Updated on 2026-02-11 GMT+08:00
Character Set Check
str_isalnum
Checks whether a string contains only letters and digits.
  • Function format
    str_isalnum(value)
  • Parameter description
    Type
    Mandatory
    value
    Any (automatically converted to string)
    Yes
    String to be checked.
  • Returned result
    true/false.
  • Function example
    • Test data
       "value": "ltsv5"
    • Processing rule
      e_set("str_isalnum", str_isalnum(v("value")))
    • Processing result
      value: ltsv5
      str_isalnum: true
str_isalpha
Checks whether a string consists of only letters.
  • Function format
    str_isalpha(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "value": "ltsv5"
    • Processing rule
      e_set("str_isalpha", str_isalpha(v("value")))
    • Processing result
      value: ltsv5
      str_isalpha: false
str_isascii
Checks whether a string is in ASCII.
  • Function format
    str_isascii(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "value": "{ltsv5}#@"
    • Processing rule
      e_set("str_isascii", str_isascii(v("value")))
    • Processing result
      value: {ltsv5}#@
      str_isascii: true
str_isdecimal
Checks whether a string consists of only decimal characters.
  • Function format
    str_isdecimal(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "value": "111"
    • Processing rule
      e_set("str_isdecimal", str_isdecimal(v("value")))
    • Processing result
      value: 111
      str_isdecimal: true
str_isdigit
Checks whether a string consists of only digits.
  • Function format
    str_isdigit(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "value": "111"
    • Processing rule
      e_set("str_isdigit", str_isdigit(v("value")))
    • Processing result
      value: 111
      str_isdigit: true
str_isidentifier
Checks whether a string is a valid Python identifier, or checks whether a variable name is valid.
  • Function format
    str_isidentifier(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "key": "int"
    • Processing rule
      e_set("str_isidentifier", str_isidentifier(v("key")))
    • Processing result
      key: int
      str_isidentifier: true
str_islower
Checks whether a string consists of only lowercase letters.
  • Function format
    str_islower(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "key": "lower"
    • Processing rule
      e_set("str_islower", str_islower(v("key")))
    • Processing result
      key: lower
      str_islower: true
str_isnumeric
  • Function format
    str_isnumeric(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "key": "123W"
    • Processing rule
      e_set("str_isnumeric", str_isnumeric(v("key")))
    • Processing result
      key: 123W
      str_isnumeric: false
str_isprintable
Checks whether all characters in a string are printable characters.
  • Function format
    str_isprintable(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
        "key": "@#11!"
    • Processing rule
      e_set("str_isprintable",  str_isprintable(v("key")))
    • Processing result
      key: @#11!
      str_isprintable: true
str_isspace
Checks whether a string consists of only space characters.
  • Function format
    str_isspace(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
        "key": "@#11!"
    • Processing rule
      e_set("str_isspace",  str_isspace(v("key")))
    • Processing result
      key: @#11!
      str_isspace: false
str_istitle
Checks whether the first letter of each word in a string is uppercase and whether other letters are lowercase.
  • Function format
    str_istitle(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "key":"Lts Is A Log Service"
    • Processing rule
      e_set("str_istitle", str_istitle(v("key")))
    • Processing result
      key: Lts Is A Log Service
      str_istitle: true
str_isupper
Checks whether all letters in a string are uppercase.
  • Function format
    str_isupper(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
    true/false.
  • Function example
    • Test data
       "key":"LTS"
    • Processing rule
      e_set("str_isupper", str_istitle(v("key")))
    • Processing result
      key: LTS
      str_isupper: true
str_uuid
Randomly generates a UUID.
  • Function format
    str_uuid(lower=true)
    Type
    Mandatory
    lower
    Boolean
    No
    Whether the letters in the generated UUID are in lowercase. The default value is true, indicating that the letters are in lowercase.
  • Returned result
    true/false.
  • Function example
    • Test data
    • Processing rule
      e_set("UUID", str_uuid())
    • Processing result
      UUID: 1acf7e1d-5a6b-4267-b7c1-874c8b70745d
