Updated on 2025-11-18 GMT+08:00
Operator Functions
This section describes operator functions, including their syntax, parameters, and usage examples.
Function List
If the value is negative, use the op_neg(positive value) function. For example, to indicate -1, use op_neg(1).
Table 1 Operator functions
Type
Function
Condition judgment
op_if
Evaluates a condition and returns the value of one of two expressions based on the evaluation result.
op_ifnull
Returns the first expression value that is not None.
op_coalesce
op_nullif
Returns None if expression1 is equal to expression2. Otherwise, it returns the value of expression1.
op_and
Uses the logical operation and to check whether a value of any type is true or false. If all parameter values are true, true is returned.
op_not
Uses the logical operation not to check whether a value of any type is true or false. It returns the Boolean opposite of the parameter value's true or false evaluation.
op_or
Uses the logical operation or to check whether a value of any type is true or false. If any parameter value is true, true is returned. If all parameter values are false, false is returned.
Comparison
op_eq
Calculates based on the a == b condition and returns true or false. The data types of a and b must be identical, for example, both strings, numbers, or lists.
op_ge
Calculates based on the ab condition and returns true or false. The data types of a and b must be identical, for example, both strings, numbers, or lists.
op_gt
Calculates based on the a > b condition and returns true or false. The data types of a and b must be identical, for example, both strings, numbers, or lists.
op_le
op_lt
Calculates based on the a < b condition and returns true or false. The data types of a and b must be identical, for example, both strings, numbers, or lists.
op_ne
Calculates based on the a != b condition and returns true or false. The data types of a and b must be identical, for example, both strings, numbers, or lists.
Container judgment
op_len
Calculates the number of characters in a text string. It can be used for strings and other expressions that return tuples, lists, and dictionaries.
op_in
Checks whether a string, tuple, list, or dictionary contains a specific element and returns true or false.
op_not_in
Checks whether a string, tuple, list, or dictionary does not contain a specific element and returns true or false.
op_slice
Extracts a portion of a specified string, array, or tuple.
op_index
Retrieves an element from a string, array, or tuple based on its specified index.
General multi-value operations
op_add
Calculates the sum of multiple values, which can be strings or digits.
op_max
Calculates the maximum value of multiple fields or expressions.
op_min
Calculates the minimum value of multiple fields or expressions.
op_if
This function evaluates a condition and returns the value of one of two expressions based on the evaluation result.
  • Function format
    op_if(condition, expression1, expression2)
  • Parameter description
    Type
    Mandatory
    condition
    Any
    Yes
    Condition to evaluate. If the condition is not a Boolean, the system determines whether it is true or false.
    expression1
    Any
    Yes
    Value of this expression returned when the condition evaluates to true.
    expression2
    Any
    Yes
    Value of this expression returned when the condition evaluates to false.
  • Returned result
    The value of the corresponding expression.
  • Function example
    1. Example 1: If content is true, the value of expression1 is assigned to test_if.
      • Test data
         "content": "hello"
      • Processing rule
        e_set("test_if", op_if(v("content"),"still origion content","replace this"))
      • Processing result
        content: hello
        test_if:  still origion content
    2. Example 2: If content is false, the value of expression2 is assigned to test_if.
      • Test data
         "content": 0
      • Processing rule
        e_set("test_if", op_if(ct_int(v("content", default=0)),"still origion content","replace this"))
      • Processing result
        content: 0
        test_if:  replace this
op_ifnull
This function returns the first expression value that is not None.
  • Function format
    op_ifnull(expression1, expression2, ....)
    Type
    Mandatory
    expression1
    Any
    Yes
    Expression 1.
    expression2
    Any
    Yes
    Expression 2.
  • Returned result
    The first expression value that is not None.
  • Function example
    1. Example 1:
      • Test data
         "test_if": "hello",
         "escape_name": "Etl"
      • Processing rule
        e_set("test_ifnull", op_ifnull(v("escape_name"),v("test_if")))
      • Processing result
        test_if: hello
        escape_name: Etl
        test_ifnull:  Etl
    2. Example 2:
      • Test data
         "test_if": "hello",
      • Processing rule
        e_set("test_ifnull", op_ifnull(v("test_if"),v("escape_name")))
      • Processing result
        test_if: hello
        escape_name: Etl
        test_ifnull:  hello
op_coalesce
  • Function format
    op_coalesce(expression1, expression2, ...)
    Type
    Mandatory
    expression1
    Any
    Yes
    Expression 1.
    expression2
    Any
    Yes
    Expression 2.
  • Returned result
  • Function example
    1. Example 1:
      • Test data
         "test_if": "hello",
      • Processing rule
        e_set("test_coalesce", op_coalesce(v("escape_name"),v("test_if")))
      • Processing result
        test_if: hello
        escape_name: Etl
        test_coalesce: Etl
    2. Example 2:
      • Test data
         "test_if": "hello",
      • Processing rule
        e_set("test_coalesce", op_coalesce(v("test_if"),v("escape_name")))
      • Processing result
        test_if: hello
        escape_name: Etl
        test_coalesce: hello
op_nullif
This function returns None if expression1 is equal to expression2. Otherwise, it returns the value of expression1.
  • Function format
    op_nullif(expression1, expression2)
    Type
    Mandatory
    expression1
    Any
    Yes
    Expression 1.
    expression2
    Any
    Yes
    Expression 2.
  • Returned result
  • Function example
    1. Example 1:
      • Test data
         "test_if": "hello",
      • Processing rule
        e_set("test_ifnull", op_nullif(v("test_if"),v("escape_name")))
      • Processing result
        test_if: hello
        escape_name: Etl
        test_ifnull:  hello
    2. Example 2:
      • Test data
         "test_if": "hello",
         "escape_name": "hello"
      • Processing rule
        e_set("test_ifnull", op_nullif(v("content"),v("escape_name")))
      • Processing result
        # Because the values of content and escape_name are the same, no content is returned for the test_isnull field.
        test_if: hello
        escape_name: hello
op_and
This function uses the logical operation and to check whether a value of any type is true or false. If all parameter values are true, true is returned.
  • Function format
    op_and(value1, value2, ...)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Any
    Yes
    Operation value 2.
  • Returned result
    • Returns true if all parameter values are true.
    • Checks whether a value of any type is true or false.
  • Function example
    1. Example 1:
      • Test data
         "number1": 123,
         "number2": 234
      • Processing rule
        e_set("op_and", op_and(v("number1"),v("number2")))
      • Processing result
        number1: 123
        number2: 234
        op_and:  true
    2. Example 2:
      • Test data
         "number1": 0,
         "number2": 234
      • Processing rule
      • Processing result
        number1: 0
        number2: 234
        op_and: false
    3. Example 3:
      • Test data
         "ctx1": "false",
         "ctx2": 234
      • Processing rule
        e_set("op_and", op_and(v("ctx1"),v("ctx2")))
      • Processing result
        ctx1: false
        ctx2: 234
        op_and: true
    4. Example 4:
      • Test data
         "ctx1": "true",
         "ctx2": 234
      • Processing rule
      • Processing result
        ctx1: true
        ctx2: 234
        op_and: true
op_not
This function uses the logical operation not to check whether a value of any type is true or false. It returns the Boolean opposite of the expression's true or false evaluation.
  • Function format
    op_not(expression)
    Type
    Mandatory
    expression
    Any
    Yes
    Expression.
  • Returned result
    • Returns the Boolean value that is opposite to the expression value.
  • Function example
    1. Example 1:
      • Test data
         "ctx1": "true"
      • Processing rule
        e_set("op_not", op_not(v("ctx1")))
      • Processing result
        ctx1: true
        op_not:  false
    2. Example 2:
      • Test data
         "ctx1": 345
      • Processing rule
      • Processing result
        ctx1: 345
        op_not:  false
    3. Example 3:
      • Test data
         "ctx1": 0
      • Processing rule
        e_set("op_not", op_not(ct_int(v("ctx1"))))
      • Processing result
        ctx1: 0
        op_not:  true
    4. Example 4:
      • Test data
         "ctx1": "ETL"
      • Processing rule
      • Processing result
        ctx1: ETL
        op_not:  false
    5. Example 5:
      • Test data
         "ctx1": "None"
      • Processing rule
      • Processing result
        ctx1: None
        op_not:  false
op_or
This function uses the logical operation or to check whether a value of any type is true or false. If the value of any expression is true, true is returned. If the values of all expressions are false, false is returned.
  • Function format
    op_or(expression1, expression2, ...)
    Type
    Mandatory
    expression1
    Any
    Yes
    Expression 1.
    expression2
    Any
    Yes
    Expression 2.
  • Returned result
    • Returns true if the value of any expression is true, or returns false if the values of all expressions are false.
  • Function example
    1. Example 1:
      • Test data
         "ctx1": 123,
         "ctx2": 234
      • Processing rule
        e_set("op_or", op_or(v("ctx1"),v("ctx2")))
      • Processing result
        ctx1: 123
        ctx2: 234
        op_or:  true
    2. Example 2:
      • Test data
         "ctx1": 0,
         "ctx2": 234
      • Processing rule
      • Processing result
        ctx1: 0
        ctx2: 234
        op_or:  true
    3. Example 3:
      • Test data
         "ctx1": "ETL",
         "ctx2": "aa"
      • Processing rule
      • Processing result
        ctx1: ETL
        ctx2: aa
        op_or:  true
    4. Example 4:
      • Test data
         "ctx1": "true",
         "ctx2":"false"
      • Processing rule
      • Processing result
        ctx1: true
        ctx2: false
        op_or:  true
    5. Example 5:
      • Test data
         "ctx1": 0,
         "ctx2":"false"
      • Processing rule
        e_set("op_or", op_or(ct_int(v("ctx1")),v("ctx2")))
      • Processing result
        ctx1: 0
        ctx2: false
        op_or:  true
    6. Example 6:
      • Test data
         "ctx1": 124,
         "ctx2": "true"
      • Processing rule
      • Processing result
        ctx1: 124
        ctx2: true
        op_or:  true
op_eq
This function calculates based on the a == b condition and returns true or false.
  • Function format
    op_eq(value1, value2)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Same as value1's type
    Yes
    Operation value 2.
  • Returned result
    Returns true if value1 is equal to value2. Otherwise, it returns false.
  • Function example
    1. Example 1:
      • Test data
         "content": "hello",
         "ctx": "hello"
      • Processing rule
        e_set("test_eq", op_eq(v("content"),v("ctx")))
      • Processing result
        content: hello
        ctx: hello
        test_eq: true
    2. Example 2:
      • Test data
         "content": "hello",
         "ctx": "ctx"
      • Processing rule
      • Processing result
        content: hello
        ctx: ctx
        test_eq: false
op_ge
This function calculates based on the ab condition and returns true or false.
  • Function format
    op_ge(value1, value2)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    Returns true if value1 is greater than or equal to value2. Otherwise, it returns false.
  • Function example
    1. Example 1: If the value of apple_price is greater than or equal to that of orange_price, true is returned.
      • Test data
         "apple_price": 16,
         "orange_price": 14
      • Processing rule
        e_set("test_ge", op_ge(ct_int(v("apple_price")),ct_int(v("orange_price"))))
      • Processing result
        apple_price: 16
        orange_price: 14
        test_ge: true
    2. Example 2: If the value of apple_price is less than that of orange_price, false is returned.
      • Test data
         "apple_price": 12,
         "orange_price": 14
      • Processing rule
      • Processing result
        apple_price: 12
        orange_price: 14
        test_ge: false
op_gt
This function calculates based on the a > b condition and returns true or false.
  • Function format
    op_gt(value1, value2)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    Returns true if value1 is greater than value2. Otherwise, it returns false.
  • Function example
    1. Example 1: Checks whether the value of old_number is greater than that of young_number. If yes, true is returned. If no, false is returned.
      • Test data
         "old_number": 16,
         "young_number": 14
      • Processing rule
        e_set("op_gt",op_gt(ct_int(v("old_number")),ct_int(v("young_number"))))
      • Processing result
        old_number: 16
        young_number: 14
        test_ge: true
    2. Example 2: Checks whether the value of priority is greater than that of price. If yes, true is returned. If no, false is returned.
      • Test data
         "priority": 14,
         "price": 16
      • Processing rule
        e_set("op_gt",op_gt(ct_int(v("priority")),ct_int(v("price"))))
      • Processing result
        priority: 14
        price: 16
        test_ge: false
op_le
  • Function format
    op_le(value1, value2)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    Returns true if value1 is less than or equal to value2. Otherwise, it returns false.
  • Function example
    1. Example 1: If the value of priority is less than or equal to that of price, true is returned. Otherwise, false is returned.
      • Test data
         "priority": 16,
         "price": 14
      • Processing rule
        e_set("op_le",op_le(ct_int(v("priority")),ct_int(v("price"))))
      • Processing result
        priority: 16
        price: 14
        op_le: false
    2. Example 2: If the value of priority is less than or equal to that of price, true is returned. Otherwise, false is returned.
      • Test data
         "priority": 14,
         "price": 16
      • Processing rule
      • Processing result
        priority: 14
        price: 16
        test_ge: true
op_lt
This function calculates based on the a < b condition and returns true or false.
  • Function format
    op_lt(value1, value2)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    Returns true if value1 is less than value2. Otherwise, it returns false.
  • Function example
    1. Example 1: If the value of priority is less than that of price, true is returned. Otherwise, false is returned.
      • Test data
         "priority": 16,
         "price": 14
      • Processing rule
        e_set("op_lt",op_lt(ct_int(v("priority")),ct_int(v("price"))))
      • Processing result
        priority: 16
        price: 14
        op_lt: false
    2. Example 2: If the value of priority is less than that of price, true is returned. Otherwise, false is returned.
      • Test data
         "priority": 14,
         "price": 15
      • Processing rule
      • Processing result
        priority: 14
        price: 15
        op_lt: true
op_ne
This function calculates based on the a != b condition and returns true or false.
  • Function format
    op_ne(value1, value2)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    Returns true if value1 is not equal to value2. Otherwise, it returns false.
  • Function example
    1. Example 1:
      • Test data
         "priority": 16,
         "price": 14
      • Processing rule
        e_set("op_ne",op_ne(ct_int(v("priority")),ct_int(v("price"))))
      • Processing result
        priority: 16
        price: 14
        op_ne: true
    2. Example 2:
      • Test data
         "priority": 14,
         "price": 14
      • Processing rule
      • Processing result
        priority: 14
        price: 14
        op_ne: false
op_len
This function calculates the number of characters in a text string. It can be used for strings and other expressions that return tuples, lists, and dictionaries.
  • Function format
    op_len(value)
    Type
    Mandatory
    value
    String, tuple, list, or dictionary
    Yes
    Operation value.
  • Returned result
    Returns the length of the field.
  • Function example
    • Test data
       "content": "I,love,this,world"
    • Processing rule
      e_set("op_len",op_len(v("content")))
    • Processing result
      content: I,love,this,world
      op_len: 17
op_in
This function checks whether a string, tuple, list, or dictionary contains a specific element and returns true or false.
  • Function format
    op_in(value1, value2)
    Type
    Mandatory
    value1
    Yes
    value2
    Any
    Yes
    Element to be checked.
    Note: In this function, the string, tuple, list, or dictionary parameter is placed before the element.
  • Returned result
    Returns true if string, tuple, list, or dictionary a contains element b. Otherwise, it returns false.
  • Function example
    • Test data
       "list":  [1, 3, 2, 7, 4, 6],
       "num2":  2
    • Processing rule
      e_set("op_in",op_in(v("list"),v("num2")))
    • Processing result
      list:  [1, 3, 2, 7, 4, 6]
      num2:  2
      op_in: true
op_not_in
This function checks whether a string, tuple, list, or dictionary does not contain a specific element and returns true or false.
  • Function format
    op_not_in(value1, value2)
    Type
    Mandatory
    value1
    Yes
    value2
    Any
    Yes
  • Returned result
    Returns true if the string, tuple, list, or dictionary does not contain the specified element. Otherwise, it returns false.
  • Function example
    • Test data
       "num2":  12
    • Processing rule
      e_set("op_not_in",op_not_in(v("list"),v("num2")))
    • Processing result
      num2:  12
      op_not_in: true
op_slice
This function extracts a portion of a specified string, array, or tuple.
  • Function format
    op_slice(value, start=0, end=None, step=None)
    Type
    Mandatory
    value
    String
    Yes
    Value to be sliced.
    start
    Num
    No
    Start position of the slice. The default value is 0.
    end
    Num
    No
    End position of the slice (exclusive). The character/element at this position is excluded. It defaults to the end position of value.
    step
    Num
    No
    Length of each slice.
  • Returned result
    The extracted substring, sub-array, or sub-tuple.
  • Function example
    1. Example 1: Truncate the word field from the start point to the end point 2.
      • Test data
         "word":  "I,love,this,world"
      • Processing rule
        e_set("op_slice",op_slice(v("word"),2))
      • Processing result
        word:  I,love,this,world
        op_slice: I,
    2. Example 2: Truncate the word field from position 2 to position 9 with a step length of 1.
      • Test data
      • Processing rule
        e_set("op_slice",op_slice(v("word"),2,9,1))
      • Processing result
        op_slice: love,th
op_index
This function retrieves an element from a string, array, or tuple based on its specified index.
  • Function format
    op_index(value, index)
    Type
    Mandatory
    value
    String
    Yes
    String, array, tuple, etc.
    index
    Num
    No
    Index of the element you want to retrieve.
  • Returned result
    The element corresponding to the index.
  • Function example
    1. Example 1: Retrieve the element at index 0 from the word field.
      • Test data
      • Processing rule
        e_set("op_index",op_index(v("word"),0))
      • Processing result
        op_index: I
    2. Example 2: Retrieve the element at index 3 from the word field.
      • Test data
      • Processing rule
        e_set("op_index",op_index(v("word"),3))
      • Processing result
        op_index: o
op_add
This function calculates the sum of multiple values, which can be strings or digits.
  • Function format
    op_add(value1, value2, ...)
    Type
    Mandatory
    value1
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    The sum of the two values.
  • Function example
    1. Example 1: Calculate the total amount of price_orange and price_apple.
      • Test data
         "price_orange": 2,
         "price_apple": 13
      • Processing rule
        e_set("account",op_add(ct_int(v("price_orange")),ct_int(v("price_apple"))))
      • Processing result
         price_orange: 2,
         price_apple: 13,
         account:  15
    2. Example 2: Calculate the sum of bytes_in and bytes_out.
      • Test data
         "bytes_in": 214,
         "bytes_out": 123
      • Processing rule
        e_set("total_bytes", op_add(ct_int(v("bytes_in")), ct_int(v("bytes_out"))))
      • Processing result
        bytes_in: 214
        bytes_out: 123
        total_bytes:  337
    3. Example 3: Add the HTTPS header to the website.
      • Test data
         "host": "xx.com"
      • Processing rule
        e_set("website", op_add("https://", v("host")))
      • Processing result
        host: xx.com
        website: https://xx.com
op_max
This function calculates the maximum value of multiple fields or expressions.
  • Function format
    op_max(value1, value2, ...)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    The maximum value among multiple values.
  • Function example
    • Test data
       "price_orange":  2,
       "priority_apple":  13
    • Processing rule
      e_set("max_price", op_max(ct_int(v("price_orange")),ct_int(v("priority_apple"))))
    • Processing result
      price_orange:  2
      priority_apple:  13
      max_price:  13
op_min
This function calculates the minimum value of multiple fields or expressions.
  • Function format
    op_min(value1, value2, ...)
    Type
    Mandatory
    value1
    Any
    Yes
    Operation value 1.
    value2
    Yes
    Operation value 2.
  • Returned result
    The minimum value among multiple values.
  • Function example
    • Test data
       "price_orange":  2,
    • Processing rule
      e_set("op_min", op_min(ct_int(v("price_orange")),ct_int(v("priority_apple"))))
    • Processing result
      price_orange:  2
      priority_apple:  13
      op_min:  2
