Updated on 2025-12-05 GMT+08:00
DCS Dashboard Template
DCS is an in-memory database service. It is compatible with Redis, an in-memory database engine, and meets your requirements for high concurrency and fast data access. LTS collects, stores, and queries cloud resource operation records. You can use these records to perform security analysis, track resource changes, audit compliance, and locate faults.
LTS provides a one-stop wizard to collect DCS logs. The DCS audit log center dashboard displays charts such as the number of access users, access clients, and audit logs.
DCS Audit Log Center
  1. Log in to the LTS console.
  2. In the navigation pane, choose Dashboards.
  3. Choose DCS dashboard templates under Dashboard Templates and click DCS audit log center to view the chart details.
    • Users. The associated query and analysis statement is:
      select count(distinct(user)) as user_num
    • Clients. The associated query and analysis statement is:
      select count(distinct(client_addr)) as client_num
    • Audit Logs. The associated query and analysis statement is:
      select count(1) as log_num
    • Average Response Time. The associated query and analysis statement is:
      select avg(use_time) as avg_time
    • Average QPS. The associated query and analysis statement is:
      select count(*) / CAST((TIMESTAMPDIFF (minute, MIN(__time),MAX(__time))+1) as FLOAT)
    • Top 5 Users. The associated query and analysis statement is:
      select user, count(1) as 'user_count' group by user order by count(1) desc LIMIT 5
    • Top 5 Clients. The associated query and analysis statement is:
      select client_addr, count(1) as 'remote_count' group by client_addr order by count(1) desc limit 5
    • Top 5 Commands. The associated query and analysis statement is:
      select command_name, count(1) as 'command_count' group by command_name order by count(1) desc
    • Hot Keys. The associated query and analysis statement is:
      SELECT count(*) as 'count',  command_keys GROUP by command_keys order by count(*) desc limit 5
    • Audit Log Details. The associated query and analysis statement is:
      select  "client_addr" as 'Client IP Address',"client_type" as 'Client Type',"server_addr" as 'Server IP Address',"command_name" as 'Command',"command_keys" as 'Keys',"command_param" as 'Command Content',"command_type" as 'Command Type',"use_time" as 'Execution Duration',"time" as 'Executed',"db" as 'DB',"user" as 'Username',"instance_id" as 'Instance ID',"role" as 'Node Role',"extend" as 'Extended Information'
