Updated on 2026-09-18 GMT+08:00
Encoding and Decoding Functions
This section describes the encoding and decoding functions, including their syntax, parameters, and usage examples.
Function List
Type
Category
Function
Encode/Decode
String
str_encode
Encodes data.
str_decode
Decodes data.
Base64
base64_encoding
Encodes data using Base64.
base64_decoding
Decodes data using Base64.
HTML
html_encoding
Encodes data using HTML.
html_decoding
Decodes data using HTML.
URL
url_encoding
Encodes data using URL.
url_decoding
Decodes data using URL.
Compression/Decompression
Gzip compression library
gzip_compress
Compresses and encodes data.
gzip_decompress
Decompresses data.
Zlib compression library
zlib_compress
zlib_decompress
Decompresses data.
Hash digest
MD5
md5_encoding
Encodes data using MD5.
SHA1
sha1_encoding
Encodes data using SHA1.
Cyclic redundancy check
crc32_encoding
Calculates the cyclic redundancy check code of the data.
str_encode
Use the str_encode function to encode a string in a specified encoding format.
  • Function format
    str_encode(value, "utf8", errors="ignore")
  • Parameter description
    Type
    Mandatory
    value
    Any (automatically converted to string)
    Yes
    Value to be encoded.
    encoding
    String
    No
    Encoding format. The default format is UTF-8. ASCII is supported.
    errors
    String
    No
    Specifies the processing solution when characters cannot be identified according to the encoding format. Options:
    • ignore (default): Ignore the characters that cannot be identified.
    • strict: An error is reported and the log data is discarded.
    • replace : The unidentified part is replaced with the question mark (?).
    • xmlcharrefreplace: The unidentified part is replaced with the corresponding XML character.
  • Returned result
    Encoded string.
  • Function example
    1. Example 1
      • Test data
          "value": "test test"
      • Processing rule
        e_set("result", str_encode(v("value"), "ascii", errors="ignore"))
      • Processing result
        value: test test
        result: test
    2. Example 2
      • Test data
      • Processing rule
        e_set("result", str_encode(v("value"), "ascii", errors="strict"))
      • Processing result: An error is reported during execution.
    3. Example 3
      • Test data
      • Processing rule
        e_set("result", str_encode(v("value"), "ascii", errors="replace"))
      • Processing result
        value: test test
        result: test ??
    4. Example 4
      • Test data
      • Processing rule
        e_set("result", str_encode(v("value"), "ascii", errors="xmlcharrefreplace"))
      • Processing result
        value: test test
        result: test 测试
str_decode
Use the str_decode function to decode the input value in a specified encoding format.
  • Function format
    str_decode(value, "utf8", errors="ignore")
    Type
    Mandatory
    value
    Yes
    Value to be decoded.
    encoding
    No
    errors
    No
    • ignore (default): Ignore the characters that cannot be decoded.
    • replace : Replace the part that cannot be decoded with the question mark (?).
    • xmlcharrefreplace: Replace the part that cannot be decoded with the corresponding XML character.
  • Returned result
    Decoded value.
  • Function example
    • Test data
        "test": "asewds"
    • Processing rule
      e_set("encoding", str_decode(b'\xe4\xbd\xa0\xe5\xa5\xbd', "utf8", 'strict'))
    • Processing result
      test: asewds
      encoding: Hello
base64_encoding
Use the base64_encoding function to encode data using Base64.
  • Function format
    base64_encoding(value, format=None)
    Type
    Mandatory
    value
    String
    Yes
    format
    String
    No
    Base64 encoding protocol. The default value is format=RFC3548. You can also set it to format=RFC4648.
  • Returned result
    Encoded string.
  • Function example
    • Test data
        "str_en": "data to be encoded"
    • Processing rule
      e_set("str_base64",base64_encoding(v("str_en")))
    • Processing result
      str_en : data to be encoded
      str_base64 : ZGF0YSB0byBiZSBlbmNvZGVk
base64_decoding
Use the base64_decoding function to decode data using Base64.
  • Function format
    base64_decoding(value, format=None)
    Type
    Mandatory
    value
    String
    Yes
    format
    String
    No
    Base64 decoding protocol. The default value is format=RFC3548. You can also set it to format=RFC4648.
    RFC4648 Base64 decoding protocol uses equal signs (=) to pad the value to be decoded to a multiple of 4 bytes.
  • Returned result
    Decoded string.
  • Function example
    • Test data
        "str_de": "ZGF0YSB0byBiZSBlbmNvZGVk"
    • Processing rule
      e_set("str_de_base64",base64_decoding(v("str_de")))
    • Processing result
      str_de: ZGF0YSB0byBiZSBlbmNvZGVk
      str_de_base64: data to be encoded
html_encoding
Use the html_encoding function to encode data using HTML.
  • Function format
    html_encoding(value)
    Type
    Mandatory
    value
    String
    Yes
  • Returned result
    Encoded string.
  • Function example
    • Test data
        "str":"<img class=\"size-medium wp-image-113\" style=\"margin-left: 15px;\" title=\"su1\" src=\"http://aadoc.com/wp-content/uploads/2008/10/su1-300x194.jpg\" alt=\"\" width=\"300\" height=\"194\" />"
    • Processing rule
      e_set("str_html_en",html_encoding(v("str")))
    • Processing result
      str : <img class="size-medium wp-image-113" style="margin-left: 15px;" title="su1" src="http://aadoc.com/wp-content/uploads/2008/10/su1-300x194.jpg" alt="" width="300" height="194" />
      str_html_en : &lt;img class=&quot;size-medium wp-image-113&quot; style=&quot;margin-left: 15px;&quot; title=&quot;su1&quot; src=&quot;http://aadoc.com/wp-content/uploads/2008/10/su1-300x194.jpg&quot; alt=&quot;&quot; width=&quot;300&quot; height=&quot;194&quot; /&gt;
html_decoding
Use the html_decoding function to decode data using HTML.
  • Function format
    html_decoding(value)
    Type
    Mandatory
    value
    String
    Yes
  • Returned result
    Decoded string.
  • Function example
    • Test data
        "str": "&lt;img class=&quot;size-medium wp-image-113&quot; style=&quot;margin-left: 15px;&quot; title=&quot;su1&quot; src=&quot;http://aadoc.com/wp-content/uploads/2008/10/su1-300x194.jpg&quot; alt=&quot;&quot; width=&quot;300&quot; height=&quot;194&quot; /&gt;"
    • Processing rule
      e_set("str_html_de",html_decoding(v("str")))
    • Processing result
       "str": "&lt;img class=&quot;size-medium wp-image-113&quot; style=&quot;margin-left: 15px;&quot; title=&quot;su1&quot; src=&quot;http://aadoc.com/wp-content/uploads/2008/10/su1-300x194.jpg&quot; alt=&quot;&quot; width=&quot;300&quot; height=&quot;194&quot; /&gt;",
       "str_html_de": "<img class=\"size-medium wp-image-113\" style=\"margin-left: 15px;\" title=\"su1\" src=\"http://aadoc.com/wp-content/uploads/2008/10/su1-300x194.jpg\" alt=\"\" width=\"300\" height=\"194\" />"
url_encoding
Use the url_encoding function to encode data using URL.
  • Function format
    url_encoding(value, plus=false)
    Type
    Mandatory
    value
    String
    Yes
    plus
    Boolean
    No
    Whether to convert a space to a plus sign (+). The default value is false.
    • true: Convert a space to a plus sign (+).
    • false: Do not convert a space to a plus sign (+).
  • Returned result
    Encoded string.
  • Function example
    1. Example 1: Perform URL encoding on data.
      • Test data
          "content": "https://www.example.org/hello/asdah"
      • Processing rule
        e_set("url",url_encoding(v("content")))
      • Processing result
        content : https://www.example.org/hello/asdah
        url: https%3A%2F%www.example.org%2FHello%2Fasdah
    2. Example 2: Perform URL encoding on data. If the parameter plus is not specified, the space in the data is not converted to a plus sign (+).
      • Test data
          "content": "1 2+3:4"
      • Processing rule
        e_set("URL",url_encoding(v("content")))
      • Processing result
        content:1 2+3:4
        URL:1%202%2B3%3A4
    3. Example 3: Perform URL encoding on data. If the parameter plus is set to true, the space in the data is converted to a plus sign (+).
      • Test data
      • Processing rule
        e_set("URL", url_encoding(v("content"), plus=true))
      • Processing result
        content:1 2+3:4
        URL:1+2%2B3%3A4
url_decoding
Use the url_decoding function to decode data using URL.
  • Function format
    url_decoding(value, plus=false)
    Type
    Mandatory
    value
    String
    Yes
    plus
    Boolean
    No
    Whether to convert plus signs (+) to spaces. The default value is false.
    • true: Convert plus signs (+) to spaces.
    • false: Do not convert plus signs (+) to spaces.
  • Returned result
    Decoded string.
  • Function example
    1. Example 1: Perform URL decoding on data.
      • Test data
          "content": "https%3A%2F%www.example.org%2FHello%2Fasdah"
      • Processing rule
        e_set("URL",url_decoding(v("content")))
      • Processing result
        content : https%3A%2F%www.example.org%2FHello%2Fasdah
        URL : https://www.example.org/hello/asdah
    2. Example 2: Perform URL decoding on data. If the parameter plus is not specified, the plus sign (+) in the data is not converted to space.
      • Test data
          "content": "/answer?event_date=2022-06-30+09%3A06%3A53%20123"
      • Processing rule
      • Processing result
        content:/answer?event_date=2022-06-30+09%3A06%3A53%20123
        URL:/answer?event_date=2022-06-30+09:06:53 123
    3. Example 3: Perform URL decoding on data. If the parameter plus is set to true, the plus sign (+) in the data is converted to space.
      • Test data
      • Processing rule
        e_set("URL",url_decoding(v("content"),plus=true))
      • Processing result
        URL:/answer?event_date=2022-06-30 09:06:53 123
gzip_compress
Use the gzip_compress function to compress and encode data.
  • Function format
    gzip_compress(data, compresslevel=6, to_format="base64", encoding="utf-8")
    Type
    Mandatory
    data
    String
    Yes
    Data to be compressed.
    compresslevel
    Int
    No
    Specifies the compression level. The value is an integer ranging from 0 to 9. The default value is 6.
    • 1: The compression speed is the fastest, but the compression ratio is the smallest.
    • 9: The compression speed is the slowest, but the compression ratio is the largest.
    • 0: no compression.
    Other levels (2 to 8): As the value increases, the compression speed slows down and the compression ratio increases. You can select a level based on the compression speed and data size after compression.
    to_format
    String
    No
    Specifies the encoding format of the compressed data. Currently, Base64 and hex encoding are supported.
    encoding
    String
    No
    Encoding format of the original uncompressed data. The default value is utf-8.
  • Returned result
    Encoded string.
  • Function example (for reference only)
    1. Example 1: Compress log fields and encode them using Base64.
      • Test data
          "content":"I always look forward to my holidays whether I travel or stay at home."
      • Processing rule
        e_set("base64_encode_gzip_compress",gzip_compress(v("content"),to_format="base64"))
      • Processing result
        content: I always look forward to my holidays whether I travel or stay at home. base64_encode_gzip_compress: H4sIAA8JXl4C/xXK0QmAMAwFwFXeBO7RMQKNREx5kAZDtle/7wbES3rDyRsnoyQmklgNo1/ztzJN08BAhjzqYGCnNCS/tPR4AcgrnWVGAAAA
    2. Example 2: Encode log fields using hex format.
      • Test data
           "content":"H4sIAA8JXl4C/xXK0QmAMAwFwFXeBO7RMQKNREx5kAZDtle/7wbES3rDyRsnoyQmklgNo1/ztzJN08BAhjzqYGCnNCS/tPR4AcgrnWVGAAAA"
      • Processing rule
        e_set("hex_encode_gzip_compress", gzip_compress(v("content"), to_format="hex"))
      • Processing result
        content:H4sIAA8JXl4C/xXK0QmAMAwFwFXeBO7RMQKNREx5kAZDtle/7wbES3rDyRsnoyQmklgNo1/ztzJN08BAhjzqYGCnNCS/tPR4AcgrnWVGAAAA hex_encode_gzip_compress:1f8b08004a478c6202ff0dc1dd0e43301800d047aa65156e3ff52f4a2ba17649c43255194d4a9f9e73527c64007e2e2426e81485c35628c1c42616535079bc6405e5d1e92ef009b59c906786a879efe1c50fb55d6c5de44cb717b2dae6d4f103f8feecbf4f88a2a441bae618c679575d9bc0e306907876806c000000
gzip_decompress
Use the gzip_decompress function to decompress data.
  • Function format
    gzip_decompress(data, from_format="base64", encoding="utf-8")
    Type
    Mandatory
    data
    Any
    Yes
    Data to be decompressed.
    from_format
    String
    No
    Encoding format of the data to be decompressed. Currently, Base64 and hex formats are supported.
    encoding
    String
    No
    Encoding format of the original uncompressed data. The default value is utf-8. For other encoding formats, see standard encoding formats.
  • Returned result
    Decompressed data.
  • Function example
    1. Example 1: Decode log fields using Base64.
      • Test data
          "content": "H4sIAA8JXl4C/xXK0QmAMAwFwFXeBO7RMQKNREx5kAZDtle/7wbES3rDyRsnoyQmklgNo1/ztzJN08BAhjzqYGCnNCS/tPR4AcgrnWVGAAAA"
      • Processing rule
        e_set("gzip_decompress",gzip_decompress(v("content"),from_format="base64"))
      • Processing result
        content: H4sIAA8JXl4C/xXK0QmAMAwFwFXeBO7RMQKNREx5kAZDtle/7wbES3rDyRsnoyQmklgNo1/ztzJN08BAhjzqYGCnNCS/tPR4AcgrnWVGAAAA gzip_decompress: I always look forward to my holidays whether I travel or stay at home.
    2. Example 2: Decode log fields using hex format.
      • Test data
        "content":"1f8b0800bff8856202ff0dc1dd0e43301800d047aa65156e3ff52f4a2ba17649c43255194d4a9f9e73527c64007e2e2426e81485c35628c1c42616535079bc6405e5d1e92ef009b59c906786a879efe1c50fb55d6c5de44cb717b2dae6d4f103f8feecbf4f88a2a441bae618c679575d9bc0e306907876806c000000"
      • Processing rule
        e_set("gzip_decompress", gzip_decompress(v("content"), from_format="hex"))
      • Processing result
        content:1f8b0800bff8856202ff0dc1dd0e43301800d047aa65156e3ff52f4a2ba17649c43255194d4a9f9e73527c64007e2e2426e81485c35628c1c42616535079bc6405e5d1e92ef009b59c906786a879efe1c50fb55d6c5de44cb717b2dae6d4f103f8feecbf4f88a2a441bae618c679575d9bc0e306907876806c000000
        gzip_decompress:H4sIAA8JXl4C/xXK0QmAMAwFwFXeBO7RMQKNREx5kAZDtle/7wbES3rDyRsnoyQmklgNo1/ztzJN08BAhjzqYGCnNCS/tPR4AcgrnWVGAAAA
zlib_compress
Use the zlib_compress function to compress and encode data.
  • Function format
    zlib_compress(data, compresslevel=6, to_format="base64", encoding="utf-8")
    Type
    Mandatory
    data
    String
    Yes
    compresslevel
    Int
    No
    to_format
    String
    No
    Specifies the format for encoding compressed data. Currently, only Base64 encoding is supported.
    encoding
    String
    No
  • Returned result
    Encoded data.
  • Function example
    • Test data
    • Processing rule
      e_set("zlib_compress", zlib_compress(v("content"), to_format="base64"))
    • Processing result (for reference only)
      zlib_compress: eJwVytEJgDAMBcBV3gTu0TECjURMeZAGQ7ZXv+8GxEt6w8kbJ6MkJpJYDaNf87cyTdPAQIY86mBgpzQkv7T0eAGNshln
zlib_decompress
  • Function format
    zlib_decompress(data, from_format="base64", encoding="utf-8")
    Type
    Mandatory
    data
    String
    Yes
    from_format
    String
    No
    Encoding format of the decompressed data. Currently, only Base64 encoding is supported.
    encoding
    String
    No
  • Returned result
    Decompressed data.
  • Function example
    • Test data
        "content": "eJwVytEJgDAMBcBV3gTu0TECjURMeZAGQ7ZXv+8GxEt6w8kbJ6MkJpJYDaNf87cyTdPAQIY86mBgpzQkv7T0eAGNshln"
    • Processing rule
      e_set("zlib_decompress", zlib_decompress(v("content"), from_format="base64"))
    • Processing result
      content: eJwVytEJgDAMBcBV3gTu0TECjURMeZAGQ7ZXv+8GxEt6w8kbJ6MkJpJYDaNf87cyTdPAQIY86mBgpzQkv7T0eAGNshln
      zlib_decompress: I always look forward to my holidays whether I travel or stay at home.
md5_encoding
Use the md5_encoding function to encode data using MD5.
  • Function format
    md5_encoding(value, format="hex")
    Type
    Mandatory
    value
    String
    Yes
    format
    String
    No
    Options: binary and hex (default).
  • Returned result
    Encoded string.
  • Function example
    1. Example 1
      • Test data
          "str": "GeeksforGeeks"
      • Processing rule
        e_set("str_md5_en",md5_encoding(v("str")))
      • Processing result
        str : GeeksforGeeks
        str_md5_en : f1e069787ece74531d112559945c6871
    2. Example 2
      • Test data
      • Processing rule
        e_set("str_md5_en",base64_encoding(md5_encoding(v("str"), format="binary")))
      • Processing result
        str : GeeksforGeeks
        str_md5_en : 8eBpeH7OdFMdESVZlFxocQ==
sha1_encoding
Use the sha1_encoding function to encode data using SHA-1.
  • Function format
    sha1_encoding(value, format=None)
    Type
    Mandatory
    value
    String
    Yes
    format
    String
    No
    Encoding type. Options: SHA1 (default), SHA256, SHA384, SHA224, SHA512.
  • Returned result
    Encoded string.
  • Function example
    • Test data
    • Processing rule
      e_set("str_sha1",sha1_encoding(v("str")))
      e_set("str_sha512",sha1_encoding(v("str"),format='SHA512'))
      e_set("str_sha224",sha1_encoding(v("str"),format='SHA224'))
      e_set("str_sha384",sha1_encoding(v("str"),format='SHA384'))
      e_set("str_sha256",sha1_encoding(v("str"),format='SHA256'))
    • Processing result
      str : GeeksforGeeks
      str_sha1 : 4175a37afd561152fb60c305d4fa6026b7e79856
      str_sha512 : 0d8fb9370a5bf7b892be4865cdf8b658a82209624e33ed71cae353b0df254a75db63d1baa35ad99f26f1b399c31f3c666a7fc67ecef3bdcdb7d60e8ada90b722
      str_sha224 : 173994f309f727ca939bb185086cd7b36e66141c9e52ba0bdcfd145d
      str_sha384 : d1e67b8819b009ec7929933b6fc1928dd64b5df31bcde6381b9d3f90488d253240490460c0a5a1a873da8236c12ef9b3
      str_sha256 : f6071725e7ddeb434fb6b32b8ec4a2b14dd7db0d785347b2fb48f9975126178f
crc32_encoding
Use the crc32_encoding function to calculate the cyclic redundancy check code of the data.
  • Function format
    crc32_encoding(data, input_format="raw", input_encoding="utf-8")
    Type
    Mandatory
    data
    String
    Yes
    Data to compute cyclic redundancy check code for.
    input_format
    String
    No
    Input format. The default value is raw. Options:
    • raw: bytes format
    • hex: hexadecimal format
    • base64: Base64 encoding format
    input_encoding
    String
    No
    Character encoding format. This parameter is mandatory only when input_format is set to raw. The default value is utf-8.
  • Returned result
    Cyclic redundancy check code of the input data.
  • Function example
    1. Example 1: Calculate the cyclic redundancy check code of the test field.
      • Test data
          "test": "aatest"
      • Processing rule
        e_set("str_crc32", crc32_encoding(v("test")))
      • Processing result
        str_crc32: 788759217
        test: aatest
    2. Example 2: Connect the fields test1 and test2, performs MD5 encoding, and calculates the cyclic redundancy check code.
      • Test data
        "test1": "test1",
        "test2": "test2"
      • Processing rule
        e_set(
            "str_crc32",
            crc32_encoding(
                md5_encoding(str_join("+", v("test1"), v("test2")), format="binary")
      • Processing result
        str_crc32:369733261
        test1:test1
        test2:test2
    3. Example 3: Calculates the cyclic redundancy check code of the field test. The value is in Base64 encoding format.
      • Test data
         "test": "Taloz+e+PzP3NltrEXiCig=="
      • Processing rule
        e_set("str_crc32", crc32_encoding(v("test"), input_format="base64"))
      • Processing result
        str_crc32:1093789404
        test:Taloz+e+PzP3NltrEXiCig==
