Updated on 2025-11-18 GMT+08:00
Search, Split, and Format
str_count
Calculates the number of occurrences of a character in a string.
  • Function format
    str_count(value, sub, start, end)
  • Parameter description
    Type
    Mandatory
    value
    Any (automatically converted to string)
    Yes
    Original string to be counted.
    sub
    Yes
    Characters to be counted.
    start
    Number
    No
    Position where the search starts.
    • 0 (default value): first character.
    • –1: last character.
    end
    Number
    No
    Position where the search ends.
    • 0: first character.
    • –1 (default value): last character.
  • Returned result
    Returns the number of occurrences of a specified character.
  • Function example
    • Test data
        "name":  "lts is a log service"
    • Processing rule
      e_set("str_count", str_count(v("name"), "l"))
    • Processing result
      name:  lts is a log service
      str_count: 2
str_find
Checks whether the original string contains the specified substring.
  • Function format
    str_find(value, str, begin, end)
    Type
    Mandatory
    value
    Yes
    Original string to be searched.
    str
    Yes
    Substring to be searched.
    begin
    Number
    No
    Start index. The default value is 0, indicating the first character. The value –1 indicates the last character.
    end
    Number
    No
    End index. The default value is the length of the string. The value 0 indicates the first character, and the value –1 indicates the last character.
  • Returned result
    Returns the position of the first occurrence of the specified substring within the original string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_find",str_find(v("name"), "l"))
    • Processing result
      str_find: 0
str_rfind
  • Function format
    str_rfind(value, substr, beg, end)
    Type
    Mandatory
    value
    Yes
    substr
    Yes
    Character to be searched.
    beg
    Number
    No
    Start position of the search. The default value is 0.
    end
    Number
    No
    End position of the search. The default value is the length of the string.
  • Returned result
    Returns the position of the last appearance of a character or string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_rfind", str_rfind(v("name"), "i"))
    • Processing result
      str_rfind: 17
str_endswith
Checks whether a string ends with a specified suffix.
  • Function format
    str_endswith(value, suffix, start, end)
    Type
    Mandatory
    value
    Yes
    Original character string to be checked.
    suffix
    Yes
    Suffix rule. This parameter can be a string or an element.
    start
    Number
    No
    Start position of the string to be checked. The value 0 indicates the first character, and the value –1 indicates the last character.
    end
    Number
    No
    End position of the string to be checked. The value 0 indicates the first character, and the value –1 indicates the last character.
  • Returned result
    Returns true if the string ends with the specified suffix, and returns false otherwise.
  • Function example
    • Test data
    • Processing rule
      e_set("str_endswith",str_endswith(v("name"), "service"))
    • Processing result
      str_endswith: true
str_startswith
Checks whether a string starts with specified characters.
  • Function format
    str_startswith(value, prefix, start, end)
    Type
    Mandatory
    value
    Yes
    prefix
    Yes
    Prefix rule. This parameter can be a string or an element.
    start
    Number
    No
    end
    Number
    No
  • Returned result
    Returns true if the string starts with the specified prefix, and returns false otherwise.
  • Function example
    • Test data
    • Processing rule
      e_set("str_startswith",str_startswith(v("name"), "lts"))
    • Processing result
      str_startswith: true
str_split
Splits a string by specifying delimiters.
  • Function format
    str_split(value, sep=None, maxsplit=-1)
    Type
    Mandatory
    value
    Yes
    Original string to be split.
    sep
    Number
    No
    Separator. None indicates a space.
    maxsplit
    Number
    No
    Maximum number of splits. –1 indicates no limit.
  • Returned result
    Processed string.
  • Function example
    • Test data
       "content": "lts,a,log,service"
    • Processing rule
      e_set("str_split", str_split(v("content"), ","))
    • Processing result
      content: lts,a,log,service
      str_split: ["lts","a","log","service"]
str_splitlines
Splits a string by specifying newline characters.
  • Function format
    str_splitlines(value, keepends)
    Type
    Mandatory
    value
    Yes
    keepends
    Boolean
    No
    Whether to remove line breaks (\r, \r\n, and \n) from the output. The default value is false, indicating that line breaks are not contained. If the value is true, line breaks are retained.
  • Returned result
    Processed list.
  • Function example
    • Test data
       "value": "lts\nis\ra\r\n"
    • Processing rule
      e_set("str_splitlines", str_splitlines(v("value"), false))
    • Processing result
      value: lts\nis\ra\r\n
      str_splitlines: ['lts','is','a']
str_partition
Splits a string into three parts from left to right based on the specified delimiters.
  • Function format
    str_partition(value, substr)
    Type
    Mandatory
    value
    Yes
    String to be split.
    substr
    No
    Specified separator.
  • Returned result
    List after splitting.
  • Function example
    • Test data
       "address":"big.middle.small"
    • Processing rule
      e_set("str_partition", str_partition(v("address"), "."))
    • Processing result
      address: big.middle.small
      str_partition: ["big",".","middle.small"]
str_rpartition
Splits a string into three parts from right to left based on the specified delimiters.
  • Function format
    str_rpartition(value, substr)
    Type
    Mandatory
    value
    Yes
    substr
    No
  • Returned result
  • Function example
    • Test data
    • Processing rule
      e_set("str_partition", str_rpartition(v("address"), "."))
    • Processing result
      str_partition: ["big.middle",".","small"]
str_center
Expands a string to a specified length with specified characters.
  • Function format
    str_center(value, width, fillchar)
    Type
    Mandatory
    value
    Yes
    Original string to be modified.
    width
    Number
    Yes
    Total length of the string after padding.
    fillchar
    No
    Padding character. The default value is a space.
  • Returned result
    Processed string.
  • Function example
    • Test data
       "value": "lts is a log service"
    • Processing rule
      e_set("str_center", str_center(v("value"), 40, "*"))
    • Processing result
      center: lts is a log service
      str_center: **********lts is a log service**********
str_ljust
Expands a string to a specified length with specified characters starting from the end of the string.
  • Function format
    str_ljust(value, width, fillchar)
    Type
    Mandatory
    value
    Yes
    width
    Number
    Yes
    fillchar
    No
  • Returned result
    Processed string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_ljust", str_ljust(v("value"), 30, "*"))
    • Processing result
      value: lts is a log service
      str_ljust: lts is a log service**********
str_rjust
Expands a string to a specified length with specified characters starting from the beginning of the string.
  • Function format
    str_rjust(value, width, fillchar)
    Type
    Mandatory
    value
    Yes
    width
    Number
    Yes
    fillchar
    No
  • Returned result
    Processed string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_rjust", str_rjust(v("value"), 30, "*"))
    • Processing result
      str_ljust: **********lts is a log service
str_zfill
Expands a string to a specified length with the character 0 starting from the beginning of the string.
  • Function format
    str_zfill(value, width)
    Type
    Mandatory
    value
    Yes
    width
    Number
    Yes
  • Returned result
    Processed string.
  • Function example
    • Test data
       "value": "this is lts"
    • Processing rule
      e_set("str_zfill", str_zfill(v("value"), 20))
    • Processing result
      value: this is lts
      str_zfill: 000000000this is lts
str_expandtabs
Converts \t in a string to a space.
  • Function format
    str_expandtabs(value, tabsize)
    Type
    Mandatory
    value
    Yes
    tabsize
    Number
    No
    Number of spaces after conversion.
  • Returned result
    Processed string.
  • Function example
    1. Example 1: Converts the \t character in the key to a space.
      • Test data
         "key": "this is\tlts"
      • Processing rule
        e_set("str_expandtabs", str_expandtabs(v("key")))
      • Processing result
        key: this is\tlts
        str_expandtabs: this is lts
    2. Example 2: Converts the \t character in the key to a space and pads the specified number of spaces.
      • Test data
      • Processing rule
        e_set("str_expandtabs", str_expandtabs(v("key"), 5))
      • Processing result
        key: this is\tlts
