Arithmetic Functions
This section describes arithmetic functions, including their syntax, parameters, and usage examples.
Function List
If the value is negative, use the op_neg(positive value) function. For example, to indicate -1, use op_neg(1).
Type |
Function |
Description |
Multi-value calculation and comparison |
Sums up the input values. |
Basic calculation |
Performs the absolute value operation on the input value. |
Divides the input values exactly. |
Divides the input values. |
Performs exponentiation on a value. |
Multiplies the input values. |
Calculates the opposite number of the input value. |
Performs the modulo operation on the input value. |
Subtracts the input values. |
Rounds off the input value. |
Mathematical calculation |
Rounds up the input value. |
Returns the exponential value with the constant e as the base. |
Calculates the absolute value of the input value. |
Rounds down the input value. |
Calculates the logarithm of the input value. |
Calculates the logarithm of the input value based on 10. |
op_sum
This function sums up the input values.
- Function format
op_sum(value1, value2, ...)
- Description
Type
Mandatory
value1
Number or numeric string
Yes
Value to be calculated.
value2
Yes
- Returned result
The sum of multiple input values.
- Function example
Calculate the total price of course_price and goods_price.
- Test data
{ "course_price": 12, "goods_price": 2 }
- Processing rule
e_set("account", op_sum(v("course_price"), v("goods_price")))
- Processing result
course_price: 12 goods_price: 2 account: 14
- Test data
op_abs
This function performs the absolute value operation on the input value.
- Function format
op_abs(value)
- Description
Type
Mandatory
value
Yes
- Returned result
The absolute value of the input value.
- Function example
- Test data
{ "course_price": -4 }
- Processing rule
e_set("op_abs", op_abs(v("course_price")))
- Processing result
course_price: -4 op_abs: 4
- Test data
op_div_floor
This function divides the input values exactly.
- Function format
op_div_floor(value1, value2)
- Description
Type
Mandatory
value1
Yes
value2
Yes
- Returned result
The result of value 1 divided by value 2.
- Function example
Calculate the unit price based on course_price and count.
- Test data
{ "course_price": 4, "count": 2 }
- Processing rule
e_set("op_div_floor", op_div_floor(v("course_price"), v("count")))
- Processing result
course_price: 4 count: 2 op_div_floor: 2
- Test data
op_div_true
This function divides the input value.
This function supports automatic data type conversion. You can enter data of the string or int type.
- Function format
op_div_true(value1, value2)
- Description
Type
Mandatory
value1
Number
Yes
value2
Number
Yes
- Returned result
- Function example
- Example 1: Calculate the unit price based on fruit_price and count.
- Test data
{ "fruit_price": 9, "count": 2 }
- Processing rule
e_set("op_div_true", op_div_true(v("fruit_price"), v("count")))
- Processing result
fruit_price: 9 count: 2 op_div_true: 4.5
- Test data
- Example 2: Calculate the acceleration (rounded off). Formula: a = (one_speed – two_speed)/time.
- Test data
{ "one_speed": 9, "two_speed": 2, "time": 3 }
- Processing rule
e_set("a", op_round(op_div_true(op_sub(v("one_speed"), v("two_speed")), v("time")), 2))
- Processing result
a:2.33 one_speed:9 time:3 two_speed:2
- Test data
op_pow
This function performs exponentiation on a value.
- Function format
op_pow(value1, value2)
- Description
Type
Mandatory
value1
Yes
value2
Yes
- Returned result
The result of value 1 raised to the power of value 2.
- Function example
Calculate the value of course raised to the power of n.
- Test data
{ "course": 100, "pow": 2 }
- Processing rule
e_set("pow_course", op_pow(v("course"), v("pow")))
- Processing result
course: 100 pow: 2 pow_course: 10000
- Test data
op_mul
This function multiplies the input values.
- Function format
op_mul(value1, value2)
- Description
Type
Mandatory
value1
Number, string, tuple, list, and other
Yes
value2
Number
Yes
- Returned result
- Value 1 is of the number type: the result of multiplication of value 1 and value 2
- Value 1 is of the string, tuple, or list type: a new sequence by repeating value 1 for value 2 times
- Function example
- Example 1: Calculate the total price based on course and price.
- Test data
{ "course": 10, "price": 23 }
- Processing rule
e_set("account", op_mul(ct_int(v("course")), ct_int(v("price"))))
- Processing result
course: 10 price: 23 account: 230
- Test data
- Example 2: Repeat course for three times.
- Test data
{ "course": "abc" }
- Processing rule
e_set("course", op_mul(v("course"), 3))
- Processing result
course: abcabcabc
- Test data
op_neg
This function calculates the opposite number of the input value.
- Function format
op_neg(value)
- Description
Type
Mandatory
value
Yes
- Returned result
The opposite number of the input value
- Function example
- Test data
{ "course": -100 }
- Processing rule
e_set("account", op_neg(v("course_price")))
- Processing result
course: -100 account: 100
- Test data
op_mod
This function performs the modulo operation on the input value.
- Function format
op_mod(value1, value2)
- Description
Type
Mandatory
value1
Yes
value2
Yes
- Returned result
The result of value 1 modulo value 2
- Function example
- Test data
{ "course": 4, "count": 3 }
- Processing rule
e_set("op_mod", op_mod(v("course"), v("count")))
- Processing result
course: 4 count: 3 op_mod: 1
- Test data
op_sub
This function subtracts the input values.
- Function format
op_sub(value1, value2)
- Description
Type
Mandatory
value1
Yes
value2
Yes
- Returned result
The result of subtracting value 2 from value 1
- Function example
Calculate the result of subtracting count_apple from count.
- Test data
{ "count": 6, "count_apple": 3 }
- Processing rule
e_set("sub_number", op_sub(v("count"),v("count_apple")))
- Processing result
count: 6 count_apple: 3 sub_number: 3
- Test data
op_round
This function rounds off the input value.
- Function format
op_round(value, number)
- Description
Type
Mandatory
value
Yes
number
Number
Yes
Number of decimal places reserved after rounding (default value: 0).
- Returned result
The rounded result of the input value
- Function example
Return the value of price accurate to one decimal place.
- Test data
{ "price": 4.56 }
- Processing rule
e_set("round_price", op_round(v("price"),1))
- Processing result
price: 4.56 round_price: 4.6
- Test data
mat_ceil
This function rounds up the input value.
- Function format
mat_ceil(value)
- Description
Type
Mandatory
value
Yes
- Returned result
The smallest integer greater than or equal to the value
- Function example
- Test data
{ "price": 4.1 }
- Processing rule
e_set("mat_ceil", mat_ceil(v("price")))
- Processing result
price: 4.1 mat_ceil: 5
- Test data
mat_exp
This function returns the exponential value with the constant e as the base.
- Function format
mat_exp(value)
- Description
Type
Mandatory
value
Yes
- Returned result
The result of e to the power of the value.
- Function example
- Test data
{ "number": 2 }
- Processing rule
e_set("e_x", mat_exp(v("number")))
- Processing result
number: 2 e_x: 7.38905609893065
- Test data
mat_fabs
This function calculates the absolute value of the input value.
- Function format
mat_fabs(value)
- Description
Type
Mandatory
value
Yes
- Returned result
- Function example
- Test data
{ "course_price": -10 }
- Processing rule
e_set("mat_fabs", mat_fabs(v("course_price")))
- Processing result
course_price: -10 mat_fabs: 10.0
- Test data
mat_floor
This function rounds down the input value.
- Function format
mat_floor(value)
- Description
Type
Mandatory
value
Yes
- Returned result
The largest integer that is less than or equal to the value
- Function example
- Test data
{ "course_price": 4.9 }
- Processing rule
e_set("mat_floor", mat_floor(v("course_price")))
- Processing result
course_price: 4.9 mat_floor: 4
- Test data
mat_log
This function calculates the logarithm of the input value.
- Function format
mat_log(value1,value2)
- Description
Type
Mandatory
value1
Yes
value2
Yes
- Returned result
The logarithm of the input value.
- Function example
- Test data
{ "number1": 100, "number2": 10 }
- Processing rule
e_set("mat_log", mat_log(v("number1"),v("number2")))
- Processing result
number1: 100 number2: 10 mat_log: 2.0
- Test data
mat_log10
This function calculates the logarithm of the input value based on 10.
- Function format
mat_log10(value)
- Description
Type
Mandatory
value
Yes
- Returned result
The logarithm of the input value with base 10.
- Function example
- Test data
{ "number": 100 }
- Processing rule
e_set("number2", mat_log10(v("number")))
- Processing result
number: 100 number2: 2.0
- Test data
