Updated on 2025-11-18 GMT+08:00
Dictionary Function
This section describes dictionary functions, including their syntax, parameters, and usage examples.
Function List
Function
dct_make
Creates a dictionary.
dct_update
Updates a dictionary.
dct_delete
Deletes dictionary key-value pairs.
dct_keys
Obtains the key list of a dictionary.
dct_values
Obtains the dictionary value list.
dct_get
Obtains the value of a key in a dictionary.
dct_make
Use the dct_make function to create a dictionary.
  • Function format
    dct_make(key1, value1, key2, value2, ...)
  • Parameter description
    Type
    Mandatory
    key
    String
    Yes
    String used as the dictionary key.
    value
    String
    Yes
    Character string used as the dictionary value.
  • Returned result
    Constructed dictionary.
  • Function example
    • Test data
        "content": "test"
    • Processing rule
      e_set("hello", dct_make("k1","v1","k2","v2"))
    • Processing result
      content:test
      hello:{"k1": "v1", "k2": "v2"}
dct_update
Use the dct_update function to update a dictionary.
  • Function format
    dct_update(dict1, dict2)
    Type
    Mandatory
    dict1
    dict
    Yes
    Target dictionary to be updated.
    dict2
    dict
    Yes
    New dictionary to be added.
  • Returned result
    Updated dictionary.
  • Function example
    • Test data
        "ctx": {
          "k1": "v1",
          "k2": "v2"
    • Processing rule
      e_set("hello", dct_update(v("ctx"), {"k3": "v3"}))
    • Processing result
      ctx: {"k1":"v1","k2":"v2"}
      hello: {"k1": "v1", "k2": "v2", "k3": "v3"}
dct_delete
Use the dct_delete function to delete dictionary key-value pairs.
  • Function format
    dct_delete(dict, key1, key2, ...)
    Type
    Mandatory
    dict
    dict
    Yes
    Target dictionary whose key-value pairs need to be deleted.
    key1
    String
    Yes
    Key of the key-value pair to be deleted.
    key2
    String
    No
  • Returned result
    Dictionary after the deletion.
  • Function example
    • Test data
        "ctx": {
          "k1": "v1",
          "k2": "v2"
    • Processing rule
      e_set("hello", dct_delete(v("ctx"), "k2"))
    • Processing result
      hello: {"k1":"v1"}
dct_keys
Use the dct_keys function to obtain the key list of a dictionary.
  • Function format
    dct_keys(dict)
    Type
    Mandatory
    dict
    dict
    Yes
    Dictionary data.
  • Returned result
    List of dictionary keys.
  • Function example
    • Test data
        "ctx": {
          "k1": "v1",
          "k2": "v2"
    • Processing rule
      e_set("hello", dct_keys(v("ctx")))
    • Processing result
      hello: ["k1","k2"]
dct_values
Use the dct_values function to obtain the dictionary value list.
  • Function format
    dct_values(dict)
    Type
    Mandatory
    dict
    dict
    Yes
    Dictionary data.
  • Returned result
    List of dictionary values.
  • Function example
    • Test data
        "ctx": {
          "k1": "v1",
          "k2": "v2"
    • Processing rule
      e_set("hello", dct_values(v("ctx")))
    • Processing result
      hello: ["v1","v2"]
dct_get
Use the dct_get function to obtain the value of a key in a dictionary.
  • Function format
    dct_get(dict,key,default=None)
    Type
    Mandatory
    dict
    dict
    Yes
    Dictionary data.
    key
    String
    Yes
    Key of the value to be obtained.
    default
    String
    No
    If the key does not exist, this value is returned.
  • Returned result
    Value of a dictionary key.
  • Function example
    1. Example 1:
      • Test data
          "ctx": {
            "k1": "v1",
            "k2": "v2"
      • Processing rule
        e_set("hello", dct_get(v("ctx"), "k1"))
      • Processing result
        hello: v1
    2. Example 2:
      • Test data
          "ctx": {
            "k1": "v1",
            "k2": "v2"
      • Processing rule
        e_set("hello", dct_get(v("ctx"), "k3",default="123"))
      • Processing result
        hello: 123
