Updated on 2026-02-11 GMT+08:00
Process Control Functions
This section describes process control functions, including their syntax, parameters, and usage examples.
Function List
Function
e_compose
Combines a series of operations.
  • This function is often used with the e_if, e_switch, or e_if_else function to combine operations.
  • It calls operations one by one, transfers and converts logs, and returns the final log.
  • If an operation deletes a log, subsequent operations are not performed.
This function can be used together with other functions.
e_if
Combines conditions and operations.
  • If a condition is met, the corresponding operation is performed. If a condition is not met, the flow proceeds to the next condition.
e_if(
e_has("a"), e_output("target-a"),
e_has("b"), e_output("target-b"),
For example, the processing rule is equivalent to the following Python code structure:
if e_has("a"):
if e_has("b"):
e_if_else
Performs operations based on the condition judgment result.
e_if_else(e_has("a"), e_output("target-a"), e_output("target-b"))
if e_has("a"):
else:
e_switch
  • If a condition is met, the corresponding operation is performed and the result is returned. If a condition is not met, the flow proceeds to the next condition.
  • If no condition is met but default parameters are configured, the operation of the default configuration is performed and the result is returned.
e_switch(
default=e_output("target-default"),
if e_has("a"):
elif e_has("b"):
else:
e_compose
Merges multiple operations.
  • Function format
    e_compose(operation 1, operation 2, ...)
  • Parameter description
    Type
    Mandatory
    Operation 1
    Global operation function
    Yes
    Global operation function or combination of global operation functions.
    Operation 2
    No
  • Returned result
    Logs after the operation.
  • Function example
    If the value of the content field is 123, delete the age and name fields, and then set the value of the content field to ctx.
    • Test data
       "content": 123,
       "age": 23,
       "name": "twiss"
    • Processing rule
      e_if(
          e_search("content==123"),
          e_compose(e_drop_fields("age|name"),
       e_rename("content", "ctx")),
    • Processing result
      ctx: 123
  • More
e_if
This function performs operations based on judgment conditions.
  • Function format
    e_if(Condition, Operation)
    e_if(Condition1, Operation1, Condition2, Operation2, ...)
    The conditions and operations in the function must appear in pairs.
    Type
    Mandatory
    Condition
    Any
    Yes
    Expression or combination of expressions. If the result is not a Boolean value, the system determines whether the result is true or false.
    Operation
    No
  • Returned result
    Processed logs.
  • Function example
    1. Example 1: Perform operations after field value matching.
      If the value of result is failed or failure, set the value of __topic__ to login_failed_event.
      • Test data
         "result": "failed"
      • Processing rule
        e_if(e_match("result", r"failed|failure"), e_set("__topic__", "login_failed_event"))
      • Processing result
        result: failed
        __topic__: login_failed_event
    2. Example 2: Extract data based on the field value.
      If the request_body field exists and is not empty, call the field operation function json to expand the request_body field into multiple values.
      • Test data
          "request_body": {
            "k1": 100,
            "k2": 200
      • Processing rule
        e_if(v("request_body"), e_json("request_body"))
      • Processing result
        request_body: {"k1": 100, "k2": 200}
        k1: 100
        k2: 200
    3. Example 3: Perform operations after advanced judgment.
      If the value of valid is failed (in lowercase), the log is discarded.
      • Test data
         "valid":"failed"
      • Processing rule
        e_if(op_eq(str_lower(v("valid")), "failed"),  e_drop())
      • Processing result: The log is discarded.
    4. Example 4: Perform operations based on the condition sequence.
      • Test data
         "valid":"failed"
      • Processing rule
        e_if(True, e_set("__topic__", "default_login"),   e_match("valid", "failed"), e_set("__topic__", "login_failed_event"))
      • Processing result
        valid: failed
        __topic__:login_failed_event
  • More
e_if_else
This function performs operations based on the condition judgment result.
  • Function format
    e_if_else (Condition, Operation when the condition is true, Operation when the condition is false)
    Type
    Mandatory
    Condition
    Any
    Yes
    Yes
    Yes
  • Returned result
    Operation result corresponding to different conditions.
  • Function example
    If the value of the result field is ok or pass, or the value of the status field is 200, the log is retained.
    • Test data
      Test data 1:
      "result":"ok",
      "status": 400
      Test data 2:
      "result": "Pass",
      "status": 200
      Test data 3:
      "result": "failure",
      "status": 500
    • Processing rule
      e_if_else(
          op_or(e_match("result", r"(?i)ok|pass"), e_search("status== 200")), e_keep(),e_drop()
    • Processing result
      result: ok
      status: 400
      result: Pass
      status: 200
e_switch
This function merges multiple conditions and operations.
  • Function format
    e_switch(Condition 1, Operation 1, ..., default=None)
    Note: Conditions and operations must appear in pairs in the function.
    Type
    Mandatory
    Condition
    Any
    Yes
    Operation
    Yes
    default
    No
    Default global operation function or combination of global operation functions. This operation is performed when no condition is met.
  • Returned result
    Processed logs.
  • Function example
    1. If the value of the content field is 123, set the value of __topic__ to Number. If the value of the data field is 123, set the value of __topic__ to PRO.
      • Test data
        Test data 1:
        "__topic__": ,
        "age": 18,
        "content": 123,
        "name":"maki",
        "data": 342
        Test data 2:
        "__topic__": ,
        "age": 18,
        "content": 23,
        "name": "maki" ,
        "data": 123
      • Processing rule
        e_switch(
            e_set("__topic__", "Number", mode="overwrite"),
            e_search("data==123"),
            e_set("__topic__", "PRO", mode="overwrite"),
      • Processing result
        __topic__: Number
        content: 123
        data: 342
        __topic__: PRO
        content: 23
        data: 123
    2. This function merges the e_switch and e_output syntax to deliver logs that meet the rules to different log streams. default=e_drop() indicates that logs that do not meet the rules are discarded. If the default parameter is not specified, all logs that do not meet the rules are delivered to the first configured log stream.
      The output processing result will not be displayed in the processing result box.
      • Test data
        "__topic__": "sas-log-dns" ,
        "test": "aa" ,
        "__topic__": "aegis-log-network",
        "test":"ecs" ,
        "__topic__": "local-dns" ,
        "test":"sls" ,
        "__topic__": "aegis-log-login" ,
        "test": "sls"
      • Processing rule
        e_switch(e_match("__topic__","sas-log-dns"),
        e_output(name="target1"),
        e_match("__topic__","sas-log-process"),
        e_output(name="target2"),
        e_match("__topic__","local-dns"),
        e_output(name="target3"),
        e_match("__topic__","aegis-log-network"),
        e_output(name="target4"),
        e_match("__topic__","aegis-log-login"),
        e_output(name="target5"),
        default=e_drop())
  • More
