Help Center/ Log Tank Service/ User Guide/ Log Transfer/ Transferring Logs to DWS
Updated on 2026-05-12 GMT+08:00
DWS is a scalable, fully managed, out-of-the-box analytic database service for online data processing, powered by the Huawei Cloud infrastructure. By transferring logs to DWS, you can map structured log fields directly into DWS database tables. This log transfer process is optional and should be implemented based on your service scenarios.
Currently, this function is available only in regions CN North-Beijing4, CN East-Shanghai1, CN South-Guangzhou, and AP-Singapore. To use this function in other regions, submit a service ticket.
Billing
LTS charges you based on the actual volume of logs transferred. For details, see LTS Pricing Details. In addition, you will be billed for your DWS storage usage. For details, see DWS Pricing Details.
  1. Log in to the LTS console.
  2. In the navigation pane, choose Log Transfer.
  3. Click Configure Log Transfer in the upper right corner.
  4. On the displayed page, select DWS Cluster for Transfer Destination and configure parameters.
    Table 1 Transfer parameters
    Example Value
    Enable Transfer
    Specify whether to enable log transfer.
    Enable
    Select a cloud service to which logs are transferred.
    DWS Cluster
    Log Group Name
    Select a log group.
    Log Stream Name
    Select a log stream.
    Log streams already configured with DWS transfer settings cannot be selected again.
    Cluster
    Name of the created cluster.
    test
    Database
    Database name of the cluster. There are two database types: gaussdb and postgres. The default cluster database is gaussdb.
    gaussdb
    Username
    Username of the database administrator.
    lts-test
    Password
    Password of the database administrator.
    Schema
    Name of a collection of database objects.
    Table
    Name of a table in the schema.
    Field Mapping
    Maps system reserved fields and structured fields and types configured in logs to database fields.
    LTS provides 13 system reserved fields: hostIP, hostId, hostName, pathFile, collectTime, clusterName, clusterId, podName, containerName, regionName, projectId, logGroupName, and logStreamName.
    Structured fields in logs can be transferred to DWS only when the structured field type and the database table field type are the same.
    • Click of the structured field and table field drop-down lists to select the fields to transfer.
    • Click in the Operation column to delete a field that does not need to be transferred.
    • Click to add fields to be transferred.
    hostIP
  5. Click OK.
    • After a transfer task is created, you can view, modify, and delete it.
    • After a transfer task is deleted, the logs that have been transferred remain in DWS.
      Deleting a transfer task will stop log transfer, and the deleted task cannot be restored. Exercise caution when performing this operation.
    • Delete a single transfer task:
      1. Click Delete in the Operation column of the target task.
      2. In the displayed dialog box, click OK.
    • Delete transfer tasks in batches:
      1. Select the transfer tasks to be deleted and click Delete above the list.
Helpful Links
  • If you have any questions when configuring log transfer, see Log Transfer in the FAQ.
  • You can create, query, and delete log transfer tasks by calling APIs. For details, see Log Transfer.
