LTS SDK Access Error Codes
If an error occurs when you use the LTS SDK, rectify the fault by referring to Table 1.
| Status Code | Error Code | Message | Description | Solution |
| Parameter errors (LTS.00XX) | LTS.0001 | %@ is null. | %@ is null. | Set the parameter and try again. |
| LTS.0002 | %@ is invalid. | The type or format of %@ is invalid. | Set valid parameters and try again. | |
| LTS.0003 | The length of %@ exceeds the maximum value of %@. | Too many characters. | Modify the parameter and try again. | |
| LTS.0004 | The value of %@ must be between %@ and %@. | The value is out of the permitted range. | Modify the parameter and try again. | |
| LTS.0006 | %@ doesn't match pattern. | The parameter does not match the regular expression. | Set valid parameters and try again. | |
| LTS.0007 | Invalid configuration parameters. | Invalid parameters. | Set valid parameters and try again. | |
| LTS.0009 | Unsupported region. | The region is not supported. | Switch to the cn-north-4 region. | |
| Integration errors (LTS.01XX) | LTS.0100 | The LTSSDK is not initialized. | The SDK has not been initialized. | Set valid parameters to initialize the SDK. |
| LTS.0102 | The LTSSDK requires %@ or higher. | The OS version must be %@ or higher. | Ensure that the OS version meets requirements. | |
| LTS.0103 | Open database failed, code=%@. | Failed to open the database. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0104 | Create database table failed, code=%@, error=%@. | Failed to create the data table. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0105 | Insert into database failed, code=%@, error=%@. | Failed to insert data. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0106 | Delete from database failed, code=%@, error=%@. | Failed to delete the data. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0107 | Select from database failed, code=%@, error=%@. | Failed to query the data. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0108 | Close database failed, code=%@. | Failed to close the database. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0109 | Reduce database size failed, code=%@, error=%@. | Failed to reduce the database size. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0110 | Begin transaction failed, code=%@, error=%@. | Failed to enable the transaction. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0111 | Commit transaction failed, code=%@, error=%@. | Failed to submit the transaction. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0112 | The count of database records exceeds the maximum value of %@, will delete %@ records before inserting. | There are too many logs. | Automatically delete old logs before inserting new logs. | |
| LTS.0113 | Add column(%@) to database failed, code=%d, error=%s. | Failed to add a field to the database table. | Handle the problem based on the SQLite 3 error code. | |
| LTS.0114 | Update column(%@) to database failed, code=%d, error=%s. | Failed to update a field in the database table. | Handle the problem based on the SQLite 3 error code. | |
| System errors (LTS.02XX) | LTS.0201 | Request signature failed. | Failed to sign the network request. | Check whether the region and device time (time zone) are correct. |
| LTS.0202 | Write to file failed. | Failed to write data into the file. | Check the permissions on the file. | |
| LTS.0203 | No file read and write permissions. | No file read and write permissions. | Grant the read and write permissions on the file or directory. | |
| Network errors (LTS.03XX) | LTS.0300 | Request failed, response code=%@, error=%@. | Failed to send the request. | Refer to the error codes in the API Reference. |
