Updated on 2026-02-11 GMT+08:00
Field Operation Functions
This section describes field operation functions, including their syntax, parameters, and usage examples.
Function List
Function
v
Obtains the value of a specific field in a log. When multiple field names are input at the same time, the value of the first existing field in the log is returned. This function can be used together with other functions.
e_set
Adds a new field or sets a new value for an existing field. This function can be used together with other functions.
e_drop_fields
Deletes log fields that meet conditions. This function can be used together with other functions.
e_keep_fields
Retains the log fields that meet conditions.
e_pack_fields
Packs log fields and outputs them to new fields.
e_rename
Renames the log field that meets conditions. This function can be used together with other functions.
v
This function obtains the value of a specified log field. When multiple field names are input at the same time, the value of the first existing field in the log is returned.
  • Function format
    v(key, ..., default=None)
  • Parameter description
    Type
    Mandatory
    key
    String
    Yes
    Field name.
    default
    Any
    No
    If the specified field name does not exist, the value of default is returned. The default value is None.
  • Returned result
    The value of the first field found in the log. If the field does not exist, the value of default is returned.
  • Function example
    Assign the value of the content field to the test_content field.
    • Test data
       "content": "hello"
    • Processing rule
      e_set("test_content", v("content"))
    • Processing result
      content: hello
      test_content: hello
  • More
e_set
This function adds a new field or sets a new value for an existing field.
  • Function format
    e_set(key1, value1, key2, value2, mode="overwrite")
    • key1 and value1 must be used in pairs.
    • When the e_set function is used to set the time field F_TIME or __time__, the field must be set to a number or string.
    e_set(F_TIME, "abc")   # Incorrect
    e_set(F_TIME, "12345678")   # Correct
    Type
    Mandatory
    key
    String
    Yes
    Target field name, which can also be obtained through a string expression.
    value
    Any
    Yes
    New field value. Non-string values are converted into strings and stored in logs. Tuples, lists, and dictionaries are converted into JSON object strings.
    Note: If the value None is transferred, the update operation is not performed.
    mode
    String
    No
    Field overwrite mode. The default value is overwrite.
  • Returned result
    The updated logs.
  • Function example
    1. Example 1: Set a fixed value for a field.
      Add a new field city whose value is Shanghai.
      • Raw data
      • Processing rule
        e_set("city", "Shanghai")
      • Processing result
        city: Shanghai
    2. Example 2: Copy the field value.
      Call a single expression function to assign the value of the existing field ret to the new field result.
      • Raw data
        {"ret": "value"}
      • Processing rule
        e_set("result", v("ret"))
      • Processing result
        ret: value
        result: value
    3. Example 3: Dynamically set a value.
      Call the combined expression function to obtain the value of the first existing field, return the value in lowercase, and assign the value to the result field.
      • Raw data
          "return": "AAA"
      • Processing rule
        e_set("result", str_lower(v("ret", "return")))
      • Processing result
        return: AAA
        result: aaa
    4. Example 4: Set the field value multiple times.
      • Raw data
                "ret" : "fail"
      • Processing rule
        e_set("event_type", "login event", "event_info", "login host")
      • Processing result
        ret: fail
        event_type: login event
        event_info: login host
  • More
e_drop_fields
This function deletes log fields that meet the specified condition.
  • Function format
    e_drop_fields(key1, key2, ....,regex=false)
    Type
    Mandatory
    key
    String
    Yes
    Log field name, which can be a regular expression. Fields are deleted if their names meet the specified condition. All other fields are retained. For more information about regular expressions, see section "Regular Expression." At least one log field must be configured.
    regex
    Boolean
    No
    If this parameter is set to false, regular expressions are not used for matching. If this parameter is not set, the default value true is used.
  • Returned result
    Logs with fields deleted.
  • Function example
    If the value of the content field is 123, the content and age fields are deleted.
    • Test data
       "age": 18,
       "content": 123,
       "name": "twiss"
    • Processing rule
      e_if(e_search("content==123"), e_drop_fields("content", "age",regex=true))
    • Processing result
  • More
e_keep_fields
This function retains log fields that meet the specified condition.
LTS contains built-in meta fields, such as __time__ and __topic__. If the __time__ field is not retained when the e_keep_fields function is called, the log time is reset to the current system time. If you do not want to reset the value of a meta field, add the meta field to the list. The common format is F_TIME, F_META, F_TAGS, "f1", "f2".
  • Function format
    e_keep_fields(key1, key2, ....,regex=false)
    Type
    Mandatory
    key
    String
    Yes
    Log field name, which can be a regular expression. Fields are retained if their names meet the specified condition. All other fields are deleted. At least one field must be configured.
    regex
    Boolean
    No
  • Returned result
    Logs with retained fields.
  • Function example
    If the value of the content field is 123, the content and age fields are retained.
    • Test data
       "age": 18,
       "content": 123,
       "name": "twiss"
    • Processing rule
      e_if(e_search("content==123"), e_keep_fields("content", "age"))
    • Processing result
      content: 123
e_pack_fields
This function packs log fields and exports them to new fields.
  • Function format
    e_pack_fields(output_fields,include=".*",exclude=None,drop_packed=true)
    Type
    Mandatory
    output_field
    String
    Yes
    Name of the field output after packing. The value is in JSON format.
    include
    String
    No
    Whitelist configuration. Fields that meet the specified regular expression are packed. The default value is .*, indicating that all fields are matched.
    exclude
    String
    No
    Blacklist configuration. Fields that meet the regular expression are not packed. The default value is None, indicating that no matching judgment is performed.
    drop_packed
    Boolean
    No
    Whether to delete the original data after the data is packed. The default value is true.
    • true (default): deletes the original data from the output result after packing.
    • false: does not delete the original data from the output result after packing.
  • Returned result
    Packed log data.
  • Function example
    1. Example 1: Pack all log fields into the test field. By default, the original fields are deleted.
      • Test data
         "test1":123,
         "test2":456,
         "test3":789
      • Processing rule
        e_pack_fields("test")
      • Processing result
        test:{"test1": 123, "test2": 456, "test3": 789}
    2. Example 2: Pack all log fields into the test field. By default, the original fields are not deleted.
      • Test data
         "test1":123,
         "test2":456,
         "test3":789
      • Processing rule
        e_pack_fields("test",drop_packed=false)
      • Processing result
        test1:123
        test2:456
        test3:789
    3. Example 3: Pack the test and abcd fields into the content field. The original fields are not deleted.
      • Test data
         "abcd@#%":123,
         "test":456,
         "abcd":789
      • Processing rule
        e_pack_fields("content", include="\w+", drop_packed=false)
      • Processing result
        abcd:789
        abcd@#%:123
        content:{"test": 456, "abcd": 789}
        test:456
    4. Example 4: The test and abcd fields are not packed. Other fields are packed into the content field. The original fields are deleted.
      • Test data
         "abcd@#%":123,
         "test":456,
         "abcd":789
      • Processing rule
        e_pack_fields("content", exclude="\w+", drop_packed=true)
      • Processing result
        abcd:789
        content:{"abcd@#%": "123"}
        test:456
e_rename
This function renames log fields that meet the specified condition.
  • Function format
    e_rename("key1", "new key1", "key2", "new key2", ..., regex=false)
    The key and new key fields must be used in pairs.
    Type
    Mandatory
    key
    String
    Yes
    Log field name, which can be a regular expression. If a field name meets the specified condition, the field name is renamed. At least one field must be configured.
    new key
    String
    Yes
    New field name after renaming.
    regex
    Boolean
    No
  • Returned result
    Renamed fields.
  • Function example
    1. Example 1: Rename the host field to client_host.
      • Test data
         "host": 1006
      • Processing rule
        e_rename("host","client_host")
      • Processing result
        client_host: 1006
    2. Example 2: If no matching field is found, no fields will be renamed.
      • Test data
         "host": 1006
      • Processing rule
        e_rename("url","rename_url")
      • Processing result
        host: 1006
  • More
