This function removes or replaces all substrings that match a specified regular expression from a target string.
- Removes substrings that match a specified regular expression from a string and returns the substrings that remain.
- Replaces substrings that match a specified regular expression in a string and returns the result string.
Parameter |
Description |
Type |
Mandatory |
expr |
Target string. |
String |
Yes |
regularExpr |
String |
Yes |
replaceStr |
Replacement string. |
String |
No |
Example: SELECT REGEXP_REPLACE('ab12cd34', '\d+'), REGEXP_REPLACE('ab12cd34', '\d+', '00')
Type |
Query Statement |
Returned Result |
Scenario 1 |
REGEXP_REPLACE('ab12cd34', '\d+') |
abcd |
Scenario 2 |
REGEXP_REPLACE('ab12cd34', '\d+', '00') |
ab00cd00 |
regexp_split
This function splits a target string and returns the substrings after splitting.
Syntax: regexp_split(expr, regularExpr)
Parameter |
Description |
Type |
Mandatory |
expr |
Target string. |
String |
Yes |
regularExpr |
String |
Yes |
Example: SELECT REGEXP_SPLIT('request_uri:/request/path-0/file-7','/')
Type |
Query Statement |
Returned Result |
Scenario |
REGEXP_SPLIT('request_uri:/request/path-0/file-7','/') |
["request_uri:","request","path-0","file-7"] |
