Updated on 2026-05-12 GMT+08:00
Funnel Chart
A funnel chart is applicable to unidirectional analysis of a single process with standard service procedure, long period, and many phases. By comparing service data in each phase of the procedure, you can intuitively find and describe the phase where a problem occurs and make decisions to solve the problem. The funnel chart uses a trapezoidal area to indicate the difference between the service volume of a phase and that of the previous phase.
Checking Funnel Charts
  1. Log in to the LTS console.
  2. On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
  3. Click the Charts tab.
    The old log analysis function is going offline. You are advised to use the new SQL engine on the Charts tab page to configure charts. This new engine is more powerful, allowing you to use the pipe character (|) to combine search and analysis statements.
  4. Enter a query and analysis statement, set a time range, and click Search. For detailed syntax, see SQL Functions.
  5. Click to display the queried data in a funnel chart. In the configuration area on the right, set parameters by referring to Table 1.
    Figure 1 Funnel
    Table 1 Funnel chart parameters
    Series Name
    Name of a funnel chart.
    Data Column
    Select a numeric field. The larger the value of a field, the higher the position of the field.
    Hide Legend
    After this function is enabled, you can hide the legend names above the funnel chart.
