Updated on 2025-11-18 GMT+08:00
Common Operations
str_strip
Deletes specified characters from a string.
  • Function format
    str_strip(value, chars)
  • Parameter description
    Type
    Mandatory
    value
    Any (automatically converted to string)
    Yes
    Original string to be modified.
    chars
    No
    Character set to be deleted at the beginning and end of a character string. The default value is \t\r\n.
  • Returned result
    Modified string.
  • Function example
    1. Example 1: Deletes spaces.
      • Test data
          "source":"      lts"
      • Processing rule
        e_set("str_strip", str_strip(v("source")))
      • Processing result
        source:      lts
        str_strip: lts
    2. Example 2: Deletes # characters at the beginning and end of a string.
      • Test data
          "source": "##lts#"
      • Processing rule
        e_set("str_strip", str_strip(v("source"), "#"))
      • Processing result
        source: ##lts#
        str_strip: lts
str_lstrip
Deletes specified characters at the beginning of a string.
  • Function format
    str_lstrip(value, chars)
    Type
    Mandatory
    value
    Yes
    chars
    No
    Character set to be deleted at the beginning of a character string. The default value is a space.
  • Returned result
    Modified string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_strip", str_lstrip("**123**", "*"))
    • Processing result
      str_strip: 123**
str_rstrip
Deletes specified characters at the end of a string.
  • Function format
    str_rstrip(value, chars)
    Type
    Mandatory
    value
    Yes
    chars
    No
    Character set to be deleted at the end of a character string. The default value is a space.
  • Returned result
    Modified string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_strip", str_rstrip("**123**", "*"))
    • Processing result
      str_strip: **123
str_lower
Converts all uppercase characters in a string to lowercase characters.
  • Function format
    str_lower(value)
    Type
    Mandatory
    value
    Yes
    String to be converted.
  • Returned result
    String after conversion.
  • Function example
    • Test data
       "name": "LTs"
    • Processing rule
      e_set("str_lower", str_lower(v("name")))
    • Processing result
      str_lower: lts
str_upper
Converts all lowercase characters in a string to uppercase characters.
  • Function format
    str_upper(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
  • Function example
    • Test data
       "name": "LTs"
    • Processing rule
      e_set("str_upper", str_upper(v("name")))
    • Processing result
      str_upper: LTS
str_title
Converts the first letter of each word in a string to uppercase and the other letters to lowercase.
  • Function format
    str_title(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
  • Function example
    • Test data
        "name":  "for example"
    • Processing rule
      e_set("str_title", str_title(v("name")))
    • Processing result
      str_title: For Example
str_capitalize
Converts the first letter of a string to uppercase and the other letters to lowercase.
  • Function format
    str_capitalize(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
  • Function example
    • Test data
        "value": "welcome to xian"
    • Processing rule
      e_set("str_capitalize", str_capitalize(v("value")))
    • Processing result
      value: welcome to xian
      str_capitalize: Welcome to xian
str_swapcase
Converts the uppercase and lowercase letters of a string.
  • Function format
    str_swapcase(value)
    Type
    Mandatory
    value
    Yes
  • Returned result
  • Function example
    • Test data
       "name": "this is lts"
    • Processing rule
      e_set("str_swapcase", str_swapcase(v("name")))
    • Processing result
      name: this is lts
      str_swapcase: THIS IS LTS
