Event Check Functions
This section describes event check functions, including their syntax, parameters, and usage examples.
Function List
| Type | Function | Description |
| Basic methods | Checks whether a specified log field exists. | |
| Checks whether a specified log field does not exist. This function can be used together with other functions. | ||
| Expression functions | Provides a simplified event search mode similar to the Lucene syntax. This function can be used together with other functions. | |
| Checks whether the values of the current log fields meet a specified regular expression condition. This function can be used together with other functions. | ||
| Checks whether the values of the current log fields meet a specified regular expression condition. If any field meets the condition, true is returned. Otherwise, false is returned. | ||
| Checks whether the values of the current log fields meet a specified regular expression condition. If all field meets the condition, true is returned. Otherwise, false is returned. |
The event check functions can be used together with the following expression functions:
| Basic judgment | Performs the logical AND operation. | |
| Performs the logical OR operation. | ||
| Performs the logical NOT operation. | ||
| Determines the values of two expressions. | ||
| Returns the first expression value that is not None. | ||
e_has
This function checks whether a specified field exists.
- Function format
e_has("key") - Parameter description
Type
Mandatory
key
String
Yes
Log field name.
- Returned result
If the field exists, true is returned. If the field does not exist, false is returned.
- Function example
Check whether the content field exists in the following log. If it exists, the log is retained. If it does not exist, the log is discarded.
- Test data
{ "content": 123 } - Processing rule
e_keep(e_has("content")) - Processing result
content: 123
- Test data
e_not_has
This function checks whether a specified field does not exist.
- Function format
e_not_has("key") - Parameter description
Type
Mandatory
key
String
Yes
Field name.
- Returned result
If the field does not exist, true is returned. If the field exists, false is returned.
- Function example
Check whether the content field exists in the following log. If it does not exist, the log is retained. If it exists, the log is discarded.
- More
e_search
This function provides a simplified event search mode similar to the Lucene syntax. This feature is currently in closed beta testing. The e_search function is only designed to process a small amount of log traffic. Use it with caution.
- Function format
e_search(querystring)
Type
Mandatory
querystring
String
Yes
Query string, which is used to quickly filter logs.
- Returned result
If the condition is met, true is returned. Otherwise, false is returned.
- Function reference example
# Full text e_search("active error")# Full text: searches for logs containing either the substring active or error. The default relationship between them is OR. e_search('"active error"') # Full text: searches for active error as a substring. # Field: string e_search("status: active") # Searches for a word. e_search('author: "john smith"') # Searches for a substring with spaces. e_search('field: active error') # Equivalent to field:active OR "error". # Exact match e_search('author== "john smith"') # Wildcard search. The asterisk (*) matches zero or more characters, and the question mark (?) matches one character. e_search("status: active*test") # active*test contains only asterisks (*). It does not need to be enclosed in double quotation marks (""). e_search("status: active?good") # active?good contains only question marks (?). It does not need to be enclosed in double quotation marks (""). e_search("status== ac*tive?good") # Exact match. # Escape the searches value. The asterisk (*) or question mark (?) must be escaped using a backslash (\). e_search('status: "\*\?()[]:="') # \*\?()[]:= contains special characters. Use double quotation marks ("") to enclose the special characters. Only the asterisk (*), question mark (?), and backslash (\) need to be escaped. e_search("status: active\*test") # active\*test contains only asterisks (*). You do not need to enclose the asterisks in double quotation marks (""). e_search("status: active\?test") # active\?test contains only question marks (?), you do not need to enclose the question marks in double quotation marks (""). # Field name escape e_search("\*\(1+1\)\?: abc") # The field name cannot be enclosed in double quotation marks (""). Special characters are escaped using backslashes (\). e_search("__tag__\:__container_name__: abc") # Use backslashes (\) for escaping. e_search("Chinese field: abc") # Write Chinese characters directly. # Regular expression matching e_search('content~="Regular expression"') # Regular expression matching. # Number e_search('count: [100, 200]') # >=100 and <=200 e_search('count: [*, 200]') # <=200 e_search('count: [200, *]') # >=200 e_search('age >= 18') # >= 18 e_search('age > 18') # > 18 # Use relational operators. e_search("abc OR xyz") # Relational operators are case insensitive. OR and or are the same. e_search("abc and (xyz or zzz)") e_search("abc and not (xyz and not zzz)") e_search("abc && xyz") # and e_search("abc || xyz") # or e_search("abc || !xyz") # or not - Function example
- Test data
{ "desc": "john smith is a player" } - Processing rule
e_if(e_search('desc: "john smith"'), e_set("found", "Yes")) - Processing result
{ "found": "Yes", "desc": "john smith is a player" }
- Test data
- More
e_match
This function checks whether the values of the current log fields meet a specified regular expression condition.
- Function format
e_match(key, regular_expression, full=true)
The e_match function is usually used together with the op_not, op_and, or op_or functions.
Type
Mandatory
key
String
Yes
Field name. If the specified field does not exist, the current sub-condition will not be met. For example, if the f1 field does not exist, the result of e_match("f1",...) is false.
regular_expression
String
Yes
Regular expression. If pure string matching (non-regular expression) is required, you can use the str_regex_escape function to modify the regular expression.
full
Bool
No
Whether the match is exact. The default value is true, indicating exact match.
- Returned result
Judgment result of field matching: true or false.
- Function example
Check whether the value of the field k1 is a digit.
- Test data
{ "k1": 123 } - Processing rule
e_set("e_match", e_match("k1",r'\d+')) - Processing result
k1: 123 match: true
- Test data
- More
e_match_any
This function checks whether the values of the current log fields meet a specified regular expression condition. If any field meets the condition, true is returned. Otherwise, false is returned.
- Function format
e_match_any(key1, regular_expression1, key2, regular_expression2, ..., full=true)
- The key and regular_expression parameters must appear in pairs in the function.
- The e_match_any function is usually used together with the op_not, op_and, or op_or function.
Type
Mandatory
key
String
Yes
Field name. If the specified field does not exist, the current sub-condition will not be met. For example, if the f1 field does not exist, the result of e_match_any("f1", ...) is false.
regular_expression
String
Yes
full
Bool
No
- Returned result
- Function example
e_match_any: If any field matches, true is returned.
- Test data
{ "k1": 123, "k2": "abc", "k3": "abc123" } - Processing rule
e_set("match",e_match_any('k1', r'\d+', 'k2', '.+')) - Processing result
k1:123 k2:abc k3:abc123 match:true
- Test data
- More
e_match_all
This function checks whether the values of the current log fields meet a specified regular expression condition. If all field meets the condition, true is returned. Otherwise, false is returned.
- Function format
e_match_all(key1, regular_expression1, key2, regular_expression2, ..., full=true)
- The e_match_all function is usually used together with the op_not, op_and, or op_or function.
Type
Mandatory
Field name
String
Yes
Field name. If the specified field does not exist, the current sub-condition will not be met. For example, if the f1 field does not exist, the result of e_match_all("f1", ...) is false.
Regular expression
String
Yes
full
Bool
No
- Returned result
- Function example
- Test data
e_set("match", e_match_all("k1", r"\d+", "k2", r"\d+")) - Processing result
k1:123 k2:abc k3:abc123 match:false
- More
- Test data
