Updated on 2025-09-07 GMT+08:00
IP Parsing Function
This section describes the IP parsing functions, including their syntax, parameters, and usage examples.
Function
geo_parse
Parses the country, province/state, and city information based on the IP address.
ip_cidrmatch
Checks whether the IP address belongs to the CIDR address block.
ip_version
Checks whether the IP address is IPv4 or IPv6.
ip_type
Checks whether the IP address is a private address or a public address.
ip_makenet
Translates a single IP address into a CIDR address block.
ip_makenet
Outputs the input CIDR address block in prefixlen or netmask.
ip_overlaps
Checks whether two network segments overlap.
ip2long
Converts an IP address in string to a long integer.
long2ip
Converts a long integer to an IP address in string.
geo_parse
Use the geo_parse function to parse the country, province/state, and city information based on the IP address.
  • Function format
    geo_parse(ip, keep_fields=None, ip_sep=None)
  • Parameter description
    Type
    Mandatory
    ip
    String
    Yes
    IP address, which is used to parse the country, province, and city information. If there are multiple IP addresses, you can use the ip_sep parameter to specify separators.
    keep_fields
    Tuple
    No
    Key information contained in the returned result. The supported keys are as follows:
    • city: city name.
    • province: province name.
    • country: country name.
    • isp: name of the network carrier.
    • lat: latitude of the location where the IP address is located.
    • lon: longitude of the location where the IP address is located.
    For example, keep_fields=("city","country") indicates that only the city and country information is output.
    In addition, keep_fields supports field renaming. For example, (("city","cty"),("country","state")) will output the fields as cty and state.
    Note: The keep_fields parameter is of the tuple type. If there is only one parameter, add a comma (,), for example, ("city",) or (("city","cty"),).
    ip_sep
    String
    No
    IP address separator, which is used to separate a character string containing multiple IP addresses into multiple IP addresses. The parsing result is returned in JSON format. The default value is None, indicating that no separation is performed.
  • Returned result
    Data in dictionary format.
  • Function example
    1. Query a single IP address.
      • Test data
          "ip": "192.168.0.1"
      • Processing rule
        e_set("geo_parse", geo_parse("192.168.0.1"))
      • Processing result (only available for public IP addresses)
        ip: 192.168.0.1
        geo_parse: {"city": "", "province": "", "country": "", "isp": "", "lat": "", "lon": ""}
    2. Query multiple IP addresses.
      • Test data
          "ip": "192.168.0.1"
      • Processing rule
        e_set("geo_parse", geo_parse("192.168.0.1,192.168.0.2", ip_sep=","))
        geo_parse: {"192.168.0.1": {"province": "", "country": "", "lat": "", "lon": ""}, "192.168.0.2": {"city": "", "province": "", "country": "", "isp": "", "lat": "", "lon": ""}}
        ip: 192.168.0.1
ip_cidrmatch
Use the ip_cidrmatch function to check whether the IP address belongs to the CIDR address block.
  • Function format
    ip_cidrmatch(cidr_subnet, ip, default="")
    Type
    Mandatory
    cidr_subnet
    String
    Yes
    CIDR address block.
    ip
    String
    Yes
    IP address.
    default
    String
    No
    This value is returned if the IP address does not match the CIDR address block.
  • Returned result
    If the IP address belongs to the CIDR block, true is returned. Otherwise, false is returned.
  • Function example
    1. The IPv4 address matches the CIDR address block.
      • Test data
          "subnet": "192.168.1.0/24"
      • Processing rule
        e_set("result",ip_cidrmatch(v("subnet"),"192.168.1.11"))
      • Processing result
        subnet: 192.168.1.0/24
        result:    true
    2. The IP address does not match the CIDR address block.
      • Test data
      • Processing rule
        e_set("result",ip_cidrmatch(v("subnet"),"192.168.100.10", default="error"))
      • Processing result
        result:    error
ip_version
Use the ip_version function to check whether the IP address is IPv4 or IPv6.
  • Function format
    ip_version(ip, default="")
    Type
    Mandatory
    ip
    String
    Yes
    Entered IP address.
    default
    String
    No
    This value is returned when the IP address version cannot be determined.
  • Returned result
    IPv4 or IPv6
  • Function example
    1. IPv4 address.
      • Test data
          "ip": "10.21.115.10"
      • Processing rule
        e_set("version",ip_version(v("ip")))
      • Processing result
        ip: 10.21.115.10
        version: IPv4
    2. IPv6 address.
      • Test data
          "ip": "2001:0db8:85a3:0000:0000:8a2e:0370:7334"
      • Processing rule
      • Processing result
        ip: 2001:0db8:85a3:0000:0000:8a2e:0370:7334
        version: IPv6
ip_type
Use the ip_type function to check whether the IP address is a private or public address.
  • Function format
    ip_type(ip, default="")
    Type
    Mandatory
    ip
    String
    Yes
    IP address.
    default
    String
    No
    This value is returned when the IP address type cannot be determined.
  • Returned result
    IP address type, which can be private, reserved, loopback, public, or allocated ripe ncc.
  • Function example
    1. Private IP address.
      • Test data
          "ip": "10.1.2.3"
      • Processing rule
        e_set("result",ip_type(v("ip")))
      • Processing result
        ip: 10.1.2.3
        result: private
    2. IPv6 address.
      • Test data
          "ip": "127.0.0.1"
      • Processing rule
      • Processing result
        ip: 127.0.0.1
        result: loopback
ip_makenet
Use the ip_makenet function to translate a single IP address into a CIDR address block.
  • Function format
    ip_makenet(ip, subnet_mask=None, default="")
    Type
    Mandatory
    ip
    String
    Yes
    IP address.
    subnet_mask
    String
    Yes
    Subnet mask. If the IP address is an IP address range, the subnet mask can be left blank.
    default
    String
    No
    This value is returned when the IP address cannot be converted into a CIDR address block.
  • Returned result
    CIDR address block.
  • Function example
    1. Convert an IP address range to a CIDR address block.
      • Test data
          "ip": "192.168.10.0-192.168.10.255"
      • Processing rule
        e_set("result",ip_makenet(v("ip")))
      • Processing result
        ip: 192.168.10.0-192.168.10.255
        result: 192.168.10.0/24
    2. Convert an IP address to a CIDR address block.
      • Test data
          "ip": "192.168.10.0"
      • Processing rule
        e_set("result",ip_makenet(v("ip"), "255.255.255.0"))
      • Processing result
        ip: 192.168.10.0
ip_to_format
Use the ip_to_format function to output the input CIDR address block in prefixlen or netmask.
  • Function format
    ip_to_format(cidr_subnet, want_prefix_len=0, default="")
    Type
    Mandatory
    cidr_subnet
    String
    Yes
    CIDR block. For example, 192.168.10.0/24.
    want_prefix_len
    Int
    No
    Return format. The default value is 0.
    • 0: no format
    • 1: prefix
    • 2: netmask
    • 3: IP address range
    default
    String
    No
    This value is returned when the input CIDR address block cannot be output in the format.
  • Returned result
    IP address in a specific format.
  • Function example
    1. Output the IP address in the IP address range format.
      • Test data
          "ip": "192.168.11.0/24"
      • Processing rule
        e_set("result",ip_to_format(v("ip"),3))
      • Processing result
        ip: 192.168.11.0/24
        result: 192.168.11.0-192.168.11.255
    2. Output the IP address in netmask format.
      • Test data
      • Processing rule
        e_set("result",ip_to_format(v("ip"),2))
      • Processing result
        ip: 192.168.11.0/24
        result: 192.168.11.0/255.255.255.0
    3. Output the IP address in prefix format.
      • Test data
      • Processing rule
        e_set("result",ip_to_format(v("ip"),1))
      • Processing result
        ip: 192.168.11.0/24
        result: 192.168.11.0/24
ip_overlaps
Use the ip_overlaps function to check whether two CIDR blocks overlap.
  • Function format
    ip_overlaps(cidr_subnet, cidr_subnet2, default="")
    Type
    Mandatory
    cidr_subnet
    String
    Yes
    CIDR address block 1.
    cidr_subnet2
    String
    Yes
    CIDR address block 2.
    default
    String
    No
    This value is returned when whether two CIDR address blocks overlap cannot be determined.
  • Returned result
    0: The two CIDR address blocks do not overlap.
    1: The two CIDR address blocks overlap at the end position.
    -1: The two CIDR address blocks overlap at the start position.
  • Function example
    1. Example 1: Two CIDR blocks do not overlap.
      • Test data
         "a": "192.168.0.0/24",
         "b": "192.168.1.0/24"
      • Processing rule
        e_set("result",ip_overlaps(v("a"),v("b")))
      • Processing result
        a: 192.168.0.0/24
        b: 192.168.1.0/24
        result: 0
    2. Example 2: Two CIDR addresses overlap at the start position.
      • Test data
         "a": "192.168.1.0/24",
         "b": "192.168.0.0/23"
      • Processing rule
      • Processing result
        a: 192.168.1.0/24
        b: 192.168.0.0/23
        result: 1
    3. Example 3: Two CIDR addresses overlap at the end position.
      • Test data
         "a": "192.168.0.0/23",
      • Processing rule
      • Processing result
        a: 192.168.0.0/23
        b: 192.168.1.0/24
        result: 1
ip2long
Use the ip2long function to convert an IP address in string to a long integer.
  • Function format
    ip2long(value,default=0)
    Type
    Mandatory
    value
    String
    Yes
    Value to be converted.
    default
    String
    No
    Value converted from an invalid IP address.
  • Returned result
    Long integer data after conversion.
  • Function example
    1. Normal parsing.
      • Test data
         "ip": "116.209.192.0"
      • Processing rule
        e_set("result",ip2long(v("ip")))
      • Processing result
        result: 1959903232
        ip: 116.209.192.0
    2. Invalid parsing.
      • Test data
         "ip": "116.209.abc.xxx"
      • Processing rule
        e_set("result",ip2long(v("ip"), "error"))
      • Processing result
        result: error
        ip: 116.209.abc.xxx
long2ip
Use the long2ip function to convert a long integer to an IP address in string.
  • Function format
    long2ip(value,default="")
    Type
    Mandatory
    value
    String
    Yes
    default
    String
    No
    Converts invalid long integer data to an empty string.
  • Returned result
    IP address converted from a long integer.
  • Function example
    1. Correct conversion.
      • Test data
         "data": "1959903232"
      • Processing rule
        e_set("ip",long2ip(v("data")))
      • Processing result
        data: 1959903232
        ip: 116.209.192.0
    2. Custom error handling after conversion failure.
      • Test data
         "data": "4294967296"
      • Processing rule
        e_set("ip",long2ip(v("data"), default="error"))
      • Processing result
        data: 4294967296
        ip: error
