Updated on 2025-12-05 GMT+08:00
Digital Line Chart
A digital line chart combines a line chart and a number chart to display the trend and key data points at the same time. This helps users better understand data and its change trend to make better service decisions.
Checking Digital Line Charts
  1. Log in to the LTS console.
  2. On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
  3. Click the Charts tab.
    The old log analysis function is going offline. You are advised to use the new SQL engine on the Charts tab page to configure charts. This new engine is more powerful, allowing you to use the pipe character (|) to combine search and analysis statements.
  4. Enter a query and analysis statement, set a time range, and click Search. For detailed syntax, see SQL Functions.
  5. Click to display the queried data in a digital line chart. Set parameters in the General Settings right pane by referring to Table 1.
    Table 1 Digital line chart parameters
    Type
    Query/Analysis
    X Axis
    Numeric or string data is supported.
    Y Axis
    Numeric or string data is supported. You can select multiple data records.
    Chart Mode
    Line Shape
    Line type. Select Straight or Curved.
    Main Items
    Title Font Size
    Sets the font size of the chart title.
    Number Format
    Displays data in the specified format.
    Data Text Size
    Font size of the displayed value. The value ranges from 12 px to 80 px.
    Data Unit
    Unit of the displayed value.
    Unit Text Size
    Font size of the displayed value unit. The value ranges from 12 px to 50 px.
    Decimal Places
    Sets the number of decimal places to be displayed.
    Background
    Background
    Background color of a chart, which can be dark or light.
