List Function
This section describes list functions, including their syntax, parameters, and usage examples.
Function List
Function |
Description |
Creates a list. |
Inserts elements at a specific position in the list. |
Adds elements to the end of the list. |
Deletes elements from a specific position in the list. |
Reverses sorting list. |
Obtains an element in a list or tuple. |
lst_make
Use the lst_make function to create a list.
- Function format
lst_make(value1, value2, ...)
- Parameter description
Type
Mandatory
value1
String
Yes
Element of the list.
value2
String
Yes
- Returned result
Created list.
- Function example
- Test data
{ "content":"test" }
- Processing rule
e_set("hello", lst_make("k1","k2"))
- Processing result
content:test hello:["k1", "k2"]
- Test data
lst_insert
Use the lst_insert function to insert elements at a specific position in the list.
- Function format
lst_insert(list_string, location, value1, value2, ...)
Type
Mandatory
list_string
List
Yes
List to be operated.
location
Number
Yes
Position to be inserted.
value1
String
Yes
Element to be inserted.
value2
String
No
- Returned result
List after the element is inserted.
- Function example
- Test data
{ "ctx": ["k1","k2"] }
- Processing rule
e_set("hello", lst_insert(v("ctx"), 0, "k0"))
- Processing result
ctx: ["k1","k2"] hello: ["k0", "k1", "k2"]
- Test data
lst_append
Use the lst_append function to add elements to the end of the list.
- Function format
lst_append(list_string, value1, value2, ...)
Type
Mandatory
list_string
List
Yes
value1
String
Yes
Element to be appended.
value2
String
No
- Returned result
List after the element is appended.
- Function example
- Test data
{ "ctx": [ "k1", "k2" ] }
- Processing rule
e_set("hello", lst_append(v("ctx"), "k3"))
- Processing result
ctx: ["k1","k2"] hello: ["k1", "k2", "k3"]
- Test data
lst_delete_at
Use the lst_delete_at function to return the list after the element is deleted.
- Function format
lst_delete_at(list_string, location)
Type
Mandatory
list_string
list
Yes
location
Number
Yes
Position of the element to be deleted. The first element starts from position 0.
- Returned result
List of dictionary keys.
- Function example
- Test data
- Processing rule
e_set("hello", lst_delete_at(v("ctx"),1))
- Processing result
ctx: ["k1","k2"] hello: ["k1"]
- Test data
lst_reverse
Use the lst_reverse function to reverse the sorting list.
- Function format
lst_reverse(list_string)
Type
Mandatory
list_string
List
Yes
- Returned result
Reversed list.
- Function example
- Test data
{ "ctx":["v1","v2"] }
- Processing rule
e_set("hello", lst_reverse(v("ctx")))
- Processing result
ctx: ["v1","v2"] hello: ["v2","v1"]
- Test data
lst_get
Use the lst_get function to obtain an element in a list or tuple.
- Function format
lst_get(list_string, location)
Type
Mandatory
ist_string
List
Yes
location
Int
Yes
The number is counted from 0. For example, if the data is ["a","b","c"], the obtained element positions are 0, 1, and 2.
- Returned result
One of the elements in the list.
- Function example
- Test data
- Processing rule
e_set("hello", lst_get(v("ctx"),1))
- Processing result
ctx: ["v1","v2"] hello: "v2"
- Test data
