Date and Time Functions
This section describes date and time functions, including their syntax, parameters, and usage examples. The pipe-character feature processes date and time of the timestamp type and returns values in the yyyy-MM-dd HH:mm:ss.SSS TimeZone format.
Function List
Function |
Description |
Returns the current date and time in the yyyy-MM-dd HH:mm:ss.SSS format. |
Converts a date expression in the ISO 8601 format to a date expression of the date type in the yyyy-MM-dd format. |
Converts a date expression in the ISO 8601 format to a date expression of the timestamp type in the yyyy-MM-dd HH:mm:ss.SSS format. |
Converts a timestamp in milliseconds to a datetime expression of the timestamp type. |
Converts a timestamp in seconds or milliseconds to a datetime expression. |
Converts a date and time expression of the date or timestamp type to ISO 8601 format. |
Converts a datetime expression of the timestamp type to a timestamp in milliseconds. |
Rounds up a timestamp of the timestamp or long type to the nearest period and returns the new timestamp. period can be any ISO 8601 duration, such as P3M (three months) or PT12H (12 hours). |
Returns a timestamp of the timestamp or long type. period can be any ISO 8601 duration, such as P3M (three months) or PT12H (12 hours). |
Rounds up a timestamp to the nearest multiple of the specified time unit. The unit can be SECOND, MINUTE, HOUR, DAY, WEEK, MONTH, QUARTER, or YEAR. |
Rounds down a timestamp to the nearest multiple of the specified time unit. The unit can be SECOND, MINUTE, HOUR, DAY, WEEK, MONTH, QUARTER, or YEAR. |
Moves a timestamp (expr) by a specified period (step time). period can be set to any ISO 8601 duration. |
Calculates the hour offset of a time zone. |
Calculates the minute offset of a time zone. |
Converts a timestamp in milliseconds or a datetime expression of the timestamp type (expr) into a string in a specified date and time format. The conversion is performed based on a user-defined format parameter and follows Joda DateTimeFormat. |
Parses a given string (expr) into a datetime expression of the timestamp type in the yyyy-MM-dd HH:mm:ss.SSS TimeZone format. The parsing is performed based on a user-defined format parameter and follows Joda DateTimeFormat. |
Converts a datetime expression of the timestamp type to a string in the specified date and time format. |
Converts a date and time string to a datetime expression of the timestamp type in a specified format. |
Extracts a date or time component from a datetime expression by specifying a field. |
Truncates a datetime expression based on a specified time unit. The time unit can be millisecond, second, minute, hour, day, month, or year. |
Returns the number of units (signed) between timestamps expr1 and expr2. |
Returns the current date in the yyyy-MM-dd format. |
Returns the current date and time. |
Adds a specified interval to the time. |
Returns the current time in the HH:mm:ss.SSSSSS format. |
Returns the current time zone. |
Returns the local time. |
Returns the local date and time. |
Returns the year of the target date in the ISO weekly calendar. The year_of_week function is equivalent to the yow function. |
Completes the missing data in the query time window. |
current_timestamp
This function returns the current date and time in the yyyy-MM-dd HH:mm:ss.SSS format.
Syntax: current_timestamp()
Return value type: timestamp
Example: SELECT CURRENT_TIMESTAMP()
Type |
Query Statement |
Returned Result |
Scenario |
CURRENT_TIMESTAMP() |
2025-05-29 20:09:17.656 Asia/Shanghai |
from_iso8601_date
This function converts a date expression in the ISO 8601 format to a date expression of the date type in the YYYY-MM-DD format.
Syntax: from_iso8601_date(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
Date expression in the ISO 8601 format. |
String |
Yes |
Return value type: string
Example: SELECT FROM_ISO8601_DATE('2018-05-14')
Type |
Query Statement |
Returned Result |
Scenario |
FROM_ISO8601_DATE('2018-05-14') |
2018-05-14 |
from_iso8601_timestamp
This function converts a datetime expression in the ISO 8601 format to a datetime expression of the timestamp type in the YYYY-MM-DD HH:MM:SS.Ms Time_zone format.
Syntax: from_iso8601_timestamp(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression in the ISO 8601 format. |
String |
Yes |
Example: SELECT FROM_ISO8601_TIMESTAMP('2018-05-14T11:51:50.153+08:00')
Type |
Query Statement |
Returned Result |
Scenario |
FROM_ISO8601_TIMESTAMP('2018-05-14T11:51:50.153+08:00') |
2018-05-14 11:51:50.153 +08:00 |
mills_to_timestamp
This function converts a timestamp in milliseconds to a datetime expression of the timestamp type.
- Converts a timestamp in milliseconds to a datetime expression of the timestamp type in the yyyy-MM-dd HH:mm:ss.SSS format.
Syntax: mills_to_timestamp(expr)
Table 7 Parameter description Parameter
Type
Mandatory
expr
UNIX timestamp.
Long
Yes
Example: SELECT MILLS_TO_TIMESTAMP(1626774758000)
Table 8 Query and analysis results Type
Query Statement
Returned Result
2021-07-20 17:52:38.000 Asia/Shanghai
from_unixtime
This function converts a timestamp in seconds or milliseconds to a datetime expression. If the value of expr is less than 315,360,000,000, it is treated as a timestamp in seconds.
- Converts a timestamp in seconds or milliseconds to a datetime expression of the timestamp type.
Table 9 Parameter description Parameter
Type
Mandatory
expr
Timestamp in seconds or milliseconds.
Long
Yes
Example: SELECT FROM_UNIXTIME(1626774758000)
Table 10 Query and analysis results Type
Query Statement
Returned Result
2021-07-20 17:52:38.000 Asia/shanghai
Example: SELECT FROM_UNIXTIME(1731916857)
Table 11 Query and analysis results Type
Query Statement
Returned Result
2024-11-18 16:00:57.000 Asia/shanghai
- Converts a timestamp in seconds or milliseconds to a datetime expression of the timestamp type with a specific time zone.
Syntax: from_unixtime(expr, timezone)
Table 12 Parameter description Parameter
Type
Mandatory
expr
UNIX timestamp.
Long
Yes
timezone
Time zone.
String
Yes
Example: SELECT FROM_UNIXTIME(1626774758000, 'Asia/Shanghai')
Table 13 Query and analysis results Type
Query Statement
Returned Result
- Converts a timestamp in seconds or milliseconds to a datetime expression with a specific time zone. The hour and minute parameters specify the time zone offset.
Syntax: from_unixtime(expr, hour, minutes)
Table 14 Parameter description Parameter
Type
Mandatory
expr
UNIX timestamp.
Long
Yes
hour
Hour.
Integer
Yes
minute
Minute.
Integer
Yes
Example: SELECT FROM_UNIXTIME(1626774758000, -2, 0)
Table 15 Query and analysis results Type
Query Statement
Returned Result
2021-07-20 07:52:38.000 -02:00
to_iso8601
This function converts a date and time expression of the date or timestamp type to ISO 8601 format.
Syntax: to_iso8601(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression of the timestamp type. |
Timestamp |
Yes |
Example: SELECT TO_ISO8601(from_unixtime(1626774758000))
Type |
Query Statement |
Returned Result |
Scenario |
TO_ISO8601(FROM_UNIXTIME(1626774758000)) |
2021-07-20T17:52:38.000+08:00 |
timestamp_to_mills
This function converts a datetime expression of the timestamp type to a timestamp in milliseconds.
Syntax: timestamp_to_mills(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
Timestamp |
Yes |
Return value type: long
Example: select timestamp_to_mills(from_unixtime(1626774758000))
Type |
Query Statement |
Returned Result |
Scenario |
timestamp_to_mills(from_unixtime(1626774758000)) |
1626774758000 |
to_unixtime
Syntax: to_unixtime(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
Yes |
Example: SELECT to_unixtime(from_unixtime(1626774758000))
Type |
Query Statement |
Returned Result |
Scenario |
to_unixtime(from_unixtime(1626774758000)) |
1626774758 |
time_ceil
This function rounds up a timestamp of the timestamp or long type to the nearest period and returns the new timestamp. period can be any ISO 8601 duration, such as P3M (three months) or PT12H (12 hours).
time_ceil(expr, period)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression in the yyyy-MM-dd HH:mm:ss.SSS TimeZone format. |
Timestamp or long |
Yes |
period |
String |
Yes |
Example 1: SELECT time_ceil(from_unixtime(__time),'PT1M')
Type |
Query Statement |
Returned Result |
Scenario |
SELECT time_ceil(from_unixtime(__time),'PT1M') |
2025-05-30 14:58:00.000 Asia/Shanghai |
Period description: The period format must be P[n]Y[n]M[n]DT[n]H[n]M[n]S or P[n]W. In these representations, [n] indicates the number of date and time elements. Leading zeros are not required, but the maximum number of digits for each element should be agreed to by the communicating parties. The uppercase letters P, Y, M, W, D, T, H, M, and S are designators for each of the date and time elements and are not replaced.
- P is the duration designator (for period) placed at the beginning of the duration representation.
- Y is the year designator that follows the value for the number of calendar years.
- M is the month designator that follows the value for the number of calendar months.
- W is the week designator that follows the value for the number of weeks.
- D is the day designator that follows the value for the number of calendar days.
- T is the time designator that precedes the time components.
- H is the hour designator that follows the value for the number of hours.
- M is the minute designator that follows the value for the number of minutes.
- S is the second designator that follows the value for the number of seconds.
For example, P3Y6M4DT12H30M5S indicates a duration of "3 years, 6 months, 4 days, 12 hours, 30 minutes, and 5 seconds."
For more information, visit https://en.wikipedia.org/wiki/ISO_8601.
time_floor
This function returns a timestamp of the timestamp or long type. period can be any ISO 8601 duration, such as P3M (three months) or PT12H (12 hours).
Syntax: time_floor(expr, period)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression of the timestamp type, in the yyyy-MM-dd HH:mm:ss.SSS TimeZone format. |
Timestamp or long |
Yes |
period |
String |
Yes |
Example 1: SELECT TIME_FLOOR(from_unixtime(1626774758000), 'PT2H')
Type |
Query Statement |
Returned Result |
Scenario |
TIME_FLOOR(from_unixtime(1626774758000), 'PT2H') |
2021-07-20 16:00:00.000 Asia/Shanghai |
ceil
This function rounds up a timestamp to the nearest multiple of the specified time unit. The unit can be SECOND, MINUTE, HOUR, DAY, WEEK, MONTH, QUARTER, or YEAR.
Syntax: ceil(expr, unit)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression in the yyyy-MM-dd HH:mm:ss.SSS format. |
timestamp |
Yes |
unit |
Time unit. |
String |
Yes |
Example: SELECT CEIL('2023-04-20 11:28:31.770', 'DAY')
Type |
Query Statement |
Returned Result |
Scenario |
CEIL ('2023-04-20 11:28:31.770', 'DAY') |
2023-04-21 00:00:00.000 |
floor
This function rounds down a timestamp to the nearest multiple of the specified time unit. The unit can be SECOND, MINUTE, HOUR, DAY, WEEK, MONTH, QUARTER, or YEAR.
Syntax: floor(expr, unit)
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
Yes |
unit |
Time unit. |
String |
Yes |
Example: SELECT FLOOR('2023-04-20 11:28:31.770', 'DAY')
Type |
Query Statement |
Returned Result |
Scenario |
FLOOR('2023-04-20 11:28:31.770', 'DAY') |
2023-04-20 00:00:00.000 |
time_shift
This function moves a timestamp (expr) by a specified period (step time). period can be set to any ISO 8601 duration.
Syntax: time_shift(expr, period, step, [timezone])
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
Yes |
period |
String |
Yes |
step |
Step. |
Integer |
Yes |
timezone |
Time zone. |
String |
No |
Example: SELECT TIME_SHIFT( from_unixtime(__time), 'P1D', 5), TIME_SHIFT( from_unixtime(__time), 'P1D', 5,'+08:00')
Type |
Query Statement |
Returned Result |
Scenario 1 |
TIME_SHIFT( from_unixtime(__time), 'P1D', 5) |
2024-11-23 21:58:59.907 Asia/Shanghai |
Scenario 2 |
TIME_SHIFT( from_unixtime(__time), 'P1D', 5,'+08:00') |
2024-11-23 21:58:59.907 +08:00 |
timezone_hour
This function calculates the hour offset of a time zone.
Syntax: timezone_hour(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression in the yyyy-MM-dd HH:mm:ss.SSS TIMEZONE format. |
timestamp |
No |
Return value type: integer
Example: SELECT TIMEZONE_HOUR(from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
SELECT TIMEZONE_HOUR(from_unixtime(__time)) |
8 |
timezone_minute
This function calculates the minute offset of a time zone.
Syntax: timezone_minute(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
No |
Example: SELECT TIMEZONE_MINUTE(from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
TIMEZONE_MINUTE(from_unixtime(__time)) |
0 |
time_format
This function converts a timestamp in milliseconds or a datetime expression of the timestamp type (expr) into a string in a specified date and time format. The conversion is performed based on a user-defined format parameter and follows Joda DateTimeFormat.
Syntax: time_format(expr, format)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression of the timestamp type or timestamp in milliseconds. |
Timestamp or long |
Yes |
format |
Time format. |
String |
Yes |
Example: SELECT TIME_FORMAT(__time, 'yyyy-MM-dd HH:mm:ss'), TIME_FORMAT(from_unixtime(__time), 'yyyy-MM-dd HH:mm:ss')
Type |
Query Statement |
Returned Result |
Scenario 1 |
TIME_FORMAT(__time, 'yyyy-MM-dd HH:mm:ss') |
2024-11-18 22:15:16 |
Scenario 2 |
TIME_FORMAT(from_unixtime(__time), 'yyyy-MM-dd HH:mm:ss') |
time_parse
This function parses a given string (expr) into a datetime expression of the timestamp type in the yyyy-MM-dd HH:mm:ss.SSS TimeZone format. The parsing is performed based on a user-defined format parameter and follows Joda DateTimeFormat. If format is not specified, the string is parsed according to ISO 8601 by default.
Syntax: time_parse(expr, format)
Parameter |
Description |
Type |
Mandatory |
expr |
String of a certain time format. |
String |
Yes |
format |
Time format. |
String |
Yes |
Return value type: datetime expression of the timestamp type
Example: SELECT TIME_PARSE('2024-11-18 22:15:11', 'yyyy-MM-dd HH:mm:ss')
Type |
Query Statement |
Returned Result |
Scenario |
TIME_PARSE('2024-11-18 22:15:11', 'yyyy-MM-dd HH:mm:ss') |
2024-11-18 22:15:11.000 Asia/Shanghai |
Description of the format parameter:
Symbol Meaning Presentation Examples
G era text AD
C century of era (>=0) number 20
Y year of era (>=0) year 1996
x weekyear year 1996
w week of weekyear number 27
e day of week number 2
E day of week text Tuesday; Tue
y year year 1996
D day of year number 189
M month of year month July; Jul; 07
d day of month number 10
a halfday of day text PM
K hour of halfday (0~11) number 0
h clockhour of halfday (1~12) number 12
H hour of day (0~23) number 0
k clockhour of day (1~24) number 24
m minute of hour number 30
s second of minute number 55
S fraction of second millis 978
z time zone text Pacific Standard Time; PST
Z time zone offset/id zone -0800; -08:00; America/Los_Angeles
' escape for text delimiter
'' single quote literal '
date_format
This function converts a datetime expression of the timestamp type to a string in the specified date and time format.
Syntax: date_format(expr, format)
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
Yes |
format |
Time format. |
String |
Yes |
Example: SELECT DATE_FORMAT(current_timestamp(),'%H%i')
Type |
Query Statement |
Returned Result |
Scenario |
DATE_FORMAT(current_timestamp(),'%H%i') |
1432 |
%a Abbreviation for the week. For example, Sun and Sat.
%b Abbreviation of the month. For example, Jan and Dec.
%c Month. Numeral type. Range: 1-12.
%D Day of the month. The value must be suffixed, for example, 0th, 1st, 2nd, and 3rd.
%d Day of the month. The value ranges from 01 to 31 in decimal notation.
%e Day of the month. The value ranges from 1 to 31 in decimal notation.
%H Hour, 24-hour system.
%h Hour, 12-hour system.
%i Minute. Numeral type. Range: 00–59.
%j Day of the year. The value ranges from 001 to 366.
%k Hour. The value ranges from 0 to 23.
%l Hour. The value ranges from 1 to 12.
%M The English expression of the month, for example, January, December.
%m Month. Numeral format. The value ranges from 01 to 12.
%p AM and PM.
%r Time in the 12-hour format. The format is hh:mm:ss AM/PM.
%S Indicates the second. The value ranges from 00 to 59.
%s Indicates the second. The value ranges from 00 to 59.
%T Time, in the 24-hour format of hh:mm:ss.
%v The first week of the year, Monday is the first day of the week. The value ranges from 01 to 53.
%W The name of the day of the week. For example, Sunday and Saturday.
%w Day of the week. Sunday is day 0.
%Y A 4-digit year, for example, 2020.
%y A 2-digit year, for example, 20.
%% Escape character for%.
date_parse
This function converts a date and time string to a datetime expression of the timestamp type in a specified format.
Syntax: date_parse(expr, pattern)
Parameter |
Description |
Type |
Mandatory |
expr |
Datetime expression. |
String |
Yes |
pattern |
Conversion format of the datetime expression. |
String |
Yes |
Return value type: datetime expression of the timestamp type.
Example: SELECT DATE_PARSE('2024-11-18 10:53','%Y-%m-%d %h:%i')
Type |
Query Statement |
Returned Result |
Scenario |
DATE_PARSE('2024-11-18 10:53','%Y-%m-%d %h:%i') |
2024-11-18 18:53:00.000 |
If the pattern includes minutes, the year, month, day, and hour components preceding the minutes must also be configured in the pattern.
time_extract
This function extracts a date or time component from a datetime expression by specifying a field.
The unit can be epoch, second, minute, hour, day (a day in a month), DOW (a day in a week), DOY (a day in a year), WEEK (a week in a week), MONTH (1 to 12), QUARTER (1 to 4), or YEAR. If the time zone is provided, it should be the time zone name (for example, America/Los_Angeles) or offset (for example, -08:00).
Syntax: time_extract(expr, unit)
Parameter |
Description |
Type |
Mandatory |
expr |
String |
Yes |
unit |
Time unit. |
String |
Yes |
Example: SELECT TIME_EXTRACT('2023-05-05','YEAR')
Type |
Query Statement |
Returned Result |
Scenario |
TIME_EXTRACT('2023-05-05','YEAR') |
2023 |
date_trunc
This function truncates a datetime expression based on a specified time unit. The time unit can be millisecond, second, minute, hour, day, month, or year.
Syntax: date_trunc(unit, expr)
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
Yes |
unit |
Time unit. |
String |
Yes |
Example: SELECT DATE_TRUNC('year', from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
DATE_TRUNC('year', from_unixtime(__time)) |
2024-01-01 00:00:00.000 Asia/Shanghai |
date_diff
This function returns the number of units (signed) between timestamps expr1 and expr2.
Syntax: date_diff(unit, expr1, expr2)
Parameter |
Description |
Type |
Mandatory |
expr1 |
timestamp |
Yes |
expr2 |
timestamp |
unit |
Time unit. |
String |
Yes |
Example: SELECT DATE_DIFF('SECOND', CURRENT_TIMESTAMP() ,from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
DATE_DIFF('SECOND', CURRENT_TIMESTAMP() ,from_unixtime(__time)) |
-899.00 |
current_date
Syntax: current_date()
Example: SELECT CURRENT_DATE()
Type |
Query Statement |
Returned Result |
Scenario |
CURRENT_DATE() |
2023-04-17 |
now
This function returns the current date and time. It is equivalent to the current_timestamp function.
Syntax: now()
Return value type: datetime expression of the timestamp type, in the yyyy-MM-dd HH:mm:ss.SSS TimeZone format.
Example: SELECT NOW()
Type |
Query Statement |
Returned Result |
Scenario |
NOW() |
2024-11-18 23:29:18.434 Asia/Shanghai |
date_add
This function adds a specified interval to the time.
Syntax: date_add(unit, n, expr)
Parameter |
Description |
Type |
Mandatory |
unit |
Time unit. It can be millisecond, second, minute, hour, day, week, month, quarter, or year. |
String |
Yes |
n |
Time interval. |
Long |
Yes |
expr |
timestamp |
Yes |
Example: SELECT DATE_ADD('MINUTE', 7, from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
DATE_ADD('MINUTE', 7, from_unixtime(__time)) |
2024-11-18 23:23:47.407 Asia/Shanghai |
current_time
This function returns the current time in the HH:mm:ss.SSSSSS format.
Syntax: current_time()
Example: SELECT CURRENT_TIME()
Type |
Query Statement |
Returned Result |
Scenario |
CURRENT_TIME () |
23:38:18.491+08:00 |
current_timezone
This function returns the current time zone.
Syntax: current_timezone()
Example: SELECT CURRENT_TIMEZONE()
Type |
Query Statement |
Returned Result |
Scenario |
CURRENT_TIMEZONE () |
Asia/Shanghai |
localtime
This function returns the local time.
Syntax: localtime()
Example: SELECT LOCALTIME()
Type |
Query Statement |
Returned Result |
Scenario |
LOCALTIME() |
23:38:51.346 |
localtimestamp
This function returns the local date and time.
Syntax: localtimestamp
Example: SELECT LOCALTIMESTAMP
Type |
Query Statement |
Returned Result |
Scenario |
LOCALTIMESTAMP |
2024-11-18 23:39:17.070 |
year_of_week
This function returns the year of the target date in the ISO weekly calendar. The year_of_week function is equivalent to the yow function.
Syntax: year_of_week(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
Time expression in the yyyy-MM-dd HH:mm:ss.SSS or yyyy-MM-dd format. |
String |
Yes |
Example: SELECT YEAR_OF_WEEK('2023-09-22 14:47:59.325'), YEAR_OF_WEEK('2023-09-22')
Type |
Query Statement |
Returned Result |
Scenario 1 |
YEAR_OF_WEEK('2023-09-22 14:47:59.325') |
2023 |
Scenario 2 |
YEAR_OF_WEEK('2023-09-22') |
2023 |
Parameter |
Description |
Type |
Mandatory |
expr |
timestamp |
Yes |
Example: SELECT YEAR_OF_WEEK(from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
YEAR_OF_WEEK(from_unixtime(__time)) |
2024 |
yow
Syntax: yow(expr)
Parameter |
Description |
Type |
Mandatory |
expr |
String |
Yes |
Example: SELECT YOW('2023-09-22 14:47:59.325'), YOW('2023-09-22')
Type |
Query Statement |
Returned Result |
Scenario 1 |
YOW('2023-09-22 14:47:59.325') |
2023 |
Scenario 2 |
YOW('2023-09-22') |
2023 |
Parameter |
Description |
Type |
Mandatory |
expr |
String |
Yes |
Example: SELECT YOW(from_unixtime(__time))
Type |
Query Statement |
Returned Result |
Scenario |
YOW(from_unixtime(__time)) |
2024 |
time_series
This function completes the missing data in the query time window. It must be used with the GROUP BY and ORDER BY syntax.
Syntax: time_series(x, window_time, format, padding_data)
Parameter |
Description |
Type |
Mandatory |
x |
Original field. |
Long or timestamp |
Yes |
window_time |
Window size. The unit can be s (second), m (minute), h (hour), or d (day). Example: 2h, 5m, or 3d. |
String |
Yes |
format |
Time format of the returned result. |
String |
Yes |
padding_data |
Supplemented content. 0: The missing value is set to 0. null: The missing value is set to null. last: The missing value is set to the value corresponding to the previous time point. next: The missing value is set to the value corresponding to the next time point. avg: The missing value is set to the average value of two adjacent time points. |
String |
Yes |
Example: select time_series(__time, '1d', 'HH:mm:ss','0') as time, count(*) as count group by time order by time asc
Type |
Query Statement |
Returned Result |
Scenario |
select time_series(__time, '1m', 'HH:mm:ss','0') as time, count(*) as count group by time order by time asc |
time count 7:04:00 5.00 7:05:00 6.00 7:06:00 6.00 7:07:00 6.00 7:08:00 6.00 7:09:00 6.00 7:10:00 6.00 7:11:00 6.00 7:12:00 6.00 7:13:00 6.00 |
