Help Center/ Log Tank Service/ User Guide/ Log Alarms/ Configuring Log Alarm Action Rules/ Creating a Message Template on the LTS Console
Updated on 2025-01-24 GMT+08:00
A message template defines the format of alarm notification messages sent to subscribers. LTS provides built-in message templates. Subscribers can select templates based on protocols. If the template of a specified protocol does not exist, the built-in template of that protocol is used to send messages to subscribers. When using a message template to send alarm notification messages, the system automatically replaces the template variables with the content in the alarm rule.
  1. Log in to the LTS console.
  2. Choose Log Alarms in the navigation pane and click the Alarm Action Rules tab.
    By default, LTS provides the following built-in message templates. If no message content is configured in your selected template, LTS uses a built-in template instead.
    • keywords_template (Chinese): keyword alarm template
    • keywords_template (English): keyword alarm template
    • sql_template (Chinese): SQL alarm template
    • sql_template (English): SQL alarm template
  3. Click Create on the Message Templates tab page. On the displayed page, set the required parameters.
    • The email content supports HTML tags and message preview.
    • Templates such as WeCom, Lark, and DingTalk support markdown syntax and message preview.
    • You can create up to 100 message templates for AOM and LTS. If there are already 100 templates, delete unnecessary templates before creating a new one.
    Table 1 Message template parameters
    Verification Rule
    Example
    Template Name
    Message template name.
    Include digits, letters, underscores (_), and hyphens (-). Do not start or end with an underscore or hyphen. (Max. 100 characters)
    LTS-test
    Description of the template.
    Include digits, letters, and underscores (_). Do not start or end with an underscore. (Max. 1,024 characters)
    Message Header
    Default message header to be added in messages.
    • Chinese (Simplified)
    • English
    • English: "Dear user,"
    • "Dear user,"
    Notification method
    Notification method.
    • Email
    • SMS
    • HTTP/HTTPS
    • DingTalk
    • Lark
    • WeCom
    • Voice
      The voice function is available only to whitelisted users. To use it, submit a service ticket.
    Topic
    Message topic.
    Customize the topic name or use variables. (Max. 512 characters)
    Only email templates need a topic name.
    test
    Body
    Message content.
    Add Variable
    • Original rule name: ${event_name}
    • Alarm severity: ${event_severity}
    • Occurrence time: ${starts_at}
    • Occurrence region: ${region_name}
    • Huawei Cloud account: ${domain_name}
    • Alarm source: $event.metadata.resource_provider
    • Resource type: $event.metadata.resource_type
    • Resource ID: ${resources}
    • Alarm status: $event.annotations.alarm_status
    • Expression: $event.annotations.condition_expression
    • Current value: $event.annotations.current_value
    • Expression with a value: $event.annotations.condition_expression_with_value
    • Statistical period: $event.annotations.frequency
    • Rule name: $event.annotations.alarm_rule_alias
    • Frequency: $event.annotations.notification_frequency
    • Original log group name: $event.annotations.results[0].log_group_name
    • Original log stream name: $event.annotations.results[0].log_stream_name
    • Variables supported by keyword alarms:
      1. Query time: $event.annotations.results[0].time
      2. Query logs: (The maximum log size is 2 KB. If a log exceeds 2 KB, the extra part will be truncated and discarded.)
        $event.annotations.results[0].raw_results
      3. Query URL:
        $event.annotations.results[0].url
      4. Log group/stream name: $event.annotations.results[0].resource_id
        Only the original name of the log group or log stream created for the first time can be added. The modified log group or log stream name cannot be added.
      5. Enterprise project ID of the log stream: $event.annotations.results[0].eps_id
      6. Query custom field: $event.annotations.results[0].fields.xxx
        xxx indicates the structured fields and system fields (such as hostIP and hostName) of the raw logs. The maximum size of a log field is 1 KB. If a field exceeds 1 KB, the extra part will be truncated and discarded.
    • Variables supported by SQL alarms:
      1. Log group/stream names of chart 0: $event.annotations.results[0].resource_id
        0 indicates the first chart, 1 indicates the second chart, and so on.
      2. Query statement of chart 0: $event.annotations.results[0].sql
      3. Query time of chart 0: $event.annotations.results[0].time
      4. Query URL of chart 0: $event.annotations.results[0].url
      5. Query log of chart 0: $event.annotations.results[0].raw_results
      6. Chart 0 Log Stream Enterprise Project ID: $event.annotations.results[0].eps_id
    Copy from Existing
    • keywords_template
    • sql_template
    • sql_template
    • keywords_template
    • Custom templates (created with variables)
    ${event_name}
    ${event_severity}
    ${starts_at}
    ${region_name}
  4. When the configuration is complete, click OK.
    When creating a message template on the LTS console, if you are prompted that the creation fails because the template name is not unique, perform the following steps to rectify the fault:
    1. Check whether the message template name already exists.
      If yes, change the name. Message template names must be unique in both LTS and AOM because the two services share the same data source. If you have created a message template named test in AOM, you cannot create a message template with the same name in LTS.
    2. Check whether the number of message templates exceeds the quota.
Modifying a Message Template
  1. In the message template list, click Modify in the row that contains the target template, and modify the template according to Table 1. The template name cannot be modified.
    Built-in message templates cannot be modified.
  2. Click OK.
Copying a Message Template
  1. In the message template list, click Copy in the row that contains the target template. Set a new template name.
  2. Click OK.
Deleting a Message Template
  1. In the message template list, click Delete in the Operation column of the target template.
    Built-in message templates cannot be deleted.
  2. Click OK.
Deleting Message Templates in a Batch
  1. In the message template list, select the templates to be deleted and click Delete.
  2. Click OK.
Exporting Message Templates
  1. In the message template list, select the templates to be exported and click Export.
  2. Click Export all data to an XLSX file or Export selected data to an XLSX file. After the data is exported, you can view it on the local PC.
