Conversion Functions
This section describes conversion functions, including their syntax, parameters, and usage examples.
Function List
| Type | Function | Description |
| Basic type conversion | Converts the value of a field or expression to an integer. | |
| Converts the value of a field or expression to a floating point number. | ||
| Converts the value of a field or expression to a string. | ||
| Converts the value of a field or expression to a Boolean value. | ||
| Number conversion | Converts the ANSI or Unicode value of a field or expression to the corresponding character. | |
| Converts characters in a field or expression to the corresponding ANSI or Unicode value. | ||
| Converts the value of a field or expression to a hexadecimal number. | ||
| Converts the value of a field or expression to an octal number. | ||
| Converts the value of a field or expression to a binary number. | ||
| Number system conversion rate | Converts a binary number to an octal number. | |
| Converts a binary number to a hexadecimal string. |
ct_int
The ct_int function converts the value of a field or expression to an integer.
- Function format
ct_int(value, base=10)
- Parameter description
Type
Mandatory
value
Number or numeric string
Yes
Value to be converted.
base
Number
No
Base of the parameter value. The default value is decimal. For example, base=8 indicates that the octal value is converted to a decimal value.
- Returned result
An integer.
- Function example
- Example 1: Convert a string to an integer.
- Test data
{ "number": 2 } - Processing rule
e_set("int_number", ct_int(v("number"))) - Processing result
number: 2 int_number: 2
- Test data
- Example 2: Convert a hexadecimal number to a decimal number.
- Test data
{ "number": "AB" } - Processing rule
e_set("int_number", ct_int(v("number"),base=16)) - Processing result
number: AB int_number: 171
- Test data
ct_float
The ct_float function converts the value of a field or expression to a floating point number.
- Function format
ct_float(value)
Type
Mandatory
value
Yes
- Returned result
A floating point number.
- Function example
- Test data
{ "price": 2 } - Processing rule
e_set("price_float", ct_float(v("price"))) - Processing result
price: 2 price_float: 2.0
- Test data
ct_str
The ct_str function converts the value of a field or expression to a string.
- Function format
ct_str(value)
Type
Mandatory
value
Any value
Yes
- Returned result
A string.
- Function example
- Test data: none
- Processing rule
e_set("ct_str", ct_str(b'test byte')) - Processing result
ct_str: test byte
ct_bool
The ct_bool function converts the value of a field or expression to a Boolean value.
- Function format
ct_bool(value)
Type
Mandatory
value
Any value
Yes
- Returned result
A Boolean value.
- Function example
- Test data
{ "num": 2 } - Processing rule
e_set("ct_bool", ct_bool(v("num"))) - Processing result
num: 2 ct_bool: true
- Test data
ct_chr
The ct_chr function converts the ANSI or Unicode value of a field or expression to the corresponding character.
- Function format
ct_chr(value)
Type
Mandatory
value
Yes
- Returned result
The character corresponding to the chr type.
- Function example
- Test data
{ "number": 78 } - Processing rule
e_set("ct_chr", ct_chr(v("number"))) - Processing result
number: 78 ct_chr: N
- Test data
ct_ord
The ct_ord function converts characters in a field or expression to the corresponding ANSI or Unicode value.
- Function format
ct_ord(value)
Type
Mandatory
value
String
Yes
Value to be converted. The length is 1.
- Returned result
The corresponding ANSI or Unicode value.
- Function example
- Test data
{ "world": "a" } - Processing rule
e_set("ct_ord", ct_ord(v("world"))) - Processing result
world: a ct_ord: 97
- Test data
ct_hex
The ct_hex function converts the value of a field or expression to a hexadecimal number.
- Function format
ct_hex(value)
Type
Mandatory
value
Yes
- Returned result
A hexadecimal value.
- Function example
- Test data
{ "number": 123 } - Processing rule
e_set("ct_hex", ct_hex(v("number"))) - Processing result
number: 123 ct_hex: 0x7b
- Test data
ct_oct
The ct_oct function converts the value of a field or expression to an octal number.
- Function format
ct_oct(value)
Type
Mandatory
value
Yes
- Returned result
An octal value.
- Function example
- Test data
e_set("ct_oct", ct_oct(v("number"))) - Processing result
number: 123 ct_oct: 0o173
- Test data
ct_bin
The ct_bin function converts the value of a field or expression to a binary number.
- Function format
ct_bin(value)
Type
Mandatory
value
Yes
- Returned result
A binary value.
- Function example
- Test data
e_set("ct_bin", ct_bin(v("number"))) - Processing result
number: 123 ct_bin: 0b1111011
- Test data
bin2oct
The bin2oct function converts a binary number to an octal number.
- Function format
bin2oct(binary)
Type
Mandatory
binary
Binary
Yes
Binary string.
- Returned result
An octal string.
- Function example
- Test data
{ "test": "test" } - Processing rule
e_set("new",bin2oct(base64_decoding("ARi8WnFiLAAACHcAGgkADV37Xs8BXftezgAdqwF9"))) - Processing result
test : test new : 214274264705421300000002073400064044000325677327547401273755366340003552600575
- Test data
bin2hex
The bin2hex function converts a binary number to a hexadecimal string.
- Function format
bin2hex(binary)
Type
Mandatory
binary
Binary
Yes
Binary string.
- Returned result
A hexadecimal string.
- Function example
- Test data
e_set("new",bin2hex(base64_decoding("ARi8WnFiLAAACHcAGgkADV37Xs8BXftezgAdqwF9"))) - Processing result
test : test new :0118bc5a71622c00000877001a09000d5dfb5ecf015dfb5ece001dab017d
- Test data
