Overview
This section describes string functions, including their syntax, parameters, and usage examples.
Function List
Type |
Function |
Description |
Multi-string operations |
Formats a string in a specified format. |
Generates a new string by connecting the input strings using a connector. |
Splits the strings of two values or expressions concurrently and then combines them into one string. |
Sorting, inversion, and replacement |
Sorts strings. |
Reverses a string. |
Replaces an old string with a new string according to rules. |
Replaces specified characters in a string based on the mapping. |
Common operations |
Deletes specified characters from a string. |
Deletes specified characters at the beginning of a string. |
Deletes specified characters at the end of a string. |
Converts all uppercase characters in a string to lowercase characters. |
Converts all lowercase characters in a string to uppercase characters. |
Converts the first letter of each word in a string to uppercase and the other letters to lowercase. |
Converts the first letter of a string to uppercase and the other letters to lowercase. |
Converts the uppercase and lowercase letters of a string. |
Search and judgment |
Calculates the number of occurrences of a character in a string. |
Checks whether the original string contains the specified substring. |
Searches for the last occurrence of specified characters a string. |
Checks whether a string ends with a specified suffix. |
Checks whether a string starts with specified characters. |
Splitting |
Splits a string by specifying delimiters. |
Splits a string by specifying newline characters. |
Splits a string into three parts from left to right based on the specified delimiters. |
Splits a string into three parts from right to left based on the specified delimiters. |
Format |
Expands a string to a specified length with specified characters. |
Expands a string to a specified length with specified characters starting from the end of the string. |
Expands a string to a specified length with specified characters starting from the beginning of the string. |
Expands a string to a specified length with the character 0 starting from the beginning of the string. |
Converts \t in a string to a space. |
Character set check |
Checks whether a string consists of only letters and digits. |
Checks whether a string consists of only letters. |
Validates whether a string contains only ASCII characters. |
Checks whether a string consists of only decimal characters. |
Checks whether a string consists of only digits. |
Checks whether a string is a valid Python identifier. |
Checks whether a string consists of only lowercase letters. |
Checks whether all characters in a string are printable characters. |
Checks whether a string consists of only space characters. |
Checks whether the first letter of each word in a string is uppercase and whether other letters are lowercase. |
Checks whether all letters in a string are uppercase. |
Randomly generates a UUID. |
