Multiple Character Strings, Sorting, Inversion, and Replacement
str_format
Formats a string in a specified format.
- Function format
str_format(format, str1, str2, ...)
- Parameter description
Type
Mandatory
format
string
Yes
Format after conversion
str1
Any
Yes
Value 1 to be formatted
str2
Any
Yes
Value 2 to be formatted
- Returned result
Formatted string.
- Function example
- Test data
{} - Processing rule
e_set("result", str_format("{}={}", "lts", 8)) - Processing result
result: lts=8
- Test data
str_join
Generates a new string by connecting the input strings using a connector.
- Function format
str_join(connector, str1, str2, ...)
Type
Mandatory
connector
Any (automatically converted to string)
Yes
Connector, for example, number sign (#), dollar sign ($), and percent (%).
str1
Yes
Value 1 to be connected.
str2
Yes
Value 2 to be connected.
- Returned result
Concatenated character string.
- Function example
- Test data
e_set("email", str_join("@", "lts", "aa", "com")) - Processing result
email: lts@aa@com
- Test data
str_zip
Splits the strings of two values or expressions concurrently and then combines them into one string.
- Function format
str_zip(value1,value2,combine_sep=None,sep=None,quote=None,lparse=None,rparse=None)
Type
Mandatory
value1
Yes
Values to be combined.
value2
Yes
combine_sep
No
Identifier for combining elements. The default value is #.
sep
No
Separator between elements after combination. Only a single character is supported. The default value is ,.
quote
No
Character used to enclose combined elements. This parameter is required when the value contains a separator. The default value is ".
lparse
No
Separator and quotation mark between elements in value1. The default separator is , and the default quotation mark is ". The format is lparse =(',', '"').
Note: The quotation mark takes precedence over the separator.
rparse
No
Separator and quotation mark between elements in value2. The default separator is , and the default quotation mark is ". The format is rparse =(',', '"').
- Returned result
Combined character string.
- Function example
- Example 1: sep usage.
- Test data
{ "key1": "value1,value11", "key2": "value2,value21" } - Processing rule
e_set("combine", str_zip(v("key1"), v("key2"), sep="|")) - Processing result
key1: value1,value11 key2: value2,value21 combine: value1#value2|value11#value21
- Test data
- Example 2: Use of quote.
- Test data
{ "key1": "\"value1, value2\", value3, \"value4,value5\"", "key2": "value11,\"value12,value13\",value14" } - Processing rule
e_set("combine", str_zip(v("key1"), v("key2"), quote='|')) - Processing result
key1: "value1, value2", value3, "value4,value5" key2: value11,"value12,value13",value14 combine: |value1,value2#value11|,|value3#value12,value13|,|value4,value5#value14|
- Test data
- Example 3: Values of different lengths.
- Test data
{ "key1": "value1,value2", "key2": "value11,value12,value13" } - Processing rule
e_set("combine", str_zip(v("key1"), v("key2"))) - Processing result
key1: value1,value2 key2: value11,value12,value13 combine: value1#value11,value2#value12
- Test data
- Example 4: Usage of lparse and rparse.
- Test data
{ "key1": "|value1, value1|, value2, |value3,value3|", "key2": "value11, #value12,value12#, value13" } - Processing rule
e_set("combine", str_zip(v("key1"), v("key2"), lparse=(",", '|'), rparse=(",", '#'))) - Processing result
key1: |value1, value1|, value2, |value3,value3| key2: value11, #value12,value12#, value13 combine: "value1,value1#value11","value2#value12,value12","value3,value3#value13"
- Test data
str_sort
Sorts the characters within a string.
- Function format
str_sort(value, reverse=false)
Type
Mandatory
value
Yes
Original string to be sorted.
reverse
Boolean
No
The default value is false, indicating that the values are sorted in ascending order.
- Returned result
Sorted string.
- Function example
- Test data
{ "key1": "value" } - Processing rule
e_set("str_sort", str_sort(v("key1"))) - Processing result
key1: value str_sort: aeluv
- Test data
str_reverse
Reverses a string.
- Function format
str_reverse(value)
Type
Mandatory
value
Yes
Value to be reversed.
- Returned result
Reversed string.
- Function example
- Test data
{ "data": "switch" } - Processing rule
e_set("reverse_data", str_reverse(v("data"))) - Processing result
data: switch reverse_data: hctiws
- Test data
str_replace
Replaces an old string with a new string according to rules.
- Function format
str_replace(value, old, new, count)
Type
Mandatory
value
Yes
Value to be replaced.
old
Yes
String to be replaced.
new
Yes
New string after replacement.
count
Number
No
Number of replacement times. This parameter is optional. If count is not set, all occurrences will be replaced.
- Returned result
- Function example
- Test data
e_set("str_replace", str_replace("this is string example", "is", "was")) - Processing result
str_replace: thwas was string example
- Test data
str_translate
Replaces specified characters in a string based on the mapping.
- Function format
str_translate(value, replace_string, mapping_string)
Type
Mandatory
value
Yes
Original string to be replaced.
replace_string
Yes
Character set to be replaced.
mapping_string
Yes
Character set after replacement.
- Returned result
Processed string.
- Function example
- Test data
e_set("str_translate", str_translate("lts", "ts", "34")) - Processing result
str_translate: l34
- Test data
