Overview
LTS can analyze structured logs with SQL query syntax and display analysis results in various charts, catering to visualization needs of different O&M and operations analysis scenarios.
With more than 40 out-of-the-box dashboard templates and preset sample data that are easy to use and configure, LTS lowers the usage threshold and reduces repetitive development work. Cloud service logs ingested to LTS can be directly displayed in dashboard templates. This helps enterprises realize digital operations based on log data and facilitates digital transformation.
| Method | Description |
| Statistical charts | Statistical charts, such as tables, bar charts, and line charts, are rendered by LTS based on SQL query syntax. For details, see Visualizing Logs in Statistical Charts. The old SQL engine will soon be replaced with a new, more powerful one. You'll then be able to use the pipe character (|) to combine search and analysis statements for chart configuration. The new SQL engine is compatible with the SQL-92 standard but has a slightly different syntax from the old engine. If a query fails, you need to manually modify the SQL statement. |
| Dashboards | LTS provides dashboards for real-time data analysis. A dashboard consolidates and synchronously saves various statistical charts derived from SQL query and analysis. For details, see Visualizing Logs in Dashboards. LTS provides multiple out-of-the-box dashboard templates. For details, see Dashboard Templates (SQL Analysis). |
This function is available to all users in regions CN South-Guangzhou, CN North-Beijing4, CN East-Shanghai1, CN-Hong Kong, CN Southwest-Guiyang1, CN North-Beijing1, and AP-Singapore. It is also available to whitelisted users in regions CN East-Shanghai2, CN South-Shenzhen, AP-Bangkok, ME-Riyadh, and AP-Jakarta.
