Date and Time functions
This section describes date and time functions, including their syntax, parameters, and usage examples.
In DSL processing, all values in logs are stored as strings. Convert the data type as required.
This section introduces the date and time functions used to convert the formats of time data in logs. There are three types of time data:
- String: for example, 2022/07/03 02-41-26
- Unix timestamp: for example, 1559500886
- Date and time object: for example, 2022-07-01 10:10:10+08:00 or 2022-07-01 10:10:10
Unix timestamps are essentially strings. Only the dt_parse, dt_str, and dt_parsetimestamp functions support the preceding three data types as parameters.
Function List
Type |
Function |
Description |
General date and time conversion |
Converts a value or time expression to a datetime object. |
Converts a value or time expression to a string. |
Converts a value or time expression to a Unix timestamp. |
Extracts specific attributes, such as day and year, from a value or time expression. |
Date and time obtaining |
Obtains the current datetime object. |
Obtains the current date, excluding the time. |
Obtains the current datetime object of the current time zone. |
Converts a Unix timestamp to a datetime object. |
Converts a Unix timestamp to a datetime object of the current time zone. |
Parses a time string into a datetime object. |
Unix timestamp obtaining |
Obtains the current Unix timestamp. |
Converts a datetime object to a Unix timestamp. |
Date and time string obtaining |
Converts a datetime object to a string in a specific format. |
Converts a Unix timestamp to a string in a specific format. |
Data and time modification |
Truncates a specific time granularity from a value or time expression. |
Changes a value or time expression based on a specific time granularity. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Monday. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Tuesday. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Wednesday. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Thursday. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Friday. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Saturday. |
Returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Sunday. |
Time zone change |
Converts a value or time expression to a datetime object of a specific time zone. |
Difference obtaining |
Obtains the difference between two values or time expressions based on a specific granularity. |
dt_parse
This function converts a value or time expression to a datetime object.
- Function format
dt_parse(value, tz=None)
- Description
Type
Mandatory
value
String, Unix timestamp, or datetime object
Yes
Value or time expression.
tz
String
No
Time zone (default value: None).
- Returned result
The converted datetime object.
- Function example
- Example 1: Convert the value of time to a datetime object.
- Test data
{ "time": "1559500886" }
- Processing rule
e_set("test_time", dt_parse(v("time")))
- Processing result
time: 1559500886 test_time: 2019-06-02 18:41:26
- Test data
- Example 2: Convert the value of time to a datetime object. Time zone: Shanghai.
- Test data
{ "time": "2019-06-01 10:10:10" "tz": "Asia/Shanghai" }
- Processing rule
e_set("test_time", dt_parse(v("time"),tz=v("tz")))
- Processing result
time: 2019-06-01 10:10:10 tz: Asia/Shanghai test_time: 2019-06-01 10:10:10+08:00
- Test data
dt_str
This function converts a value or time expression to a string.
- Function format
dt_str(value, fmt="format_string", tz=None)
- Description
Type
Mandatory
value
Yes
fmt
String
No
Format string.
tz
String
No
Time zone.
- Returned result
The converted time string.
- Function example
- Example 1: Convert the value of time to the fmt format. Time zone: Tokyo.
- Test data
{ "time": "2019-06-03 02:41:26", "fmt": "%Y/%m/%d %H-%M-%S" , "tz": "Asia/Tokyo" }
- Processing rule
e_set("dt_str", dt_str(v("time"),fmt=v("fmt"),tz=v("tz")))
- Processing result
{ "time": "2019-06-03 02:41:26" "fmt": "%Y/%m/%d %H-%M-%S" "tz": "Asia/Tokyo" "dt_str": "2019/06/03 02-41-26" }
- Test data
- Example 2: Convert the value of time (Unix timestamp) to the fmt format.
- Test data
{ "time": "1559500886", "fmt": "%Y/%m/%d %H-%M-%S" }
- Processing rule
e_set("dt_str", dt_str(v("time"),fmt=v("fmt")))
- Processing result
time: 1559500886 fmt: %Y/%m/%d %H-%M-%S dt_str: 2019/06/02 18-41-26
- Test data
- Example 3: Convert the value of time to the default format.
- Test data
{ "time": "2019-06-03 02:41:26" }
- Processing rule
e_set("dt_str", dt_str(v("time")))
- Processing result
time: 2019-06-03 02:41:26 dt_str: 2019-06-03 02:41:26
- Test data
dt_parsetimestamp
This function converts a value or time expression to a Unix timestamp.
- Function format
dt_parsetimestamp(value, tz=None)
- Description
Type
Mandatory
value
Yes
tz
String
No
- Returned result
The converted Unix timestamp.
- Function example
- Example 1: Convert the value of time to a timestamp. Time zone: Beijing.
- Test data
{ "time": "2019-06-03 2:41:26", "tz": "Asia/Tokyo" }
- Processing rule
e_set("dt_parsetimestamp", dt_parsetimestamp(v("time"),v("tz")))
- Processing result
time: 2019-06-03 2:41:26 tz: Asia/Tokyo dt_parsetimestamp: 1559497286
- Test data
- Example 2: Convert the value of time to a Unix timestamp.
- Test data
{ "time": "2019-06-03 2:41:26" }
- Processing rule
e_set("dt_parsetimestamp",dt_parsetimestamp(v("time")))
- Processing result
time: 2019-06-03 2:41:26 dt_parsetimestamp: 1559529686
- Test data
- Example 3: Convert the value of time to a Unix timestamp.
- Test data
- Processing rule
- Processing result
time: 2019-06-03 02:41:26+8:00 dt_parsetimestamp: 1559500886
- Test data
dt_prop
This function extracts specific attributes, such as day and year, from a value or time expression.
- Function format
dt_prop(value, props)
- Description
Type
Mandatory
value
Yes
props
String
Yes
Target attributes: day, year, month, hour, second, minute, microsecond, weekday, weekdayname, weekdayshortname, monthname, monthshortname, dayofyear, dayofweek, weekofyear, weekofyear_m, tzname, and weekofmonth.
- Returned result
The extracted attribute.
- Function example
- Example 1: Extract the day attribute from time.
- Test data
{ "time": "2018-10-2 09:11:40" }
- Processing rule
e_set("dt_parsetimestamp",dt_prop(dt_parse(v("time")),"day"))
- Processing result
time: 2018-10-2 09:11:40 dt_parsetimestamp: 2
- Test data
- Example 2: Extract the year attribute from time.
- Test data
- Processing rule
e_set("dt_parsetimestamp",dt_prop(dt_parse(v("time")),"year"))
- Processing result
time: 2018-10-2 09:11:40 dt_parsetimestamp: 2018
- Test data
- Example 3: Extract the weekdayname attribute from time.
- Test data
- Processing rule
e_set("dt_prop",dt_prop(dt_parse(v("time")),"weekdayname"))
- Processing result
time: 2018-10-2 09:11:40 dt_prop: Tuesday
- Test data
- Example 4: Extract the weekofyear attribute from time.
- Test data
- Processing rule
e_set("dt_prop",dt_prop(dt_parse(v("time")),"weekofyear"))
- Processing result
time: 2018-10-2 09:11:40 dt_prop: 39
- Test data
dt_now
This function obtains the current datetime object.
- Function format
dt_now(tz=None)
- Description
Type
Mandatory
tz
String
No
- Returned result
The datetime object of the specified time zone.
- Function example
Obtains the current datetime object. Time zone: Shanghai.
- Test data
{ "tz": "Asia/Shanghai" }
- Processing rule
e_set("dt_now",dt_now(tz=v("tz")))
- Processing result
tz: Asia/Shanghai dt_now: 2022-06-30 11:21:25.111836+08:00
- Test data
dt_today
This function obtains the current date, excluding the time.
- Function format
dt_today(tz=None)
- Description
Type
Mandatory
tz
String
No
- Returned result
The date object of the specified time zone.
- Function example
Obtain the current date, excluding the time.
dt_fromtimestamp
This function converts a Unix timestamp to a datetime object.
- Function format
dt_fromtimestamp(value, tz=None)
- Description
Type
Mandatory
value
String
Yes
tz
String
No
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_fromtimestamp",dt_fromtimestamp(v("time")))
- Processing result
time: 1559500886 dt_fromtimestamp: 2019-06-02 18:41:26
- Test data
- Test data
{ "time": "1559500886" "tz": "Asia/Shanghai" }
tz: Asia/Shanghai
- Processing rule
e_set("dt_fromtimestamp",dt_fromtimestamp(v("time"),tz=v("tz")))
- Processing result
time: 1559500886 tz: Asia/Shanghai dt_fromtimestamp: 2019-06-03 02:41:26
- Test data
dt_utcfromtimestamp
This function converts a Unix timestamp to a datetime object of the current time zone.
- Function format
dt_utcfromtimestamp(value)
- Description
Type
Mandatory
value
String
Yes
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_utcfromtimestamp",dt_utcfromtimestamp(v("time")))
- Processing result
time: 1559500886 dt_utcfromtimestamp: 2019-06-02 18:41:26
- Test data
dt_strptime
This function parses a time string into a datetime object.
- Function format
dt_strptime(value, "format_string")
- Description
Type
Mandatory
value
String
Yes
fmt
String
No
Format string.
- Returned result
Parsed datetime object
- Function example
- Test data
{ "time": "2019/06/03 02-41-26", "fmt": "%Y/%m/%d %H-%M-%S" }
- Processing rule
e_set("dt_strptime",dt_strptime(v("time"),v("fmt")))
- Processing result
time: 2019/06/03 02-41-26 fmt: %Y/%m/%d %H-%M-%S dt_strptime: 2019-06-03 02:41:26
- Test data
dt_currentstamp
This function obtains the current Unix timestamp.
- Function format
dt_currentstamp(value, normalize='floor')
- Description
Type
Mandatory
value
String
Yes
normalize
String
No
Calculation result formats:
- floor (default value): rounding down
- int: truncating
- round: rounding off
- ceil: rounding up
- Returned result
The current Unix timestamp.
- Function example
dt_totimestamp
This function converts a datetime object to a Unix timestamp.
- Function format
dt_totimestamp(timeexpression)
- Description
Type
Mandatory
timeexpression
Datetime object
Yes
Datetime object to be converted.
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_totimestamp",dt_totimestamp(dt_parse(v("time"))))
- Processing result
time: 2019-06-03 2:41:26 dt_totimestamp: 1559529686
- Test data
dt_strftime
This function converts a datetime object to a string in a specific format.
- Function format
dt_strftime(timeexpression, "format_string")
- Description
Type
Mandatory
timeexpression
Datetime object
Yes
format_string
String
Yes
Format string.
- Returned result
Formatted string.
- Function example
Convert the value of time based on the fmt format.
- Test data
{ "time": "2019-06-03 2:41:26", "fmt": "%Y/%m/%d %H-%M-%S" }
- Processing rule
e_set("dt_strftime",dt_strftime(dt_parse(v("time")),v("fmt")))
- Processing result
time: 2019-06-03 2:41:26 fmt: %Y/%m/%d %H-%M-%S dt_strftime: 2019/06/03 02-41-26
- Test data
dt_strftimestamp
This function converts a Unix timestamp to a string in a specific format.
- Function format
dt_strftimestamp(value, fmt="format_string", tz=None)
- Description
Type
Mandatory
value
String
Yes
Unix timestamp to be converted.
fmt
String
Yes
Format string.
tz
String
No
- Returned result
Formatted string.
- Function example
- Example 1
- Test data
- Processing rule
e_set("dt_strftimestamp",dt_strftimestamp(v("time"),v("fmt")))
- Processing result
time: 1559500886 fmt: %Y/%m/%d %H-%M-%S dt_strftimestamp: 2019/06/02 18-41-26
- Test data
- Example 2
- Test data
{ "time": "1559500886", "fmt": "%Y/%m/%d %H-%M-%S", "tz": "Asia/shanghai" }
- Processing rule
e_set("dt_strftimestamp",dt_strftimestamp(v("time"),v("fmt"),v("tz")))
- Processing result
dt_strftimestamp:2019/06/03 03-41-26 fmt:%Y/%m/%d %H-%M-%S time:1559500886 tz:Asia/shanghai
- Test data
- Example 1
dt_truncate
Truncates a value or time expression value to a specific granularity.
- Function format
dt_truncate(value, unit='day')
- Description
Type
Mandatory
value
Yes
unit
String
Yes
Time attribute granularities: second, minute, <num>_minute (for example, 5_minute, 19_minute, and 2_minute), hour, day (default value), week, month, quarter, half_year, and year.
- Returned result
The truncated time value.
- Function example
- Example 1
- Test data
{ "time": "2019-06-03 2:41:26", "unit": "year" }
- Processing rule
e_set("dt_truncate",dt_truncate(v("time"),v("unit")))
- Processing result
time: 2019-06-03 2:41:26 unit: year dt_truncate: 2019-01-01 00:00:00
- Test data
- Example 2
- Test data
{ "time": "2019-06-03 2:41:26", "unit": "hour" }
- Processing rule
- Processing result
time: 2019-06-03 2:41:26 unit: hour dt_truncate: 2019-06-03 02:00:00
- Test data
- Example 1
dt_add
This function changes a value or time expression based on a specific time granularity.
- Function format
dt_add(value, dt1=None, dt2=None, year(s)=None, month(s)=None, day(s)=None, hour(s)=None, minute(s)=None, second(s)=None, microsecond(s)=None, week(s)=None, weekday=None)
- Description
Type
Mandatory
value
Yes
Date and time expression.
dt1
No
Date and time expression (default value: None).
dt2
No
year/years
Number
No
- year: target year. Example: year=2020. Default value: None.
- years: number of years to be added. For example, years=1 indicates that one year is added to the original year.
day/days
Number
No
- day: target day. Example: day=1. Default value: None.
- days: number of days to be added. For example, days=1 indicates that one day is added to the original day.
hour/hours
Number
No
- hour: target hour. Example: hour=1. Default value: None.
- hours: number of hours to be added. For example, hours=1 indicates that 1 hour is added to the original hour.
minute/minutes
Number
No
- minute: target minute. Example: minute=1. Default value: None.
- minutes: number of minutes to be added. For example, minutes=1 indicates that 1 minute is added to the original minute.
second/seconds
Number
No
- second: target second. Example: second=1. Default value: None.
- seconds: number of seconds to be added. For example, seconds=1 indicates that 1 second is added to the original second.
microsecond/microseconds
Number
No
- microsecond: target microsecond. Example: microsecond=1. Default value: None.
- microseconds: number of microseconds to be added. For example, microseconds=1 indicates that one microsecond is added to the original microsecond.
week/weeks
Number
No
- week: number of weeks to be offset. Example: week=1. Default value: None.
- weeks: number of weeks to be added. For example, weeks=1 indicates that one week is added to the original week.
weekday
Number
No
Target weekday. Example: weekday=dt_MO(1). Default value: None.
- Returned result
The new time expression.
- Function example
- Example 1
- Test data
{ "dt": "2018-10-10 1:2:3", "dt1": "2018-11-3 11:12:13", "dt2": "2018-10-1 10:10:10" }
- Processing rule
e_set("dt_add",dt_add(dt_parse(v("dt")), dt1=dt_parse(v("dt1")), dt2=dt_parse(v("dt2"))))
- Processing result
dt:2018-10-10 1:2:3 dt1:2018-11-3 11:12:13 dt2:2018-10-1 10:10:10 dt_add:2018-11-12 02:04:06
- Test data
- Example 2
- Test data
{ "dt": "2018-10-11 02:03:04", "year": "2019" }
year: 2019
- Processing rule
e_set("dt_add", dt_add(dt_parse(v("dt")), year=ct_int(v("year"))))
- Processing result
dt:2018-10-11 02:03:04 dt_add:2019-10-11 02:03:04 year:2019
- Test data
- Example 1
dt_MO
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Monday.
- Function format
dt_MO(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
Input offset. If a negative number needs to be input, use op_neg(positive). For example, -1 is represented by op_neg(1).
- Returned result
The time after the offset.
- Function example
- Test data
{ "time": "2019-08-13 02:03:04" }
- Processing rule
e_set("dt_MO",dt_add(v("time"),weekday=dt_MO(1)))
- Processing result
time: 2019-08-13 02:03:04 dt_MO: 2019-08-19 02:03:04
- Test data
dt_TU
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Tuesday.
- Function format
dt_TU(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
- Returned result
- Function example
- Test data
{ "time": "2023-06-17 02:03:04" }
- Processing rule
e_set("dt_TU",dt_add(v("time"),weekday=dt_TU(1)))
- Processing result
time: 2023-06-17 02:03:04 dt_TU: 2023-06-20 02:03:04
- Test data
dt_WE
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Wednesday.
- Function format
dt_WE(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_WE",dt_add(v("time"),weekday=dt_WE(1)))
- Processing result
time: 2023-06-17 02:03:04 dt_WE: 2023-06-21 02:03:04
- Test data
dt_TH
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Thursday.
- Function format
dt_TH(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_TH",dt_add(v("time"),weekday=dt_TH(1)))
- Processing result
time: 2023-06-17 02:03:04 dt_TH: 2023-06-22 02:03:04
- Test data
dt_FR
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Friday.
- Function format
dt_FR(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_FR",dt_add(v("time"),weekday=dt_FR(1)))
- Processing result
time: 2023-06-17 02:03:04 dt_FR: 2023-06-23 02:03:04
- Test data
dt_SA
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Saturday.
- Function format
dt_SA(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_SA",dt_add(v("time"),weekday=dt_SA(1)))
- Processing result
dt_SA: 2023-06-17 02:03:04 time: 2023-06-17 02:03:04
- Test data
dt_SU
This function returns a value to be passed to the weekday parameter of the dt_add function, representing an offset to a specific Sunday.
- Function format
dt_SU(Integer_or_negative)
- Description
Type
Mandatory
Integer_or_negative
Number
Yes
- Returned result
- Function example
- Test data
- Processing rule
e_set("dt_SU",dt_add(v("time"),weekday=dt_SU(1)))
- Processing result
dt_SU: 2023-06-18 02:03:04 time: 2023-06-17 02:03:04
- Test data
dt_astimezone
This function converts a value or time expression to a datetime object of a specific time zone.
- Function format
dt_astimezone(value, tz, reset=false)
- Description
Type
Mandatory
value
Yes
tz
String
No
reset
Bool
No
Whether to reset the time zone. Default value: false. If the value is set to true, the original time plus the configured time zone is returned.
- Returned result
- Function example
- Example 1
- Test data
{ "time": "2019-06-03 2:41:26", "tz": "UTC" }
- Processing rule
e_set("dt_astimezone",dt_astimezone(dt_parse(v("time")), v("tz")))
- Processing result
time: 2019-06-03 2:41:26 tz: UTC dt_astimezone: 2019-06-03 02:41:26+00:00
- Test data
- Example 2
- Test data
{ "time": "2019-06-01 10:10:10+10:00", "tz": "Asia/shanghai" }
- Processing rule
e_set("dt_astimezone",dt_astimezone(v("time"), v("tz"),reset=true))
- Processing result
time: 2019-06-01 10:10:10+10:00 tz: Asia/shanghai dt_astimezone: 2019-06-01 10:10:10+08:00
- Test data
- Example 3
- Test data
{ "time": "2019-06-01 10:10:10+08:00", "tz": "Asia/shanghai" }
- Processing rule
e_set("dt_astimezone",dt_astimezone(v("time"), v("tz"),reset=false)) e_set("dt_astimezone_true",dt_astimezone(v("time"), v("tz"),reset=true))
- Processing result
dt_astimezone: 2019-06-01 10:10:10+08:00 dt_astimezone_true: 2019-06-01 10:10:10+08:00 time:2019-06-01 10:10:10+08:00 tz:Asia/shanghai
- Test data
- Example 1
dt_diff
This function obtains the difference between two values or time expressions based on a specific granularity.
- Function format
dt_diff(value1, value2, unit='second', normalize='floor')
- Description
Type
Mandatory
value1
Yes
value2
Yes
unit
String
No
Units of the returned value: second (default value), microsecond, millisecond, minutes, hours, or day.
normalize
String
No
- int: truncating
- round: rounding to N decimal places
- ceil: rounding up
- Returned result
The difference between two values calculated at a specific granularity
- Function example
- Example 1: Calculate the difference between the values of time1 and time2 by second.
- Test data
{ "time1": "2018-10-1 10:10:10", "time2": "2018-10-1 10:10:10" }
- Processing rule
e_set("diff",dt_diff(v("time1"), v("time2")))
- Processing result
time1: 2018-10-1 10:10:10 time2: 2018-10-1 10:10:10 diff: 0
- Test data
- Example 2: Calculate the difference between the values of time1 and time2 by second.
- Test data
{ "time1": "2018-10-1 11:10:10", "time2": "2018-10-1 10:10:10" }
- Processing rule
- Processing result
time1: 2018-10-1 11:10:10 time2: 2018-10-1 10:10:10 diff: 3600
- Test data
- Example 3: Calculate the difference between the values of time1 and time2 by microsecond.
- Test data
{ "time1": "2018-10-1 11:10:11", "time2": "2018-10-1 10:10:10", "unit": "microsecond" }
- Processing rule
e_set("diff",dt_diff(v("time1"), v("time2"),v("unit")))
- Processing result
diff:3601000000 time1:2018-10-1 11:10:11 time2:2018-10-1 10:10:10 unit:microsecond
- Test data
- Example 4: Calculate the difference between the values of time1 and time2 by minute and round down the result.
- Test data
{ "time1": "2018-10-1 11:11:59", "time2": "2018-10-1 10:10:00", "unit": "minute ", "normalize": "floor" }
- Processing rule
e_set("diff", dt_diff(v("time1"), v("time2"), v("unit"), v("normalize")))
- Processing result
diff:61 normalize:floor time1:2018-10-1 11:11:59 time2:2018-10-1 10:10:00 unit:minute
- Test data
- Example 5: Calculate the difference between the values of time1 and time2 by second and round down the result.
- Test data
{ "time1": "10:00:00", "time2": "11:00:00", "unit": "second" , "normalize": "floor" }
- Processing rule
Processing resultdiff:-3600 normalize:floor time1:10:00:00 time2:11:00:00 unit:second
- Test data
