String Functions
This section describes string functions, including their syntax, parameters, and usage examples.
Function List
| Function | Description |
| Pads the beginning of a string with specified characters until it reaches the specified length, and then returns the result string. If you do not specify padding characters, space characters are used for padding. | |
| Pads the end of a string with specified characters until it reaches the specified length, and then returns the result string. If you do not specify padding characters, space characters are used for padding. | |
| Replaces all occurrences of a matched substring in the original string with a specified string. If no replacement string is specified, all matched substrings are removed from the original string. | |
| Reverses the order of characters in a string. | |
| Repeats a string a specified number of times. | |
| Checks whether a string contains a specified substring. | |
| Checks whether a string contains a specified substring, regardless of letter case. | |
| Concatenates two strings and returns the concatenated result. | |
| Removes spaces from both sides of a string. | |
| Converts a string to a long integer using a specified radix (base). If no radix is provided, the default radix of 10 (decimal) is used. | |
| Splits a string using a specified delimiter and returns an array of substrings. You can set limit to limit the number of resulting substrings. | |
| Splits a string using a specified delimiter and returns the substring at a specified position. If the position exceeds the array length, an empty string is returned. | |
| Splits a string using the first delimiter, then splits the string further using the second delimiter, and returns the result. | |
| Returns a string formatted using Java's String.format method. | |
| Returns the position of the first occurrence of the target substring in a string. It returns 0 if the target substring is not found. | |
| Extracts a substring based on the start position and length. If the length is not specified, it returns the entire string starting from the start position. It is equivalent to the substring function. | |
| Extracts a substring based on the start position and length. If the length is not specified, it returns the entire string starting from the start position. | |
| Returns the length of the input characters (for a string expression) or the byte length (for a non-string expression). The byte length is at least the smallest integer obtained by dividing the number of digits by 8. | |
| Returns the length of the input characters (for a string expression) or the byte length (for a non-string expression). The byte length is at least the smallest integer obtained by dividing the number of digits by 8. This function is equivalent to the length function. | |
| Equivalent to the length function. | |
| Calculates the minimum edit distance between strings str1 and str2. | |
| Formats a string. | |
| Converts a string to the UTF-8 encoding format. | |
| Converts an ASCII value to characters. | |
| Concatenates multiple parameters into a string. |
lpad
This function pads the beginning of a string with specified characters until it reaches the specified length, and then returns the result string. If you do not specify padding characters, space characters are used for padding.
Syntax: lpad(str, len, lpadStr)
| Parameter | Description | Type | Mandatory |
| str | Original string. | String | Yes |
| len | Length of the result string.
| Integer | Yes |
| lpadStr | Padding characters. | String | No |
Return value type: string
Example: SELECT LPAD('hello world', 10), LPAD('hello', 10, 'e')
| Type | Query Statement | Returned Result |
| Scenario 1 | LPAD('hello world', 10) | hello worl |
| Scenario 2 | LPAD('hello', 10, 'e') | eeeeehello |
rpad
This function pads the end of a string with specified characters until it reaches the specified length, and then returns the result string. If you do not specify padding characters, space characters are used for padding.
Syntax: rpad(str, len, rpadStr)
| Integer | Yes |
| rpadStr | Padding characters. | String | No |
Example: SELECT RPAD('hello world', 10), RPAD('hello', 10, 'e')
| Scenario 1 | RPAD('hello world', 10) | hello worl |
| Scenario 2 | RPAD('hello', 10, 'e') | helloeeeee |
replace
This function replaces all occurrences of a matched substring in the original string with a specified string. If no replacement string is specified, all matched substrings are removed from the original string.
Syntax: replace(str, subStr, replaceStr)
| subStr | Target substring. | String | Yes |
| replaceStr | String for replacement. | String | No |
Example: SELECT REPLACE('hello world', 'o'), REPLACE('hello world', 'w', 'new w')
| Scenario 1 | REPLACE('hello world', 'o') | hell wrld |
| Scenario 2 | REPLACE('hello world', 'w', 'new w') | hello new world |
reverse
This function reverses the order of characters in a string.
Syntax: reverse(str)
Example: SELECT REVERSE('hello world')
| Scenario | REVERSE('hello world') | dlrow olleh |
repeat
This function repeats a string a specified number of times.
Syntax: repeat(str, num)
| num | Number of repetitions. | Integer | Yes |
Example: SELECT REPEAT('hello world', 2), REPEAT('hello world', 0)
| Scenario 1 | REPEAT('hello world', 2) | hello worldhello world |
| Scenario 2 | REPEAT('hello world', 0) |
contains_string
This function checks whether a string contains a specified substring.
Syntax: contains_string(str, containsStr)
| containsStr | Specified string. | String | Yes |
Return value type: Boolean
Example: SELECT CONTAINS_STRING('hello world', 'llo')
| Scenario | CONTAINS_STRING('hello world', 'llo') | true |
icontains_string
This function checks whether a string contains a specified substring, regardless of letter case.
Syntax: icontains_string(str, containsStr)
Example: SELECT ICONTAINS_STRING('hello world', 'llo')
| Scenario | ICONTAINS_STRING('hello world', 'llo') | true |
textcat
This function concatenates two strings and returns the concatenated result.
Syntax: textcat(str1, str2)
| str1 | String 1 to be concatenated. | String | Yes |
| str2 | String 2 to be concatenated. | String | Yes |
Example: SELECT TEXTCAT('hello ', 'world')
| Scenario | TEXTCAT('hello ', 'world') | hello world |
btrim
This function removes spaces from both sides of a string.
Syntax: btrim(str)
Example: SELECT BTRIM(' hello world ')
| Scenario | BTRIM(' hello world ') | hello world |
parse_long
This function converts a string to a long integer using a specified radix (base). If no radix is provided, the default radix of 10 (decimal) is used.
Syntax: parse_long(str, radix)
| radix | Base. | Integer | No |
Return value type: long
Example: SELECT PARSE_LONG('-1234', 8), PARSE_LONG('1234')
| Scenario 1 | PARSE_LONG('-1234', 8) | -668 |
| Scenario 2 | PARSE_LONG('1234') | 1234 |
split
This function splits a string using a specified delimiter and returns an array of substrings. You can set limit to limit the number of resulting substrings.
Syntax: split(str, splitStr, limit)
| splitStr | Delimiter. | String | Yes |
| limit | Base. | Integer | No |
Return value type: ARRAYS<STRING>
Example: SELECT SPLIT('helloworld', 'o'), SPLIT('helloworld', 'o', 2)
| Scenario 1 | SPLIT('helloworld','o' ) | ["hell","w","rld"] |
| Scenario 2 | SPLIT('helloworld', 'o', 2) | ["hell","world"] |
split_part
This function splits a string using a specified delimiter and returns the substring at a specified position. If the position exceeds the array length, an empty string is returned.
Syntax: split_part(str, splitStr, position)
| position | Position of the string to be returned. | Integer | Yes |
Example: SELECT SPLIT_PART('helloworld', 'o', 2), SPLIT_PART('helloworld', 'o', 4)
| Scenario 1 | SPLIT_PART('helloworld','o', 2) | w |
| Scenario 2 | SPLIT_PART('helloworld', 'o', 4) |
split_to_map
This function splits a string using the first delimiter, then splits the string further using the second delimiter, and returns the result.
Syntax: split_to_map(str, splitStr1, splitStr2)
| splitStr1 | Delimiter 1. | String | Yes |
| splitStr2 | Delimiter 2. | String | Yes |
Return value type: array
Example: SELECT SPLIT_TO_MAP('upstream_response_time:123, request_time:456', ',', ':')
| Scenario | SPLIT_TO_MAP('upstream_response_time:123, request_time:456', ',', ':') | {" request_time":"456","upstream_response_time":"123"} |
string_format
This function returns a string formatted using Java's String.format method.
Syntax: string_format(str, Object... args)
| args | Output time format. | String/Integer/Long/Boolean/Double | Yes |
Example: SELECT STRING_FORMAT('My name is %s and I am %d years old.', 'name', age)
| Scenario | STRING_FORMAT('My name is %s and I am %d years old.', 'Tom', 25) | My name is Tom and I am 25 years old. |
- %d: outputs an integer.
- %f: outputs a floating point number.
- %s: outputs a string.
- %n: outputs a newline character.
- %c: outputs characters.
- %b: outputs the Boolean type.
- %e: outputs the exponential type.
- %tc: outputs date and time information.
- %tF: The output format is YYYY-MM-DD.
- %tr: The output format is HH:MM:SS PM.
strpos
This function returns the position of the first occurrence of the target substring in a string. It returns 0 if the target substring is not found.
Syntax: strpos(str, subStr)
Return value type: integer
Example: SELECT STRPOS('hello world', 'llo'), STRPOS('llo', 'hello world')
| Scenario 1 | STRPOS('hello world', 'llo') | 3 |
| Scenario 2 | STRPOS('llo', 'hello world') | 0 |
substr
This function extracts a substring based on the start position and length. If the length is not specified, it returns the entire string starting from the start position. It is equivalent to the substring function.
Syntax: substr(str, start, length)
| start | Start position of the target substring to be returned. | Integer | Yes |
| length | Length of the substring. | Integer | No |
Example: SELECT SUBSTR('helloworld', 5), SUBSTR('helloworld', 5, 3)
| Scenario 1 | SUBSTR ('helloworld', 5) | oworld |
| Scenario 2 | SUBSTR ('helloworld', 5, 3) | owo |
substring
Syntax: substring(str, start, length)
| start | Start position for extracting the substring. Valid values start from 1. | Integer | Yes |
Example: SELECT SUBSTRING('helloworld', 5), SUBSTRING('helloworld', 5, 3)
| Scenario 1 | SUBSTRING('helloworld', 5) | oworld |
| Scenario 2 | SUBSTRING('helloworld', 5, 3) | owo |
length
This function returns the length of the input characters (for a string expression) or the byte length (for a non-string expression). The byte length is at least the smallest integer obtained by dividing the number of digits by 8.
Syntax: length(str)
Example: SELECT LENGTH('HELLO WORLD')
| Scenario | LENGTH('HELLO WORLD') | 11 |
char_length
This function returns the length of the input characters (for a string expression) or the byte length (for a non-string expression). The byte length is at least the smallest integer obtained by dividing the number of digits by 8. This function is equivalent to the length function.
Syntax: char_length(str)
Example: SELECT CHAR_LENGTH('HELLO WORLD')
| Scenario | CHAR_LENGTH('HELLO WORLD') | 11 |
character_length
Syntax: character_length(str)
Example: SELECT CHARACTER_LENGTH('HELLO WORLD')
| Scenario | CHARACTER_LENGTH('HELLO WORLD') | 11 |
strlen
Syntax: strlen(str)
Example: SELECT STRLEN('HELLO WORLD')
| Scenario | STRLEN('HELLO WORLD') | 11 |
levenshtein_distance
This function calculates the minimum edit distance between strings str1 and str2.
Syntax: levenshtein_distance(str1, str2)
| str1 | Original string 1. | String | Yes |
| str2 | Original string 2. | String | Yes |
Example: SELECT LEVENSHTEIN_DISTANCE('horse', 'ros')
| Scenario | LEVENSHTEIN_DISTANCE('horse', 'ros') | 3 |
normalize
This function formats a string (str).
- Formats str using the NFC form.
Syntax: normalize(str)
- Formats str using a specified form. The supported forms include NFC, NFD, NFKC, and NFKD.
Syntax: normalize(str, form)
| form | Formatting form. | String | No |
Example: SELECT NORMALIZE('schön'), NORMALIZE('Henry \u2163', 'nfd')
| Scenario 1 | NORMALIZE('schön') | schön |
| Scenario 2 | NORMALIZE('Henry \u2163', 'nfd') | Henry IV |
to_utf8
This function converts a string to the UTF-8 encoding format.
Syntax: to_utf8(str)
Example: SELECT TO_UTF8('%')
| Scenario | TO_UTF8('%') | JQ== |
chr
This function converts an ASCII value to characters.
Syntax: chr(ascii)
| ascii | ASCII code. | Integer | Yes |
Example: SELECT CHR(99)
| Scenario | CHR(99) | c |
concat
This function concatenates multiple parameters into a string.
Syntax: concat(x, y...)
| x,y... | Original field. | String | Yes |
Example: select concat('1','+','1')
| Scenario | concat('1','+','1') | 1+1 |
