Regular Expression Functions
This section describes regular expression functions, including their syntax, parameters, and usage examples.
| Type | Function | Description |
| Value extraction | Extracts values that meet regular expression conditions. | |
| Obtains a list of all values that meet regular expression conditions. | ||
| Matching judgment | Checks whether a regular expression is matched. | |
| Replacement | Replaces a specified character in a string based on regular expressions. | |
| Splitting | Splits a string into string arrays. |
regex_select
- Function format
regex_select(value, r"regular expression", mi=None, gi=None)
- Parameter description
Type
Mandatory
value
Any
Yes
Value to be matched.
regular expression
String
Yes
Regular expression to be matched.
mi
int
No
Specifies the sequence number of the matched expression. The default value is None, indicating the first expression.
gi
int
No
Specifies the sequence number of the matched group. The default value is None, indicating the first group.
- Returned result
The extracted value.
- Function example
- Example 1: Extract the first value that matches the regular expression from the str field.
- Test data
{ "str": "iZbp1a65x3r1vhpe94fi2qZ" } - Processing rule
e_set("regex", regex_select(v("str"), r"\d+")) e_set("regex2", regex_select(v("str"), r"\d+", mi=None)) e_set("regex3", regex_select(v("str"), r"\d+", mi=0)) - Processing result
regex:1 regex2:1 regex3:1 str:iZbp1a65x3r1vhpe94fi2qZ
- Test data
- Example 2: Extract the first and second values that match the regular expression from the str field.
- Test data
{ "str": "abc123 xyz456" } - Processing rule
# Extract the first value that meets regular expression conditions from the field str. e_set("regex", regex_select(v("str"), r"\d+")) # Extract the second value that meets regular expression conditions from the field str. e_set("regex2", regex_select(v("str"), r"\d+", mi=1)) - Processing result
regex: 123 regex2: 456 str: abc123 xyz456
- Test data
- Example 3: Extract the values of different groups of different expressions from the field str.
- Test data
# Extract the value of the first group of the first expression that meets the regular expression from the field str. e_set("regex", regex_select(v("str"),r"[a-z]+(\d+)",gi=0)) # Extract the value of the first group of the second expression that meets the regular expression from the field str. e_set("regex2", regex_select(v("str"),r"[a-z]+(\d+)",mi=1,gi=0)) # Extract the value of the first group of the first expression that meets the regular expression from the field str. e_set("regex3", regex_select(v("str"),r"([a-z]+)(\d+)",gi=0)) # Extract the value of the second group of the first expression that meets the regular expression in the str field. e_set("regex4", regex_select(v("str"),r"([a-z]+)(\d+)",gi=1)) - Processing result
str: abc123 xyz456 regex: 123 regex2: 456 regex3: abc regex4: 123
- Test data
regex_findall
Use the regex_findall function to obtain a list of all values that meet regular expression conditions.
- Function format
regex_findall(value, r"regular expression")
Type
Mandatory
value
Any
Yes
regular expression
String
Yes
Regular expression.
- Returned result
The list that meets the search criteria.
- Function example
Obtain all digits in the str field.
- Test data
e_set("regex_findall", regex_findall(v("str"),r"\d+")) - Processing result
str: iZbp1a65x3r1vhpe94fi2qZ regex_findall: ["1", "65", "3", "1", "94", "2"]
- Test data
regex_match
Use the regex_match function to check whether a regular expression is matched.
- Function format
regex_match(value, r"regular expression", full=false)
Type
Mandatory
value
Any
Yes
regular expression
String
Yes
Regular expression.
full
Bool
No
Whether the match is exact. The default value is false.
- Returned result
true or false.
- Function example
Check whether the field str contains digits.
- Test data
# Check whether the str field contains digits. e_set("regex_match", regex_match(v("str"),r"\d+")) # Check whether the str field contains only digits. e_set("regex_match2", regex_match(v("str"),r"\d+",full=true)) - Processing result
str: iZbp1a65x3r1vhpe94fi2qZ regex_match: true regex_match2: false
- Test data
regex_replace
Use the regex_replace function to replace a specified character in a string based on regular expressions.
- Function format
regex_replace(value, r"regular expression", replace="", count=0)
Type
Mandatory
value
Any
Yes
Value to be replaced.
regular expression
String
Yes
Regular expression.
replace
String
No
New character. The default value is empty, indicating that characters are deleted.
Regular expressions are supported. For example, r"\1****\2" indicates that the new string must match the regular expression.
- \1 indicates the first group.
- \2 indicates the second group.
count
Number
No
Number of replacement times. The default value is 0, indicating that all characters are replaced.
- Returned result
New string after replacement.
- Function example
- Example 1: Replace all digits in str with 13.
- Test data
{ "str": "iZbp1a65x3r1vhpe94fi2qZ ", "replace": "13" } - Processing rule
e_set("regex_replace", regex_replace(v("str"),r"\d+",v("replace"))) - Processing result
str: iZbp1a65x3r1vhpe94fi2qZ replace: 13 regex_replace: iZbp13a13x13r13vhpe13fi13qZ
- Test data
- Example 2: Anonymize the middle four digits of a mobile number.
- Test data
{ "iphone": "13900001234" } - Processing rule
- replace=r"\1****\2" indicates that the string after replacement must meet the regular expression r"\1****\2".
- \1 indicates the first group, that is, (\d{0,3}).
- \2 indicates the second group, that is, (\d{4}).
e_set( "sec_iphone", regex_replace(v("iphone"), r"(\d{0,3})\d{4}(\d{4})", replace=r"\1****\2"), ) - Processing result
iphone: 13900001234 sec_iphone: 139****1234
- Test data
regex_split
Use the regex_split function to split a string into string arrays.
- Function format
regex_split(value, r"regular expression", maxsplit=0)
Type
Mandatory
value
Any
Yes
Value to be split.
regular expression
String
Yes
Regular expression.
maxsplit
int
No
Maximum number of split matching times. The default value is 0, indicating that all matching items are split. If the value is 1, only the first match item is split.
- Returned result
The split array list.
- Function example
Split the str field by digit.
- Test data
e_set("regex_split", regex_split(v("str"),r"\d+")) - Processing result
str: iZbp1a65x3r1vhpe94fi2qZ regex_split: ["iZbp", "a", "x", "r", "vhpe", "fi", "qZ"]
- Test data
