Updated on 2026-05-12 GMT+08:00
API for Reporting High-Precision Logs
Function
This API is used to report tenant logs from a host to LTS.
The access IP address is contained in the ICAgent installation command displayed on the LTS console. The port number is 8102. You can check the Example Request to see how to add the access IP address and port number in a request.
Each log event will carry a nanosecond-level timestamp when it is reported. When you view logs on the LTS console, the log events are sorted by timestamp. For details about the constraints on log reporting, see Log Read/Write Constraints.
URI
POST /v2/{project_id}/lts/groups/{log_group_id}/streams/{log_stream_id}/tenant/contents/high-accuracy
Table 1 URI parameters
Mandatory
Type
project_id
Yes
String
Project ID. For details about how to obtain it, see Obtaining a Project ID.
log_group_id
Yes
String
Log group ID. For details about how to obtain it, see Obtaining Log Group and Log Stream IDs.
log_stream_id
Yes
String
Log stream ID. For details about how to obtain it, see Obtaining Log Group and Log Stream IDs.
A write rate exceeding 100 MB/s per log stream may cause log losses.
Request Parameters
Table 2 Request header parameters
Mandatory
Type
X-Auth-Token
Yes
String
User token obtained from IAM. For details about how to obtain a user token, see Obtaining a User Token.
Content-Type
Yes
String
Message body format. Set this parameter to application/json;charset=UTF-8.
Content-Encoding
No
String
Log compression format.
Example value:
  • GZIP
  • SNAPPY
  • gzip
  • snappy
Table 3 Request body parameters
Mandatory
Type
contents
Yes
Array of LogContents
Indicates a list of log events that carry reporting timestamps.
labels
Yes
Object
Custom labels.
Do not set field names to be the same as system reserved fields. Otherwise, problems such as duplicate field names and inaccurate query may occur.
tenant_project_id
No
String
Tenant project ID. For details about how to obtain it, see Obtaining a Project ID.
Table 4 LogContents
Mandatory
Type
log_time_ns
Yes
Long
Time when log data is reported (UTC time in nanoseconds).
When logs are reported to LTS via APIs, the time difference between the log reporting time you set and the current time must not exceed two days. Otherwise, the reported logs will be deleted by LTS.
log
Yes
String
Log content.
Response Parameters
Status code: 200
Table 5 Response body parameters
Type
errorCode
String
Error code.
error_msg
String
Error message.
result
String
Response result.
Status code: 400
Table 6 Response body parameters
Type
errorCode
String
Error code.
error_msg
String
Error message.
result
String
Response result.
Status code: 401
Table 7 Response body parameters
Type
errorCode
String
Error code.
error_msg
String
Error message.
result
String
Response result.
Status code: 500
Table 8 Response body parameters
Type
errorCode
String
Error code.
error_msg
String
Error message.
result
String
Response result.
Status code: 503
Table 9 Response body parameter
Type
result
String
The requested service is unavailable.
Example Request
POST https://{access_IP_address:8102}/v2/{project_id}/lts/groups/{log_group_id}/streams/{log_stream_id}/tenant/contents/high-accuracy
 "contents": [
   "log_time_ns": 1586850540000000000,
   "log": "Fri Feb  15 15:48:04 UTC 2019"
   "log_time_ns": 1586850540000000001,
   "log": "Sat April 18 16:04:04 UTC 2019"
 "labels": {
  "user_tag": "string"
Example Response
Example response with status code 200:
Logs are reported.
  "errorCode": "SVCSTG.ALS.200.200",
  "error_msg": "Report success.",
  "result": null
Example response with status code 401:
The authorization information provided by the client is incorrect or invalid.
  "errorCode" : "SVCSTG.ALS.403.105",
  "error_msg" : "Project id is invalid.",
  "result": null
Status Code
Status Code
200
Logs are reported.
400
The request is invalid. Modify the request based on the description in error_msg before a retry.
401
500
An internal error occurred.
503
